Question about Hitachi 60SDX88B 60" Rear Projection Television
Hitachi 60SDX88BA Convergence IC - How to remove from heatsink
I am trying to replace the convergence ICs in my Hitachi 60SDX88BA. There is a horizontal metal strip over the top of the chips that is attached to the heat sink. The strip has cable straps on it. It looks like it is tabbed into the heatsink somehow, however, I can't figure out how to get this off the heatsink to expose the top of the IC's. Can anyone help?
  • allenmi1 Jun 23, 2008
    Thanks Slinteriors,
    I was trying to do this before actually pulling out the PCB. After I pulled the board out, I see that there are two screws on either side of the heatsink (about midway above the PCB) that secure this to the front of the heatsink.
    BTW - I have another prob... can't seem to disconnect the wires from the HV unit. Service manual says to rollup the silcon boots and then push down and twist the wire 90 degrees. Is there a trick to this? I am going by feel and can't seem to get the connector fins in the proper position.
    Regards
  • Anonymous Jan 24, 2009
    there is a thing funny with my hitachi - same as the previous listed above but now - red light on the front dashboard comes on - you can hear the "ignition" starting but no images - no sounds...
    what do you think?
  • Hitachi Master
  • 8,617 Answers
Most of those have screws down one side of the heatsink going into the PC board and other models you have to unscrew the ics through the fins on the heat sink.
Posted on Jun 20, 2008
  • Sonny Berry
    Sonny Berry Jun 23, 2008
    The best way to remove the HV cable is to put tape on a set of plier jaws so as not to hurt the cable then grasp the wire about a half inch above the connection push in and twist.
Hitachi projection TV - video is in 3d rainbow
This sounds like a convergence circuit problem. Your set has two convergence IC chips (integrated circuit). One is for the red CRT, the other is for the blue CRT. This is a common issue with projection TVs. It is not a difficult repair if you have any experience with electronics and soldering. Both convergence ICs should be replaced at the same time. The part is IC (STK394-160E) and is available for around $36 or less. If you have a shop fix this they will likely charge $300-$400. If this information was helpful or if you would like to know how to do this repair in more detail post back on this thread. I would be happy to walk you through it.
Dec 02, 2009 | Hitachi 43UWX10B 43" Rear Projection...
I have a 60sdx88ba and will not power on
First I would check to see if you may have shorted the STK ICs pins when you soldered them in. There may be more than one short, so check them carefully.
Next I would check to see if that circuit uses ant fuses or pico fuses on the supply lines to those ICs.
Good luck.
Dec 01, 2009 | Hitachi Televison & Video
I tried to manually focus the grids on my hitachi projection tv and I can't get the lines to line up. The top and bottom blue lines are curved, the colors don't line up except in the center. I would...
This is a defect in the convergence circuit and is either poor solder connections at the convergence ICs or defective ICs. These are large black ICs attached to a heatsink and should be marked STKxxx. If you can solder, try resoldering the pins on these ICs first. If that fails, replace the ICs. If you need more details, please update this with the model number.
Thanks,
Dan
Jul 25, 2009 | Hitachi Televison & Video
Hitachi 51G500A Convergence Problem
Hi, 110`s & 150`s are both replaced by stk 392-120`s. which run waaay cooler because the 120``s are rated at 4 amps while the 110`s and 150`s are 3 amp devices , the real key is to make absolutely certain you are not buying generics (which are everywhere on the internet), there should
be NO black print on the back side and a 4 digit code (not 5) on the front, top right corner, the originals or OEM`s are never $8.99, usually run about $12-15 and are made by Sanyo but the word sanyo will NOT be on the IC`s , so go by the info above, be sure to check for burnt resistors next to the heatsinks as well, good luck, video-tek
Feb 03, 2009 | Hitachi 51G500 51" Rear Projection...
I have a hitachi 50FX18B and the convergence lines are not lining up and the picture looks like you are looking through 3D glasses. How do I fix this??
This is a problem with the convergence circuit. If you can solder, you can fix this yourself. Please note as well that there are potentially dangerous high voltages present even when the set is unplugged. That being said... Open up the back and locate the convergence ICs (large black ICs attached to a heatsink and marked STKxxx). Try resoldering the pins on these ICs first. If that fails to resolve the problem, replace the ICs. There may be other related components that need to be replaced as well, but start with the ICs.
Keep us posted.
Dan
Jan 22, 2009 | Hitachi 50FX18B/19K 50" Rear Projection...
Blue and yellow shadows on my Hitachi rear projection TV
The color has gone crazy on you because your convergence IC's have gone bad.
These IC's operate at a very high temp, and usually only last 4-5 years.
If you remove the back of the set, you will want to look for the BIGGEST heatsink in there, on that heatsink, you will see 2 lage IC's , probably STK392-110, or STK392-120's or something close...regardless - you can go on ebay to order the new ones, but MAKE SURE they are Genuine SANYO IC's and not counterfiet cheapies. the cheap ones may only last 2 months..
You will also need some "Heat transfer paste" - you can pick this up at radio shack.
Once you remove the old IC's, test all the large resistors near them.. pull one side of the resistor out of the board so you can check it out of circuit. they will usually have the value in Ohms, printed directly on the resistor, but you may have to use the resistor color code to find out what value they are....However, usually if there is any damage, the resistor will look like it has been HOT or fried. replace the IC's and any bad resistors, and you should be good to go.
If after replacing the IC's and any defective resistors, the convergence is still bad, make sure to use a multimeter to check ALL fuses on the boards, --- sometimes when the IC's go, they will take out a fuse to the convergence power supply. If you find any bad fuses, replace them accordingly!
Hope that helps!
Dec 21, 2008 | Toshiba 55H70 55" Rear Projection...
Help
It sounds as if your convergence ICs have failed again,However if you didnt replace the convergence resistors with the ICs that is most likely the cause of early IC failure. There is a quick test to determine if the ICs have failed. Remove the front speaker panel and access panel up front, and you will see the convergence panel with the two black heatsinks. Directly in front of those heatsinks are three wire clips that are for the convergence yokes, Unplug those three wire plugs and try turning on your set. If it comes on the ICs have failed, and the ICs and resistors should be replaced as a kit. You can get the repair kit for the JVC rear projections at the following link with free instructions. Heres the link.
http://servicemanuals.vstore.ca/
Let me know if you need more information.
Jul 23, 2008 | JVC AV-56WP74 56" Rear Projection...
I have my panasonic tv
This is a convergence problem and is either bad connections at the convergence IC or defective ICs. If you can solder, try resoldering the pins on teh convergence ICs. If that fails to resolve the problem, replace the ICs. These ICs are large black ICs attached to a heatsink and may be marked STKxxx.
Keep us posted on your progress.
Dan
Jun 18, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Hitachi 50ux57b
The green and blue ghosting is a convergence problem that is either bad connections at the convergence ICs or defective ICs. If you can solder, try resoldering the ICs. If that fails to resolve the problem, replace them. These ICs are large black ICs attached to a heatsink. They should be marked STKxxx.
Keep us posted.
Dan
May 13, 2008 | Hitachi 50UX58B 50" Rear Projection...
Hitachi ultrascan HD pic looks like a 3D movie w/o the glasses
Take a look a the video below to determine if you have a true convergence problem or if you can make the adjustment through the menu feature on your TVs original remote.
Apr 03, 2008 | Hitachi 61SDX01B 61" Rear Projection...
Hitachi 60SDX88B 60" Rear Projection Television Logo
520 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
