Question about Sony KV-32V16 TV
Picture goes off and on...
I have a Sony KV-32V16. When i turn on, it takes about 30 secs. for the picture to appear, though sound is perfect. Then the pictures starts going off and on, off and on for about first 15 mins while the sound is fine. After about 15 mins, the frequency of going off on on the picture decreases and ultimately it becomes all good.
Appreciate for your suggestions, and solution.
I had the same exact problem with the same model ...started last fall. I thought it was the cable box at first because the sound was perfect but it did it with a dvd also. It got progressively worse until it was like watching a strobe light. It was the holidays and I brought our bedroom set down and took it to a nearby repairman. He explained what it was which was the tube going bad and that Sony had designed it to blink like that where many will just give out. He made some adjustments to it but couldn't promise anything... "might last a couple days , a couple weeks or a couple months. It might even last a couple of years". The charge was $90 and the fix has lasted tiill this week and 2 days ago it has started again. The tube is no longer available and even finding a salvaged one was a long shot and would run a couple hundred bucks. I am thankful I didn't have a new tv to shell out for at christmas but sort of wish I had put that $90 toward a new tv. Hope this helps...Good luck.
Posted on May 16, 2010
    Sergeant:
  • 260 Answers
Most likely your Cathode Ray Tube or CRT is going bad. That model number reflects an older TV. What you are describing is a fairly common problem for that television. If you bump the TV and it improves or gets worse then you know there may be a short.. Either way, I would recommend that you use our Premium Service or use our online resources to find a repair person near you. Good luck.
Posted on Jun 20, 2008
Picture goes on for 30 sec. then off for 45 sec.,power/standby lite then blinks.can this be fixed or thrown out.SONY KDF-E50A10
Search Results
    KDF-E50A10 Sony TV - turns off and on - on its own - Sony's ...
    https://community.sony.com/t5/...Picture.../KDF...Sony...off.../442042
    Sep 12, 2014 - Our TV turns off and on without warning on its own. The standby lights starts to blink and the picture and sound go out, then 30 seconds to a ...
    Sony KDF-E60A20 problems - High Def Forum - Your High Definition ...
    www.highdefforum.com > ... > Rear-Projection TVs
    Jan 19, 2009 - 14 posts - ‎11 authors
    I recently got a 60 inch Sony KDF-E60A20 from a friend for around. ... runs for about 1 minutes then goes black(no picture no sounds), then the picture and sound come right back on for another minutes then off for 30 seconds.
Jan 18, 2016 | Televison & Video
Kv-25x5u picture goes off but sound still there, red light at front flashes 4 times every 5 secs, picture comes back on after 15 mins
if you are a tech the set is having problem in the vertical and horizontal circcuit...check IC 1509 and Q1505.good luck.
Sep 13, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Video Labels stay on - Sony TV Model KV-32V16
Press Display / ' i ' button TV original remote and on-screen display will disappear.
I repeat, you need Sony TV original remote to do so, universal remotes do not have such button.
Jan 14, 2009 | Sony KV-32V16 TV
20 inch wega @1999 Picture comes in and out
Try to finde lose connection/ cold solder joint at board attached at end of picture tube. It seems heater/ filament voltage not being supplied to picture tube after a while and picture goes to black.
Jul 22, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Delay to see the picture
Your power supply is going south, I have an old sony with the same problem. The voltage level drops and does not have enough 'kick' to start. It will work better when it is warm. The module will need to be replaced.
Nov 29, 2007 | Sony KV-27XBR45 27" TV
No picture, sound and/or stanby indicator light...dead!
Loss of low voltage supply has happened. This regulates the ability of the set to sense the remote as well as the front panel switches. Could be anything from open T1 secondary to a regulation problem; i.e. excess drop from defective component....accordianman
Oct 20, 2007 | Sony KV-32V16 TV
Sony KV-27V55 no picture sound ok
I have a KV-27V55 and when I turn the TV on the picture and sound is good for about 30 minutes and then the picture goes off, but the sound is still on. It will come back on after a while.  What do I do?
Hog_mama
Jan 14, 2007 | Sony KV-27V55 27" TV
Sony kv-32s26 32 inch tv
video card went out in the tv. You are saying you need a schematic. Be real careful getting into tvs. They have very large capacitating capacitators in them that can electrocute you. You need to take it to a repair specialist and have them run a check on it. Sounds like the video card to me though.
Sep 18, 2006 | Sony KV-32S26 32" TV
Picture takes hours to appear
Spounds like the b+ feed filter capacitor off the flyback that supplys voltage to the three drive transistors on the crt board is bad.
Apr 16, 2006 | Sony KV-32V16 TV
Televison & Video Logo
132 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
