Question about Intertherm Heating & Cooling
I have a 4 ton intertherm a/c. The condenser fan is about to go out it makes a loud chirp and drag noise when starting. where can I get a replacement for it fairly cheap. It has a 1/4 hp 1100rpm ge motor.
  • 40 Answers
You have to go to an HVAC supply. Take the old motor with you so they can match the numbers. A universal motor is usually o.k. if the mounting matches. Depending on where you live this can be almost impossible as most supply houses will not sell to consumers.But, give it a try. If they ask for an account say you'll open a cash account; might work. Good luck
Posted on Jun 20, 2008
Vibration and loud rumbling noise
blower motor bad or squirrel cage out of balance.
Sep 30, 2013 | Gibson Intertherm Nordyne Miller Fan Motor...
Condenser fan motor
It would be easier to get the data from the condenser fan motor than attempt to match AC unit model numbers. If unreadable then remove the fan motor and take to someone to match with the one you have. That is what I do, Thanks Sea Breeze
Make sure you mark your wiring before removal.
Jun 14, 2013 | Intertherm Heating & Cooling
Fan wont kick on
a bad fan motor they will go bad is the blower on your inside unit or the condenser assembly outside either could be a bad motor
Jul 13, 2012 | Intertherm Heating & Cooling
My LG ice maker fan is making a really loud noise right after the water stops going in
Hello, Self-defrosting refrigerators use a circulating fan to move air through the freezer and refrigerator compartment. This fan runs when ever the unit is cooling. The fan is located in the freezer, as follows:
  • If the freezer is on top, the fan is on the back wall,near the top or bottom, in the center of the freezer.
  • If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer.
  • If the freezer is on the left, the fan is on the back wall, half way up or near the top.
Overtime the fan may become noisy, usually making a chirping or squealing sound, though it may make a loud groaning noise instead.
To find out if the fan is causing the noise,just open the freezer door and push in any fan/light switches, if the noise is louder when the door is open, the evaporator fan motor is the cause. You can lubricate or repair this motor. You must replace it.
There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor(if self-defrosting), or the defrost timer (if self-defrosting).
Thanks
Jun 17, 2010 | LG LSC26905TT Side by Side Refrigerator
Very frequent loud buzzing sound like a motor trying to start
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 11, 2010 | Frigidaire FRT21P5A Top Freezer...
My GE DBXR453GAWW is making a loud chirping noise
The rear drum berring is worn causing the chirp.
The motor berring is bad causing the chirp.
Service is needed to prevent fruther damage.
Jan 19, 2010 | Dryers
THE AIR HANDLER IN SET IN 75 DE GREE, THE CONDENSING UNIT GET OFF BUT THE A/H IS RUNNING AND DON'T STOP UNTIL THE C/U START AGAIN Y GET AGAIN THE 75, MY SYSTEM IS A 5 TON 12 SEER BOTH ARE INTERTHERM
1 Do you have a digtal thermostate?
Do you have GAS ELECT OR HEATPUMP
All of the fan setting have a dip switch so the fan can be set to match
the type of heat you have
2. is the fan switch in the on poision
Oct 28, 2009 | Intertherm Heating & Cooling
Noise from hitachi 42PD5000
The noise is coming from one of the plasma driver boards. There are 2 inside the set. These are essentially power supplies for the plasma itself and contain many capacitors. The noise you hear is some oscillation inside a cap or two. This is an indication that one or more components have drifted from their rated value. While the set will continue to work for a while, that board should be replaced. If the board fails, 1/2 of the picture will be blank or the set will not start at all. Call around to get the cost of that board. Please note that continued use of the set WILL NOT cause any harm. This is an annoyance only at this point.
Dan
Apr 29, 2009 | Panasonic Viera TH-42PX80U Plasma TV
GE side by side Refrigerator makes LOUD SQUEAK when running
Noise can come from these areas:
The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows:
  • If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer.
  • If the freezer is on the left, the fan is on the back wall, halfway up or near the top.
Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead.
To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it.
The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting).
  • The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly.
  • If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor.
  • The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
The bottom of the refrigerator Noises detected at the bottom of the refrigerator almost always originate from the back of the refrigerator. However, sometimes the drain pan under the refrigerator will rattle. You may need to tape the pan in place to stop a rattle. Also see the “Outside back of the refrigerator.”
Mar 24, 2009 | GE Refrigerators
Ruud achiever 10 seer air conditioner
It sounds like your condenser fan motor may be locked up or the capacitor that helps give the condenser fan motor a kick to get it started may be defective. Try turning your system on and using a long screwdriver try to push the fan blade on the condenser fan motor to see if it will run normally if you give it the starting boost it needs.If it does run at full speed and doesn't over heat or start and then slow down then you probably only need to replace a simple 10-12$ capacitor. If it barely turns, makes an odd humming sound or overheats etc. then you will have to replace the condenser fan motor. This is assuming that the outdoor condenser has the 220v supplied and the 24v supplied to the compressor relay, that the compressor relay is engaged and suppling 220v to the condenser fan motor.
May 28, 2008 | Ruud Matching Split Air Conditioner
Heating & Cooling Logo
57 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
