Question about HP OfficeJet V40 All-In-One InkJet Printer
Color printing problems
I cannot get my Office Jet to print in color. It doesn't say anything is wrong with the cartridge. But everything prints black and white despite being in color on monitor. Occasionally I want to print an edited email or text with changes in, say, red. It won't. Or an Avery sign. It used to, but now it won't. I rarely use color. Could the cartridge be dry? If so, wouldn't it say so?
  • HP Master
  • 6,487 Answers
In the HP Director software, click Settings , click Print Settings , and then click Printer Toolbox .
In the Printer Toolbox, select the Estimated Ink Level tab. Replace any cartridge with one or more of the colors low or empty.
If the ink levels are not low, proceed to step 3.
Figure 4: Estimated ink levels
1 - Low color ink
2 - Ink levels okay
Follow the steps below to check and clean the print cartridges and the print carriage:
Turn on the power to the unit and open it to access the print cartridges. The power must be on to access the print cartridges because the print cartridges are locked in place by the capping station when the power is off. The capping station prevents the print cartridges from drying out while not in use.
When the print cartridges can be accessed, without turning off the all-in-one with the On button, unplug the power cord from the all-in-one. This will prevent the cartridges from moving back to the capping station or being damaged.
Remove the cartridge(s) from the carriage and inspect them for ink level (if possible).
If the print cartridge is new, verify that the protective tape covering the nozzles has been removed. Do not remove the copper circuit with the electrical contact points.
Figure 5: Removing the protective tape from a new print cartridge
Clean the cartridge with a cotton swab or cloth lightly moistened with distilled, filtered, or bottled water. Tap water may contain contaminants that can damage the print cartridges.
Clean the areas of the cartridge indicated in call-out 2 and call-out 3 below. Clean the nozzle plate, indicated by call-out 1 below, as a last resort to recover the cartridge. Remove any buildup from the bottom of the ink cartridge. Do not touch the nozzle plate with anything other than the cotton swab.
Figure 6: Cleaning the cartridge
1 - The nozzle plate
2 - Areas to clean to remove buildup
3 - Cartridge electrical contacts
Clean and dry the electrical contacts on the ink cartridge with a dry soft clean cotton cloth.
Figure 7: Cleaning and drying the electrical contacts
Inside the HP all-in-one product, clean the cartridge contact points inside the print carriage (the ink cartridge holder) with a soft clean cloth or cotton swab. See the image below.
CAUTION: To avoid damaging the HP product allow cartridge contact points to dry for at least five minutes before reinserting the cartridge(s) and verify that the contacts are free of any cotton or cloth fibers.
Figure 8: Cleaning the contact points in the cartridge carriage
After waiting five minutes to allow the carriage contacts to dry, reinsert the ink cartridges and then plug in the power cable.
Follow the steps below to run the print cartridge cleaning utility to flush contaminants out of the print nozzles:
For products with a Setup or Menu button on the front panel, access the cartridge cleaning utility by pressing this button. It may be listed in the Maintenance submenu.
The HP Officejet 500 and 600 product families and HP PSC 300 series products have this feature in the Maintenance section of the Manager software.
Repeat Steps 3 and 4, if necessary, to correct the problem. If the problem still exists after performing these steps twice, continue to step 5.
If the black or color cartridge has been refilled, remanufactured, or is not an HP cartridge, replace it with a new HP cartridge. Refilled or remanufactured print cartridges frequently have nozzle clogging problems due to impurities in the ink and fail far more frequently than HP cartridges. HP cannot guarantee that refilled or non-HP cartridges will print correctly in HP products. Print quality is subject to the quality of the ink and cartridge.
If all of the steps above have been followed and the problem remains, replace the print cartridge with a new HP print cartridge.
hope this helps.........
Posted on Jun 20, 2008
    Genius:
  • 2,028 Answers
It may be that the cartridge has gotten clogged. Sometimes, with very little use, the ink will dry at the edge clogging it. Try cleaning it with alcohol. If that doesn't work try a new cartridge.
  • Ryan Rogers
    Ryan Rogers Jun 20, 2008
    I've had the same problem with my ink jet at the shop. Cleaning it usually works, but not always. Sometimes we have to replace it before it's empty.
  • 197 Answers
Nope..you need to go to the application, and check the settings under color management. before you do that, do a test page, to make certain that the color management is working at all.
    Brigadier General:
  • HP Master
  • 3,614 Answers
Could be dry... have you done replacing a colored ink...?
  • HP Master
  • 13,433 Answers
Check the in printer settings about printing with color, and also on the pc side make sure its not set to black and white only.
  • Ekse Jun 20, 2008
    todo this press start -> printers and faxes -> right click your printer -> printing preferences
    go thought all the pages and make sure everything is correct, also try reconnecting the cartridge.
    the cart can also be dry.. try cleaning the cartridge head with a wet cloth incase there is some dry ink blocking it
My desk jet 3320 printer do not print black
Are you sure there is enough level on the black ink cartridge.. if does try to do "print head clean up" if doesn't fix the problem consider to replace the black ink cartridge
Aug 31, 2012 | HP DeskJet 3320 InkJet Printer
HP Office jet printer slow
I think it's that black cartridge!
The problem you've described is typically caused by one of the cartridges failing. Try removing the black cartridge and printing (not copying) a test page. If this prints at near normal speed the black cartridge is at fault and should be replaced. If the printer still prints slowly then put the black cartridge back in and remove the color cartridge, then print a page. Replacing the cartridge that causes the slow printing with a fresh cartridge will resolve the issue.
Assuming the cartridges are original HP (not re-manufactured or refilled) you can check the warranty status by CLICKING HERE
Let me know how you make out.
Ben
May 03, 2012 | HP OfficeJet 7410 All-In-One InkJet...
Have put new cartridges in and only prints yellow lines
Remove all cartridges, make sure any tape has been removed from over the nozzle. Ensure that everything has been installed properly, then use your printer (prompts on device, or in printer>control panel) to print some test pages, realign heads, etc.
May 05, 2011 | Canon Computers & Internet
My J4680 only prints color, no black. Printer is
Your black cartridge is most definitely clogged. You can easily check that by removing the cartridge and press the print head on some tissue. If there is no mark, the print head on your black cartridge is clogged. Now, HP has some kind of software head cleaning. It doesn't always work, but you can try. Here is a link to HP site, referring to your problem: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01361894&cc=bg&lc=en&dlc=en&product=3692888
Read carefully and follow the instructions.
If that doesn't solve your problem, you should buy a new black cartridge.
Also, bear in mind that with ink-jet printers, you need to print something at least once in 10-15 days, otherwise the print head will again get clogged and you will be facing the same issue over and over again. If you do not print on a regular basis, make some kind of test page, that contains black, yellow, magenta and cyan. Print that page once in 2 weeks and your printer will always work fine.
Apr 04, 2010 | HP J4680 Office Jet All-In-One Printer
Printer won't print in black
Here's a link to the HP online support solution for this problem. And this may pertain.
Make sure you have the correct settings in Print Preferences. And perhaps use the online manual available here to check other options related to the ink cartridges and printing problems....
But I have to admit I know of no way to keep the color cartridge from printing, nor from having to buy another cartridge (short of refilling it). I am intrigued by the notion that you can possibly get a grey photo cartridge instead of the tri-color cartridge to print black and white photos and richer blacks...but have never tried this, and don't know for sure if it's an option for your model....
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 24, 2009 | HP J4680 Office Jet All-In-One Printer
My HP 7410 will not print in color. Black
my hp printer officejet7410 made a wierd noise and now the only color that anything prints is in reds and pinks.
Jul 13, 2009 | HP Office Equipment & Supplies
Printer Cartrige Problem [Tri-Color]
if the printer queue is empty and you have turned both comp and printer to off it should reset.
Frpm your explanation it sounds like your color cartridge has a problem Tricolor red,blue, yellow maybe one is empty the black is a separate cartridge
Jun 21, 2009 | HP J4680 Office Jet All-In-One Printer
Printer does not print in color
I have the 4315, so I am not sure if the answer is exactly the same. But there is a setting, for only printing in black ink and you need to disable it. Here is how to get to that setting: Go to
"File" "Print" "Properties" "color" UNCLICK "Greyscale" and unclick "Black cartridge only."
Jan 10, 2009 | HP Officejet 4315 All-in-One Printer
My brother fax machine is indicating that two color cartridges are almost empty, however i never print anything and color, and basically everything is black. so how can they be almost empty?
Three reasons -
If your print driver is set to color. It will use all the colors to make black.
Because the machine is ink jet it needs to clean the print head to stop it from drying out. It will use color ink to flush the print head every two days.
When ever in receives a fax it will use some color when printing a fax, particularly Cyan.
If you only wish to print or receive faxes in black there is now a version of Brother fax that only uses black ink and has no color inks. However it may not be available in your region. If you try and cheat the system you will only kill your print head.
May 02, 2008 | Office Equipment & Supplies
HP OfficeJet V40 All-In-One InkJet Printer Logo
103 people viewed this question
Seeker5211
Seeker5211
