Question about Canon PIXMA iP90 InkJet Printer
I need to know what the error codes 5100, and 5700 mean, and what causes those errors to come up on the screen. Thank you
  • bendicione44 Jul 31, 2008
    my printer prints blank pages, and also goes back n forth then I get error 5100
    HELP
  • jack_02_02_0 Oct 17, 2008
    error code 5100, how to fix?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 97 Answers
Try resetting the printer:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Posted on Dec 07, 2008
What does error code E-11 mean
Hello Roger, thank you for your inquiry!
Based off the information you have provided you would like to know what an E-11 error code means on your Frigidaire washer. An E-11 error code means that the fill time is too long. This could be a possible problem with your pressure sensor, water valve, or main control panel. If the water pressure is below 30 PSI then it will continue to display the error code of E-11. Also make sure the hoses are not restricted or blocked because this could cause the error code to display. I hope this information has been helpful to you. -Matt
Dec 01, 2015 | Frigidaire Affinity ATF6000F Front Load...
Tip
How to Fix Blue Screen Errors (BSOD)
<p>Blue screen errors, or blue screen of death (BSOD) errors, are the most severe errors Windows can encounter. Since Windows can not recover from this kernel level error, a blue screen is displayed with the error details. The error details contain a STOP error code, which indicates the type of error.<br /> <p>There are a lot of possible causes for blue screen errors, but most of them relate to the computer hardware. The cause of a BSOD error can be a temperature problem, a timing error, a resource conflict, hardware failure, a corrupt registry, a virus or simply a device incompatibility or driver error.<br /> <p><b>How to analyze blue screen errors</b><br /> <p>The first thing to do to analyze a blue screen error is to check the meaning of the STOP error code. You need to stop Windows from rebooting when a STOP error is encountered. Once the blue screen of death is shown, you can check the meaning of the STOP error code. Together with the filename of the driver or module, this will give an indication of the error cause.<br /> <p>Another option to analyze the cause of the blue screen error is to look at the Windows system event log or to debug the memory dump (minidump) that Windows created when the error occurred. The event log can be viewed using the event viewer. Right-click Computer in the Start menu, and then select Manage. In the Computer Management window select Event Viewer. The information in the event log can be of great help to isolate the cause of the blue screen error.<br /> <p>Reading the minidump requires a bit more technical knowledge, but Microsoft has tools to read the minidump.<br /> <p><b>The most common cause of blue screen errors</b><br /> <p>In reality, the most common cause of blue screen errors is a device driver problem. Outdated, incorrect or corrupt drivers can cause the system to encounter a STOP error, resulting in the BSOD.<br /> <p>So the easiest way to try and fix a blue screen error is to reinstall and update your system's device drivers. This will ensure that all driver bugs are fixed and that all hardware has the correct driver.<br /> <p>If you know which device caused the error, you can update or reinstall that driver first. The file name in the blue screen of death can help identify the driver. Look for a file with the .SYS extension and search for that file name.<br /> <p>If you do not have the drivers for all devices, or are not comfortable updating your PC's drivers manually, you can use a driver update tool to find, download and update all device drivers for you. Such tools will accurately identify your computer hardware, including any device causing an error, and automatically install the latest drivers for it.<br /> <p>In most cases updating or reinstalling drivers will solve your blue screen errors.<br /> <p><b>Other causes of blue screen errors</b><br /> <p>However, if updating device drivers does not fix the blue screen error, there are a number of additional things to try:<br /> <p>Load the default BIOS values - resource conflicts and timing issues can be caused by incorrect BIOS settings.<br /> <p>Update the BIOS - especially after adding new hardware or installing a Windows service pack this can help fix issues.<br /> <p>Update Windows - missing updates, including service packs can be a source of stop errors.<br /> <p>Check your system - run a virus scan and spyware scan after updating your definition files.<br /> <p>Driver rollback - if you have recently updated a driver, you can use the driver rollback to revert back to the previous driver version.<br />
on Nov 29, 2010 | Computers & Internet
I need to know what error code "E1" means and what
Thank you for contacting Fixya.com.
The "E1" error code means the thermistor is open but it could be also a broken wire, loose connections at the teamster and/or the control board and a bad control board.
Please get back to us if you have any further query.
Have a nice day.
Dec 02, 2010 | Kenmore Dryers
The machine has the error code c0500. I need to know how to reset the error
Code C-0510 means a low fuser temperature. Most probable cause for that - the fuser lamp is probably defective. Try first to clear the error code (if the lamp is close to its life's end the code may pop up after a long print) so do this: power machine off; turn on the machine with the stop key held down; turn off, then on again. If this doesn't fix it then you need a new fuser
Thank you for contacting FixYa
*Please rate this solution with Thumbs Up
Nov 30, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Error code
These fault codes indicates an EEPROM error or a PUMP DRIVER error. A communication error between the Central Control Unit (CCU) and the EEPROM on board the CCU occurred.
Possible causes of an EEPROM error:
A power glitch may have caused this error. Unplug the power cord for 3 minutes then reconnect power.
Possible causes of PUMP DRIVER error:
The pump driver fails to activate. Replace the the CCU board. Most likely the CCU board will need to be replaced.
Thank you !!
Jun 20, 2010 | Kenmore HE2 Plus Front Load Washer
WHAT DOES FAX ERROR CODE 358 MEAN THANK YOU
  • The remote user pressed the Stop key, causing the session to be terminated.
  • The remote machine encountered a system problem such as no paper or a paper jam. This prevented the fax from receiving any more pages, and caused it to terminate the session prematurely.
  • The call-waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line.
  • The remote machine encountered an incompatible feature causing it to terminate the session.
Dec 10, 2009 | HP Photosmart 2710 All-In-One InkJet...
Laptop display a blue error screen and immediately shut off
Hi
Blue screen problem, unplug your memory use eraser for cleaning memory and for slot of memory use toothbrush & lacquer thinner to clean it. For best solutions barrow the working memory to your friends for testing. Bad OS can cause of blue screen display, backup your files and reformat to new operating system.Bad hard disk drive can cause of blue screen problem.
Aug 12, 2009 | Compaq Computers & Internet
WHAT DOES ERROR CODE 10 MEAN/FOR FRIDGIDARE FT.load washer
The E10 error indicates a long fill error, meaning the machine thinks it took to long to fill with water.
Recommend you check that the drain tube is not stuck too far into the stand pipe possibly causing a siphoning problem, and that the screens on the water valve inlet are cleaned and not slowing the water flow. You can hook the drain hose off, force water through it with a water hose, unclog the stinky mess and hook it back up again and work it.. that would do it...
Dec 24, 2008 | Frigidaire ATF6000ES Front Load Washer
Error code C-D351 on a Bizhub C250
didn't find this code, so dis you read the code correctly and is the model write. you can try troble reset. turn off printer and then on again, holding utility key down. push trouble reset, and reboot again.
May 05, 2008 | Konica Minolta bizhub C250 All-In-One...
Whirlpool AWM 8023 -error F06
This erroe code means drive motor tackometer error Probably a bad motor or motor drive pc board or cable problems
May 23, 2007 | Whirlpool AWM8163 Front Load Washer
Canon PIXMA iP90 InkJet Printer Logo
224 people viewed this question
old marine
old marine
