I have a Protron TV and need the Coax-to-RCA Adapter part. Do you have one available. The numbers on my warranty are disconected. maureen.nolan3@verizon.net
  • osullivan Jun 20, 2008
    I have a PLTV-26, 26" Ligquid Crystal Display. You can call me on 617-522-8828. The adapter is a very small part that is needed by the Cable TV connection to the TV.
    Genius:
  • 3,422 Answers
Please CLICK HERE AND CLICK HERE.
You can buy it from any one of these websites.
Please don't forget to rate or accept the solution.
Posted on Jun 20, 2008
    Brigadier General:
  • 3,614 Answers
What TV model do you have..?
  • 197 Answers
Sure....what model are you using fro Protron?
I have a Bose Cinemate II and an NTSC/PAL AVOL television. I am in Germany. I want to connect the audio, but the TV only has a VGA slot, and I can't figure out how to get them together.
tv model number? does the tv has Audio Out. from tv out to bose input. could be optical or rca type whichever is available.
i think you can use the headphone out but you might need an adapter plug (male, sized to fit) then splits into two male rca plugs (left & right) which will be plug into the bose audio inputs.
if the bose has coax input (digital), better use this.
Oct 07, 2015 | Televison & Video
How do I get the correctly connect from the DVD player to the TV set?
It depends on your TV's available inputs. If your TV has an HDMI port, you'll get the audio and HD video to your set with one cable if you invest in an HDMI cable; purchase the cable online (you don't need to pay $$$$ for the cable). Stores that specialize in cables will have the best picture. Press the HDMI select button on your remote to go through the resolution options for the DVD player. (see page 14 of the manual
If your TV doesn't have an HDMI port, check for component video. This will also give an HD picture to the TV. You'll need cables for the 2 RCA audio and 3 RCA (Red, blue, green) video plugs (or one cable with 5 RCA plugs) on each end of the cable. The mega-cables though can be a bit more difficult to plug in. Make sure that the colors match. (Some TVs use an adapter that consolidate the cable connection at the TV. You still need to match the colors at the adapter.)
If your TV only has composite in, you'll have an SD signal at the TV. This is the cable with one RCA plug (yellow) for video and the 2 RCA plugs (red and white) for audio. This cable is often included with the DVD player.
If your TV only has a coax connection (OTA tuner or analog cable), you'll need a Composite to RF converter. These used to be available at Radio Shack and can still be found online as well.
If some countries, the TV might have a SCART port. You can find a composite to SCART adapter.
The manual is available from Toshiba here: http://support.toshiba.com/support/modelHome?freeText=2805086 . Select the Manuals and Specs tab. The file is a PDF; so you will need Adobe Reader or a similar program to read the file.
I hope this helps. If you need additional assistance, please add a comment with details of your TV.
(if your TV has an SD (480i) resolution, you probably only have the composite and coax inputs.)
May 08, 2013 | Toshiba SD7300 DVD Player
What s-video cables do i need and what size and what kind of component video cable and what kind of coaxial cable do i need
If your TV has component, then get one component video cable (green/red/blue) and a set of RCA for audio (red/white).
S-Video/Coax is obsolete for dvd players unless you have an old TV.
Oct 29, 2011 | Protron PD-DVR100 DVD Recorder
Where is the cable connection on my tv
There are usually two types of cables that connect to your tv-- coax and RCA. Cable usually uses the coax style, but some modern tvs don't have a coaxial input, which means they probably have RCA jacks. Therefore, you will probably have to find an RF modulator or the like that has a coax cable "Cable" input and RCA (yellow, white, and red plugs) output. These should be able to connect your tv to cable. I hope this helps, and good luck! Sincerely, Der Strom
Apr 09, 2010 | Protron PLTV-32 Television
Need the rca remote code for a protron pltv-32
Afraid, you must purchase a new clicker. this is counterfeit brand, with no codes for universal remotes. If you can't get it at manufactures, check all available universal remotes at department stores for supporting this "brand". Sorry, didn't have any good experience of getting parts for "Protron".
Good luck,
Alex's TV Service,
Philadelphia,PA
215-806-5980.
Jan 22, 2010 | Protron PLTV-32 Television
Trying to hook up "back-up camera" which only has a coax output jack. Can I hook it directly into "ANT" jack or do I have to go through a demodulator and reduce to an RCA and then plug into V1 jack?
I would be interested to know the model number of the camera. "Coax" jacks are usually only used for tuners. It is more possible that it is a BNC connection. If it truly is coax than they may have used the coax jack because an RCA style plug would come unplugged too easily while driving.
Just get an F (male or female depending on the connection) to RCA (female) adapter and an RCA cable and plug it into any composite (yellow) video input.
If it is BNC than get a BNC to RCA adapter.
http://www.cablesnmor.com/bnc-rca-adapter.html
Take the part into Radio Shack and they will have the right adapter.
Nov 25, 2009 | Sylvania 6615LFP 15 in. EDTV-Ready LCD...
CABLE JACK NEEDED
You can try using an rf modulator to convert the coax signal into one that you connect to the tv using RCA jacks. I believe that model has one source on it for AV. Most stores carry these and they are relatively inexpensive.
Oct 15, 2008 | Protron PLTV-20 20 in. LCD Television
2600 atari
To connect your Atari to your TV, you'll need to get a "phono to f" adapter. These are available at RadioShack (part no. 278-255) for about $5.00 This adapter takes the phono plug from the Atari and changes it to a standard coaxial adapter. If your HD TV doesn't have an input for standard cable wires, you'll need to get yourself an RF modulator to switch the coax to RCA. If you have an old VCR with an unused cable input, that will work as well.
Mar 28, 2008 | Atari 2600 Console
Protron DVD REcorder
The coax output is just a passthrough. You need to go to the TV through the RCA output even if you have to go through a VCR or other component.
Jan 21, 2008 | Protron PD-DVR100 DVD Recorder
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
