Question about Samsung Televison & Video
I need someone to help me with the controls of my SyncMaster 910mp. It's on blue screen and I want to put the cable TV on
ZENITH 50 PROJECTION TV a50m84w has the 3d picture
Posted on Jun 20, 2008
TV Samsung 910mp. I had it for 4 year. I also
It is either the backlight inverter circuits went out or the power supply for the inverter is bad due to bad caps, you will need to open it up and look inside.
Look through my pictures so you will know what bad caps look like.
http://s807.photobucket.com/home/budm/allalbums
Service manuals:
http://elektrotanya.com/?q=showresult&megnev=samsung%20&megnev2=910&kategoria=&kat2=all
May 11, 2010 | Samsung SyncMaster 910MP 19" LCD Monitor
How much can u sell it for if it is used in very good condition
As your Samsung SyncMaster 910MP 19" LCD monitor was probably manufactured around 2005, has the old 4:3 aspect ration, is a TV without a digital tuner, and is lastly a "touch screen" which has very limited applications usually targeted to special needs (i.e., digital kiosks, point of sale, or other specialized applications.) These displays aren’t meant for standard desktop computing environments.
I have found brand new touch screens for as little as $95 to over $500. My recommendation would be to target a mid-range price that you feel comfortable with but understand that savvy shoppers will most likely not purchase it when they can have an up-to-date 2010 model with a manufacturers warranty.
The last SyncMaster 910MP sold on eBay on April 22, 2010 for $92.00
Best of Luck!
May 07, 2010 | Samsung SyncMaster 910MP 19" LCD Monitor
My Samsung SyncMaster 910MP has thin colored lines all over the screen, both horizontally and vertically. this problem came up instantly. Any ideas where i can look for this failure ? Unfortunately i...
This is either loose cable connection or faulty LCD. Try and take your screen apart. It's pretty easy normally get rid of all the screws and take plastics apart. Look for loose cable connection and resit any visible connectors. If this isn't working you more likely need new monitor. Good Luck
Apr 28, 2010 | Samsung SyncMaster 910MP 19" LCD Monitor
My SyncMaster 910mp LCD TV monitor switch thus not turn on. The green light bleeps and the screen goes blank. Can you help?
ritchaddison, Problem could be inside monitor. If "cold-cathode-fluoresscent-lamps" fail to stay lit. problem might be the "electronic ballast" circuit needs work done on it. Also check the "switch-mode-power-supply" for typical failure modes that result in "black screen" complaints. Remember this!! Your monitor no different than any other brand of CCFL back-lit LCD display in it's basic design and operation. Software not problem. Only you or qualified electronics technician will repair this unit. Read my and other LCD monitor tech's fixya profiles to make decision on what option you will use on 910mp unit. 12fixlouie
Mar 18, 2010 | Samsung SyncMaster 910T 19" LCD Monitor
Same problem- SyncMaster goes on/off, bad TV image, needs reset
try to update the monitor driver tehn check the same with the cables from cpu detached if no signal comes for long then the monitor is fine also try to check the monitor on bios screen
Sep 15, 2009 | Samsung SyncMaster 910MP 19" LCD Monitor
Changing in satelit TV from Radiocanal zu TV chanal
LOOK IN YOUR LOCAL PHONE DIREDTORY UNDER COMPUTER CABLE SPECAILIST, CALL THE AND SEE IF THEY MAKE THAT SWITCH FOR YOU, 99% TIME THEY CAN MAKE THAT HAPPEN FOR YOU ANOTHER OPTION IS A TV SHOP THAT BEEN IN BUSINESS FOR 20+ YEAR MAYBE TO DO ALSO.
ROD
Feb 09, 2009 | Samsung SyncMaster 910MP 19" LCD Monitor
Televison & Video Logo
19 people viewed this question
Henry  Thomas
Henry Thomas
