Question about Pioneer DEH-P9800BT CD/MP3/WMA Player/Blue Tooth Enabled
Pioneer DEH-P9800BT with Nokia N95 8GB via Bluetooth
Hi!
I have connected my phone N95 8GB to this DEH-P9800BT, but when I'm calling to someone, music (radio) stops and I can't hear anything and receiver also, but call is active. With incoming calls there are no problems.
What it could be?
Regards
  • Dragster2008 Jul 06, 2008
    For example, after rebooting the phone I can make a first call without any problems by using bluetooth and Pioneer. When I'm making the next calls problem is there again.
    I have noticed that the N95 recognizes the DEH as an headset not like car handsfree.
Sometimes the call is diverted to the phone, so the deck stops playing. Happens to me too
Posted on Jul 06, 2008
Hello, I have an odd problem with my Pioneer DEH-P9800BT Screen
Clean all contacts chemically and check all wiring for good, tight connections.
Aug 25, 2017 | Pioneer DEH-P9800BT CD/MP3/WMA Player/Blue...
My Pioneer DEH-P9800 BT faceplate won't close
The clip that locks the plate into place probably broke.
Mar 20, 2013 | Pioneer DEH-P9800BT - In-Dash CD/MP3/WMA...
Paring
how did u pair/connect ur voyager to ur deh-p9800bt? i tried from the head unit and from the phone.. read both books.. just cant seem to figure it out.. can u email me what u did plz? pt400kyle@hotmail.com
Dec 27, 2008 | Pioneer DEH-P9800BT CD/MP3/WMA Player/Blue...
Pioneer deh-p9800bt is makeing a bad noise thrrough my speakers
Since vehicles started using High Energy Ignition engine noise in stereo equipment has been a issue. You have two options. The first is to try connecting your power wire to a alternate source that may have internal filtering. If you cant find a clean source of power you will have to add a inline filter on your power wire. You can pick them up at any stereo shop.
Nov 20, 2008 | Pioneer AVH-P5700DVD Car DVD Player
Pioneer DEH -P7050BT Problem with Bluetooth connection using Nokia N95. Cannot establish a permanent connection. Disconnects almost immediately. Unable to download phonebook.
There is a file that needs to be downloaded to the Pioneer using the Software Update facility. You can get this file from your Pioneer dealer. After this, you will need to play with your device until you get the BT Audio to connect properly, then connect the Telephone. I spent about an hour trying this and then I was successful. My Nokia E71 now connects when I start the car on both the BT Audio and Telelphone connections without continually disconnecting.
Jul 20, 2008 | Audio Players & Recorders
Pioneer DEH-P700BT and Nokia N95
Yay! I got it working!
I can
Looks like pioneer recently released an update even though its not on the pioneer australia website. You can get it from:
http://www.pioneer.eu/eur/content/support/support/update/deh_bt_update.html
This works for the DEH-P7050BT as well, even though it doesn’t say it.
Basically it adds another “group” called Nokia-A… This let’s both the headset and the car kit connect at the same time.
The contacts sync too… this worked for me before all this madness btw.
You have to click yes to transfer contacts, then the phone “disconnects”. On the phone you then go to your contacts menu, and select the contacts you want across. Then send these via bluetooth to the head unit.
Once done it didn’t really have an obvious way out of the menu, so I just turned the car off, but you can probably just press source or something.
When I turned it back on after syncing, it didn’t sync up automatically, so obviously on the phone I just told it the head unit was an authorised device.
Bingo I am happy.
I hope this helps someone else who was about to throw both the deck and the E51 out the friggen window… FYI this apparently fixes all the latest Nokia N and E series phones too.
May 16, 2008 | Nokia N95 Cellular Phone
Deh-p9800bt My screen is gone
I opened the radio and found that the wired ribbon that connect the front display plug to the inside main electronic board was cutted on the place that the ribbon bends when the face plate move in and out to take off the display or put a CD.(It sees like after years opening and closing ribbon makes an edge and break). I called Crutchfield and they brought this phone # for Pioneer replacement parts, Tel. 1-800-228-7221. I called and ordered the part (P/N:XNP7026, FACEPLATE RIBBON CABLE - $24.95) and I installed it, the decks is working perfect! If you have electronic working experience will be easy, if not, buy the part and bring it to an electronic shop. The front connector plug has to be reused. This cable is used on other models like : DEHP6800MP, DEHP7800MP, DEHP780MP, DEHP9800BT, and the DEH980BT. Hope that this help!
Jose Carrasquillo- Puerto Rico
Mar 19, 2008 | Pioneer DEH-P9800BT CD/MP3/WMA Player/Blue...
Pioneer deh p9800bt
There is a yellow wire that needs to be connected to a constant +12 volt supply. This wire retains all of the pre-sets, settings, etc.
It sounds like it is not.
Check the connections with a volt meter with the vehicle off to verify it has constant +12 volts.
Best of Luck.
Nov 13, 2007 | Pioneer DEH-P9800BT CD/MP3/WMA Player/Blue...
Alternor noise
I had the same problem with my Pioneer Head Unit.
I changed the ground of the Head Unit and the AMP to the same location and that took care of the Alternator noise.
Best of Luck.
Nov 11, 2007 | Pioneer DEH-P9800BT CD/MP3/WMA Player/Blue...
Car Audio & Video Logo
281 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
