Question about Hoover Vacuums
Change bag on U5014-900, Hoover Spirit Vacuum
4 Suggested Answers
SOURCE: replace on/off switch on hoover vacuum
My wife picked one up on the side of the road that someone had tossed. The power switch would not turn off. I took the two bolts out of the top part of the handle, and then removed the screws along the back. This will remove the required panels to access the On/Off switch. Once I found the actual on/off button, I found it to be frozen in the "ON" position. After manipulating it for a few minutes, I got the switch to work. This machine now operates great, and I now have a Hoover :)
Posted on Jan 03, 2009
  • 231 Answers
SOURCE: Need correct number on a bag. It says Z bag but it doen't fit
According to Hoover, Your vacuum takes a Hoover Z bag. Make sure you dont have a Eureka Z bag, they are different. Let me know if it works.
Posted on Apr 13, 2010
  • 240 Answers
SOURCE: Hoover Ultra U6430-900 WindTunnel Bagged
The wider belt is # 38528035,( package # 40201170 ), and the v-belt is # 38528034, ( package # 40201200 ). The wide belt should be replaced twice as often as the v-belt.
Posted on Jul 06, 2011
Why is my hoover spirit spitting dirt out the sides?
Hey there! Sounds like you have a clog somewhere in the vacuum. Try removing the hose completely from the cleaner. Use a broom stick to gently loosen and remove any clogs from the hose. Use a wooden spoon to break up and remove any clogs from the lower hose area. Also check that your bag is not full and your brushes are still spinning. Hope this helps!
Jun 03, 2014 | Hoover U5068-900 Sprint Upright Vacuum
How do you unclog the back of vacuum?
Yes you need to remove the hose and while you are at it you can clean other parts of the vac too
Dec 14, 2017 | Hoover S3410 Spirit Bagged Canister Vacuum
I don't know how to change the bag for the machine, bag # SR 401010. Vaccum is Maytag Legacy series. Is there a diagram or picture to show how to replace the bag. Thanks
http://www.hoover.com/CustomerService/Manuals/Default.aspx Enter your model number on Hoover's website to view or print a manual. I suspect that you may have accidentally discarded the bag frame ( part # 93001544 ), which holds the bag in position.
May 21, 2011 | Maytag Hoover Duros S3590 Vacuum...
I need a new bag for the Hoover 3.8 Model # U5465-900 which bag is it ?
Hoover Genuine Hoover Type Y Allergen Filtration Vacuum Bags, Fits Hoover Windtunnel and Hoover Tempo Bags Hoover 4010100Y
Feb 17, 2011 | Hoover U6437-900 / U6439-900 Windtunnel...
Apr 12, 2010 | Vacuums
I need instructions on how to change bag in a Hoover Soft & Light Supreme upright vacuum cleaner. Thank you.
Here is a link that will show you how to change bag (and more).
The model number of manual is not the same as yours but it will work for your machine.
http://www.hoover.com/pdfs/manuals/C1404.pdf
I hope this helps.
Feb 02, 2010 | Hoover Soft Light Supreme U4262-930 Bagged...
Belt change for model #u4258-930
This link will take you to a site with instructionsand illustrations to help you change your belt.
http://www.info-vacuum-cleaner.com/hoover-vacuum-cleaners.php
Hope this helps
Jan 22, 2010 | Hoover Runabout U50-940 Bagged Upright...
What kind of bag do I need?
Sound like a hoover spirit. You bag type will be on the data label on the bottom of the vac.
Oct 11, 2009 | Hoover U5016-900 Bagged Upright Vacuum
Vacuums Logo
93 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
