Question about Canon FaxPhone L75 Plain Paper Laser
How do you change the time
I can't find the manual. How do you change the time?
  • 1 more comment
  • Skapeela Jun 20, 2008
    Canon Fax Machine L75
    I don't see a "data registration key"
    Thank you I am 150% satisfied!
  • 2,039 Answers
Manual is available here. Once open, you can save it by clicking on the save icon in the upper left corner.
To set date/time (page 3-6 in the manual):
1. Open the panel which covers the speed dial buttons on the right side, using the tab along the right edge (when open, you should see the Data Registration key in the upper left corner).
2. Press the Data Registration key.
3. Press the Set button 3 times.
4. Use the numeric buttons on the left keypad to enter month (2 digits), date (2 digits), year (4 digits), and time in 24 hour format.
5. Press the Set button 2 times.
6. Press the Stop button.
Posted on Jun 20, 2008
How do I adjust the settings on a 625-236 atomic clock
If you have a Howard-Miller 625-236 atomic clock, do you need to change the time zone only or manually set the time?
To set the time zone, press Mode (furthest left on the back of the clock) to get to the Alarm Time Mode. Then press Set (2nd from the left) to change the time zone. Then press Adjust (the middle button) to select the correct time zone. Press Mode again to exit the settings mode. To manually set the time, you need to remove the battery from the clock. Then reinsert the battery after 30+ seconds. Press and hold Set until the hour begins to flash, then press Adjust to change the time. Press and hold to quickly change the hour. Then press Set to change to the minutes and use Adjust to set the current minutes. Repeat this routine to set the seconds, month, date and year. Press Mode to exit to the Time mode.
The manual is available here: http://www.theclockdepot.com/howard-miller-625-236-techtime-operations-manual.pdf .
I hope this helps.
Oct 06, 2014 | Home
Change time
Hi here is user manual for your Kenwood KDC-X590.
Please download and review your manual via link below.
Kenwood KDC-590 User Manual
Nov 18, 2013 | Kenwood KDC-X590 CD Player
Setting time smartset
I couldn't figure out how to change the time zone because I didn't have the manual. Here's how to change time zone:
1. On top of clock you hold down time zone button
2. Push the up or down button to change the time zone. There are 7 time zones. The clock is set at zone 2 -Eastern Standard time. My zone is 3 -Central Time - I then had to manually set the correct time -(I'm not sure why but I did that) To test if the time zone worked properly I switched the time zones and the time on the clock adjusted automatically to the associated time for that area. I, of course, moved it back to zone 3 and the correct time for central time was displayed. I am waiting to see if the time properly adjust when time the DST changes. Also, for the manual: http://www.emersonradio.com/owner_manuals_list.php?ID=157
This is the manufacturers website (Emerson) for the EZ Set clock radio. Hope this helps.
Oct 03, 2013 | H.H. Scott SCR120 Clock Radio
Time is six minutes late
Manual Time Adjustments
Some people like to set their clocks 5 to 10 minutes fast to make sure that they will alwaysbeontime.EventhoughtheSmartSet® setsthetimebyitself,youstillhave the option of adjusting the time manually if you wish.
To manually adjust the time display depress and hold the TIME button, and press either the SET (Up) or SET (Down) buttons to adjust the time display ahead or back as desired.
Each press of the SET (Up) or SET (Down) buttons will change the display by one minute.
If you hold the SET (Up) or SET (Down) buttons the display will continue to change. The display will change slowly at first, one minute at a time.
But if you continue holding the SET (Up) or SET (Down) buttons the display will change rapidly.
Note:If you manually adjust the time, your new setting is entered into the SmartSet® memory. If the power is interrupted, the display will return to your new setting, not the original setting, when the power is restored.
Sep 23, 2010 | Emerson Smartset Clock Radio
How do i change time on the eclipse cd5100
here is the link to your owners manual ans installation manual.
Eclipse Manual
here is the link to the eclipse site.
Eclipse Site
owners manual
setting clock is under
making changes with function mode
setting time
Mar 28, 2010 | Car Audio & Video
The time has changed here in Ohio, and we need to roll back an hour, have lost manual. How do I change time?
http://www.retrevo.com/support/Sony-ICF-C318-Clock-Radios-manual/id/2727ci362/t/2/
you can download the manual from here, chk n change ur time from it
njoy..
Nov 01, 2009 | Sony ICF-C318 AM/FM Clock Radio ( White )
Changing Date/Time on fax Machine
Press teh MENU button. Go to INITIAL SETUP. Then to DATE AND TIME
Nov 29, 2007 | Brother IntelliFAX 2800 Laser Fax
SETTING THE TIME
The time on LG phones are automatically set. you cannot change the time manually. They are adjusted as per the atomic clock.
Oct 28, 2007 | LG VX8300 Cellular Phone
I am having the same problem.
According to the Timex web site: We apologize but there is no patch available. Consumers must change clocks manually. Due to newly enacted government regulations, effective this year you must change the time manually, since the calendar was programmed to change according to the time DST issued by the government, it will not recognize the change after 2007. Now the time must be changed 4 times. Press & hold the time set button until the time flash, then release it and press the ff >> or << rev buttons.
Apr 11, 2007 | Timex Auto-set Clock Radio
Canon FaxPhone L75 Plain Paper Laser Logo
75 people viewed this question
old marine
old marine
