I have a 19 inch magnavox tv receiver, model # 20mt11331/17, serial # DN1A05430. I have tried to hook up a vcr to this tv with no luck and I don't have the manual for the tv. Will this receiver work with a vcr? Welcome your suggestions. RG
premtech
  • 934 Answers
SOURCE: Magnavox combo vcr dvd
What you're describing is common when the center LED has failed / gone out. If you're really good at taking a unit like this apart and putting it back together - and not too bad with a solder stick you could attempt this one yourself... It is a pretty intensive repair but not difficult for a good shop just time consuming. The part isn't too expensive either, just an infared LED... In fact, we've run a bit short on stock once in awhile and bought one of the off the shelf versions from Radio Shack which worked just fine. Good Luck Bill
Posted on Jun 12, 2007
Shuttle83
  • 1139 Answers
SOURCE: No sound from VCR
OK here we go, The system is connected in the following manner: DTV-----RG6Coax-----VCR-------RG6Coax-------TVset Might I suggest a simple test? from the VCR to the TV use the Video and Stereo RCA outputs. The reason I want you to do this is to see if the Audio signal is being processed by the VCRs circuitry. I think it is. If it is then you problem might be the modulator that is used from the VCR to the TV when the VCR is on. You see when the VCR is off the RF connections are basically a switched pass-thru, when the VCR is on the switch send the signal to the VCR circuitry and the back into a Modulator and into the audio and video output RCA jacks. If the test works then the signal is being processed by the VCR and it might be a modulator problem, if not then the issue might be the actual RF input circuit prior to the demodulator. Another test would be to play a tape to see if the tape plays. If it does then this narrows down the trouble area between demodulator and the audio and video detector stages. If there is an internal proble you may want to take your unit to a radio and Tv repair shop.
Posted on Sep 05, 2007
  • 3 Answers
SOURCE: magnavox mwd7006 dvd player hookup
How can I hook my Magnavox MWD7006 player up to a entertainment system. So far sound is playing in Stereo (3 speaker) format instead of (six speaker) format or Db5.1. Any ideas? I used a s-video cable to connect.
Posted on Jan 17, 2008
ctf1800
  • 4402 Answers
SOURCE: New Magnavox 19" LCD HDTV
need model number and you should also post under tv not projections.
Posted on Feb 01, 2008
SOURCE: 19 inch magnavox portable tv remote does not work now the tv works
I AM VERY DISSAPPOINTED. I HAVE PAID 10 DOLLARS AND HAVE NOT SEEN ANY EMAIL WITH AN ANSWER HERE. I ALREADY WENT OUT AN PURCHASED A NEW REMOTE, I WOULD APPRECIATE YOUR REFUNDING MY MONEY AS I HAVE NOT HAD ANY HELP LIKE YOU SAID IN YOUR BEGINNING AD... I WILL CHECK WITH MY CREDIT CARD COMPANY TO SEE THE REFUND. DIANA PERKINS
Posted on Jun 01, 2008
Hook up of magnavox zv427mg9
I have a magnavox dvd recorder/vcr combo (ZV427MG9A) connected to my Sharp hdtv via hdmi cord, Can anyone tell me simple setup steps to make it record and play on either sides. I have read instruction book over and over and it is still not recording to disc or tapes. I also have Charter Cable connected. Can you tell me what do i need to do to make it work. H-E-L-P!!!!
Nov 17, 2009 | Philips Magnavox DVD+R/+RW Recorder/VCR
There has got to be a way
I have this model..was trying to hook it up to a directv hughes receiver. After a day of trying and many curse words I found that using this hookup works . Hook up your satellite connection to you tv as usual...Now plug rca cables(red, yellow white) into the corresponding holes on the BACK of the Directv receiver ..now plug the rca cables into the FRONT of the Magnavox player...you will only use find holes for the white and yellow(that's ok) Now hook up up the dvd player to the tv using the rca connection back of dvd/vcr player..or if your tv only has a coax connection you will need a rf modulator available at walmart etc. You will run the dvd/vcr on L2. The key is the connections to the FRONT of the dvd/vcr player..I hope this helps..:)
Aug 03, 2009 | Philips Magnavox DVD/VCR Dual Player
Magnavox dv220mw9 does not have a ant. in,or ant. out. How do I hook up to my direct tv satellite rcvr. My original hook up is from a DTV d10-300 RCVR to a Sylvania vcr/dvd SR2900,which has a antenna in...
have this model..was trying to hook it up to a directv hughes receiver.After a day of trying and many curse words I found that using thishookup works . Hook up your satellite connection to you tv asusual...Now plug rca cables(red,yellow white) into the corresponding holes on the BACK of the Directvreceiver ..now plug the rca cables into the FRONT of the Magnavoxplayer...you will only use find holes for the white and yellow(that'sok) Now hook up up the dvd player2.gifto the tv using the rca connection back of dvd/vcr player..or if yourtv only has a coax connection you will need a rf modulator available atwalmart etc. You will run the dvd/vcr on L2. The key is the connectionsto the FRONT of the dvd/vcr player..I hope this helps..:)
Jun 04, 2009 | Philips Magnavox DVD/VCR Dual Player
I can't setup channels for Magnavox tv/vcr.
Good luck! We are taking our unit back. We are both professionals dealing with multiple intense things, then we get home and can't figure this stupid POS out.
May 28, 2009 | Philips Magnavox MDV530R DVD VCR
DVP3345V/17 can't watch TV Programs
I would like a insturction book, as I never receiver one. I can't fine the channel on the vcr to match the channel on the tv. to tape. My Name Carol King
Address 229 Billings Ave.
Paulsboro., Nj. 08066 Thanking you
Carol King
Model #DVP3345v/17
Serial #SG1A0816014102 Make Philips VCR/DVD
Aug 16, 2008 | Philips Magnavox DVD/VCR Dual Player
Help
you'll need to bring up the menu, under "channels" or "set-up" you will find something called autotune (or manual channel set-up). it will automatically set the channels you pick up.
May 28, 2008 | Philips Magnavox 20MC4304 20 in....
Dvd/vcr installation
I have a sony regular tv and I have direct tv box. Do I hook up the dvd player to the direct tv box?
Jan 15, 2008 | Philips Magnavox DVD/VCR Dual Player
Magnavox tv problem a green vertcal streak on rt side
Dickson do you have a speaker next to your tv anything magnet will change color it may need demagnatised
Maxol your tv more then likely has a bad picture tube or you have a shorted transistor for green output shorted on CRT board.
ThankYou for using FixYa. Have a Nice Day.
Dec 28, 2007 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
