Question about Frigidaire Affinity ATF6000ES 3.5 Cu. Ft. I.E.C. Front Loading Washer
Roper by whirlpool model # RAX4233PQ0
Machine will turn on but doesnt wash (doen't rotate the agitater, just hums).
  • 1,028 Answers
I assume that's a top load and not a front load as wiring connections to motor try turning coupler between motor and gearcase by hand if locked remove pump(2 clamps from motor) try again if turns free clean pump if not gearcase ..if turns free with pump attached and wires look ok suspect timer
Posted on Jun 22, 2008
My clothes doesn't get agitated in the wash or rinse cycle. I don' t see how it can get my clothes clean this way
Need more info, what kind of washing machine do you have? I am going to assume you have a front load washer. There is no agitater, instead the drum rotates, as the drum rotates the cloths roll up the side of the drum. When they are almost to the top of the drum they fall and the weight of the cloths themselves provides the agitating action. I have been using a front load washer for years, wouldent think of using a top load. Hope this helps..
Oct 08, 2015 | Washing Machines
Won't agitat under agitator yellow coupling held by 7/16 bolt should this spin freely or does this mean its stripped
it probably means that it's stripped. it grips the spine and allows movement of the agitator. the transmission shaft may be rotating back and forth, but the agitator doesnt move properly. i would remove the coupling and take a look underneath it to see if it's stripped.
Jul 06, 2011 | GE WBSR3140DW Top Load Washer
How to clean the screen under the agitater
Pull the fabric softener dispenser off the agitator, reach down and pull off the white cover (has 2 ears on it), then remove the bolt holding the agitator to the shaft. It then lifts off.
Jan 28, 2010 | Whirlpool LSR7333 Top Load Washer
Washing Machine problem
Couldd be motor or belt..loose, ifits motor possible that motor brush kit is worn epect after about 4 years, if this is case can be fixed not too expesive if motor may need new machine.
Oct 03, 2009 | Washing Machines
Washer wont agitate or spin motor hums i canturn
if the moter hums when working but does not move time for a new moter the torque side of the moter has gone look on ebay or espares
Jul 29, 2009 | Washing Machines
Wont agitate unless you move the agitator
defective motor,,,start whindin gone ,,,replace motor
Jan 17, 2009 | Maytag PAV2300 Top Load Washer
Washing Machine Drum doesnt rotate
Try this site.
In you browser box type in
then in the search box type in whirlpool washer repair
Then click on appropiate video(s)
This should hel p with your prob.
PLz rate this solution.
Dec 31, 2008 | Whirlpool Washing Machines
Kenmore washer won't agitate,drain or spin.
What you have here is a broken drive coupling
the part looks like this:
To fix it CLICK HERE
Dec 29, 2008 | Kenmore 24032\24036 Top Load Washer
Simpson esprit 750
machine stopped moving round --goes through the cycles --the agitater just woun't spin out --makes a humming noise
Nov 01, 2008 | Washing Machines
Frigidaire Affinity ATF6000ES 3.5 Cu. Ft. I.E.C. Front Loading Washer Logo
110 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
