Uninstalling I had installed rct3 gold to my computer. i broke the cd and want to uninstall the game. everytime i do it says installshield setup launcher has stopped working. It will not let me uninstall. Can you tell me what to do. The acer people say its not their problem because it was a third party program but im asking why the installshield wont uninstall the game
    Scholar:
  • 141 Answers
Hi denka;
I did encounter this problem before and in order to un-install it, you must first re-install it, but unfortunately,since you no longer have the cd, you might want to just leave it there, because deleting the folder will not remove everything but if in case you really wanted to you can try these steps here:
Look for the rct3 gold folder on your C:\ProgramFiles\
delete the folder, delete the shortcuts in your desktop and in your "all programs" then install a free registry cleaner CCleaner,
here is the link
http://www.ccleaner.com/download and run it, it will remove all useless registry and applications,,,,,
not sure if it would 100% remove everything though but worth a try.hope it helps.
Posted on Jun 21, 2008
Catz 5 Won't Uninstall :
Try software Revo uninstaller it will hunt those files
Oct 14, 2016 | Ubi Soft Catz 5 (Windows) (680901) for PC
I am tryign to uninstall fix it, get error 5006
Installation or uninstallation of an application or game fails and gives the following error code:
This issue is due to a previous installation not finishing properly
Solution 1. Rename the Installshield folder
Make sure you've enabled Show hidden files and folders.
Find and rename the Installshield folder:
Windows 32-bit: C:\Program Files\Common Files\Installshield
Windows 64-bit: C:\Program Files (x86)\Common Files\Installshield
If there is an Installshield file in the Common Files folder, rename that one also (e.g. to Installshield_OLD).
Solution 2. Remove all traces of previous uninstall
If renaming the Installshield folder had no effect, find and delete any traces of uninstalled applications.
Applications that can assist you are: Revo Uninstaller, Windows Installer Cleanup Utility , CCleaner.
Alternatively, do a manual clean-up:
Close all running programs. Then clear the Temp folder (found via input of %temp% in Start > Search or Start > Run).
Use the Windows registry editor to delete registry entries related to the program.
Restart the computer.
hope this helps
Sep 10, 2012 | Microsoft Windows Vista Home Basic Edition...
EVERYTIME I TRY TO PLAY FIRST BATTALION IT CRASHES FROM SOME 997 ERROR CAN YOU HELP ME CLEAN MY REGISTRY
I started getting this error message also on the same PC the game previously played. I had uninstalled it and e-installed it a few years later. Here's how I got it to work again:
Let the entire introduction, cut scenes, and dialogue play entirely. Do not click to skip any part. You will eventually come to the option screen to play. It should work. Good luck.
Jul 28, 2011 | Dreamcatcher First Battalion: Gold Edition
Windows XP will not let me uninstall a programme I no longer use it tells me "InstallShield (R) Setup Launcher has encountered a problem and needs to close" HELP
This sounds to me like some of the files your computer has stored to enable an uninstall are corrupted.
Perhaps the best thing to do is use the installer cleanup utility.
The URL is http://www.softpedia.com/get/Security/Secure-cleaning/Windows-Installer-CleanUp-Utility.shtml
Jul 20, 2011 | Microsoft Windows XP Professional
I am having no luck installing Spongebob typing on Windows XP
Seems i had this problem with another spongebob game.
Try downloading and installing installsheild.
here is a link to it.http://software.informer.com/getfree-installshield-wizard-vista/
Uninstall game files before you install install sheild
You may also want to run windows update for a more updated version of xp
Thanks
Jan 22, 2010 | Encore SpongeBob SquarePants Typing...
My BB pearl 8110 keeps rebooting on its own.
  1. Right-click the Windows Taskbar.
  2. Select Task Manager.
  3. Select windows installer from the Applications tab.
  4. Click End Task.
  5. Perform a clean uninstall of the BlackBerry Desktop Software.
  6. Reboot the computer.
  7. Reinstall the BlackBerry Desktop Software.
Follow the trouble shooting steps for uninstall of the BlackBerry Desktop Software.
Task 1: Uninstall BlackBerry Desktop Software
For Windows 98/ME/2000/XP
  1. Close BlackBerry® Desktop Manager, if it is running.
  2. Open the Control Panel and double-click Add or Remove Programs.
  3. Select BlackBerry Desktop Software and click Change/Remove.
  4. On the InstallShield® Wizard window, select the Remove option and click Next.
  5. On the Uninstall Options window, select the check box labeled Remove all user settings for BlackBerry Desktop Software.
  6. On the Confirm Uninstall window, click OK.
  7. On the InstallShield Wizard window, click Finish.
Task 2: Uninstall BlackBerry Desktop Software
For Windows Vista®
  1. Close BlackBerry Desktop Manager, if it is running.
  2. Open the Control Panel and click Programs and Features.
  3. Select Uninstall a program.
  4. Select BlackBerry Desktop Software and click Change/Remove.
  5. On the InstallShield Wizard window, select the Remove option and click Next.
  6. On the Uninstall Options window, select the check box labeled Remove all user settings for BlackBerry Desktop Software.
  7. On the Confirm Uninstall window, click OK.
  8. On the InstallShield Wizard window, click Finish.
Oct 26, 2009 | RIM BlackBerry Pearl 8100
D945GCNL AUDIO DRIVERS
for this purpose you need to do following :
when you start the computer enter into bios setup.
when you switch on your pc keep on pressing delete button. a menu appers from that go to the motherboard configuration and that menu select audio driver: it must be hd audio deck you should select there realtek audio , now press F10 , press y and then enter. now restart and install the realtek drivers they will be installed without any problem.
Jul 09, 2009 | Computers & Internet
I can't uninstall the program.
1. A lot of times just restarting your computer will fix some installation issues. Their may have been updates to your computer since the last restart that need a reboot to be updated.
2. If you are trying to install it in widows vista right click on the installation file (usually setup.exe) and go to "Run as Administrator" and that could possibly do the trick.
May 30, 2009 | Sierra Hallmark Card Studio Deluxe 2005...
HELP Installshield is giving me problems
Did you uninstall SIMS first? I would ask if you have added any new devices (like a new video card) to your machine. The idea is that a device driver is being installed and there may be a conflict or file that is locked while installing. Do you actually get an error? Please indicate it here.
1) Uninstall SIMS
2) Shutdown the computer, wait for 15 seconds
3) Restart the machine, if any new changes occur, let them happen, then start at 2 again until nothing updates.
4) Reinstall SIMS
If these don't work, make sure your machine still meets the minimum requirements of the game.
Also, see that the disk is clean. Possibly make a backup copy of the game on DVD/CD and try from that.
One more thing, make sure you scan your system for Virus.
Nov 16, 2007 | Computers & Internet
Crappy computer
the solution on the cd disc is to remove the cd out then uninstall the all games installed in this cd drive replace cd drive when it comes to uninstalling sim delux is goto where saved games in sim deluxe and save folder to a different location then uninstall then re-install with new cd drive and hunt net for nc patches for games that work if this still doesn't work time for re-install windows from scratch if you have a spare hard drive use it to copy all game saves to it then redo windows and all drivers then all games then place saves back into place where they came from. good luck.
Aug 13, 2007 | Gigabyte G-MAX MA6CU (GB-GMAXMA6CU) PC...
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
