Question about Kenmore 63942 Dryer
Kenmore 70 series
Whats the easiest way to get to the belt
Dryer wont even start or make any noises, has power.
Posted on Feb 23, 2010
Kenmore 70 series dryer, will not start. Just makes a clicking noise, in the back of the dryer.
Posted on Aug 16, 2009
My kenore when turned on only makes a low buzz type sound, it does not turn the drum! What is some possible problems?
Posted on Oct 09, 2008
  • 246 Answers
If you just want to get to it (to check the condition or what have you), You can insert a flat head screwdriver or putty knife where the lower front panel meets the upper front panel (just below the door). There are clips on either side, that when pushed on, will let you pull the lower front panel forward. Once you pull it forward you can lift it off the front clips and set it aside. If you move your head towards the right side and look towards the left you can see the belt. Now if you want to change the belt, you'll need to do the following steps. Unplug the washer. Move the two springs on either side that were behind the panel you just removed. (this can be done by pushing slightly down and unhooking them from the bottom) Near the top of the panel you just removed, there are 2 1/4" screws. These have to come out. About 4" from the right hand side, you will see a yellow/red wire if your unit has moisture sensors. Follow this up and unplug this wire. Now, up to the top. There are 2 plastic caps on either end of the console. Remove these by prying/ twisting the up. You now have uncovered 2 phillips screws that need to be removed. After they are out, pull the bottom of the console slightly forward to rotate it up out of the way. Underneath on the top of the dryer, there are 3 1/4" screws. Remove these and slide the top of the washer forward slightly to lift it off. Underneath, where the top was, \there is a 1/4" screw on each side towards the front. On the right hand side just inside the front panel the is a connection for your door switch. Depending on the model, you will need to write down where they go, or if it is a connector style, a small flat head screw driver can be inserted to work the clips out to unplug it. Now the whole front panel will come off. If your belt is being changed, take note of how it winds around the motor and the tension pulley. If the belt is still whole, Press on the tension pulley to get slack in the belt. It can now be lifted off the pulleys and slid towards the front. If your belt is broken, the belt is first inserted all the way around the drum. (look for the black mark on the drum which will show you where the belt has been traveling. As the belt lays down the left hand side of the drum, pull some slack through the pulley and around the motor shaft. Re-assemble in the reverse order and you should be set.
Posted on Jun 20, 2008
2 Suggested Answers
SOURCE: kenmore gas dryer,belt replacement
http://repair2000.com/wpoolbelt.htm#PHOTO
Posted on May 06, 2008
What is the capacity of the Kenmore 70 series model#11022722101
In the Kenmore line of washers and dyers, the 70 Series is a mid-priced family appliance that handles an average family's laundry needs. All appliances in the 70 series are freestanding and do not have stackable units. Available with both English and Spanish instructions, this mid-line series of appliances is suitable for almost any household needs. Kenmore Series 70 Specifications eHow
Jun 08, 2015 | Kenmore Washing Machines
I have a Kenmore Series 70 dryer wont start, just hums
Check for correct voltage at the terminal block on the back of the dryer, where the power cord attaches to the dryer.You should be getting 220/240 volts, check by way of a voltage tester.
If the voltage is correct, then could be the motor capacitor or the motor itself, or start button?
Good Luck !
Feb 07, 2010 | Kenmore 63942 Dryer
70 series how to replace belt
the kenmore 70 series do not come with belts they have a coupler behind the motor. Fairly easy to replace you can actually find videos on youtube.com to walk you through how to change it.
Oct 02, 2009 | Kenmore Washing Machines
Dryer wont start.
can you hear the motor or does the unit humm or vibrate when it is turned on
if yes then have a look at the belt
if not it's time sor a service call
Aug 04, 2009 | Kenmore 700 6972 Dryer
Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
Jun 30, 2009 | Kenmore Washing Machines
Help with Kenmore washer 70 Series
I called a repair man. The machine, it turns out is gear driven, and all the gears were shot.
May 27, 2009 | Kenmore Washing Machines
Belt on my Kenmore series 70 dryer broke. How do
broken belt......simple fix.......remove lint filter from top 2 screws remove.........insert screwdriver between top & front push down to pop top......1 screw on each side holding front on at top remove them....front will then pick up off the 2 remaining clips at the front bottom.....spin door around to the side belt should be laying in the bottom of the dryer or around the tub but broken.......hope this helps......check back.......
May 05, 2009 | Kenmore Dryers
Kenmore 70 series washer will not spin, clothes are too wet
Not a belt, this is only a sound deadening devise on the brake housing. Not really needed. Replace the coupler
Jan 03, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 63942 Dryer Logo
1,972 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
