Question about Gateway GT5220 PC Desktop
Desk top problem
My computer will not boot up. it gives an error message which says fatal systems error. it gave an option to open in safe mode but when seleted it kept going back to that same screen with the error.
  • cmc1224 Jun 20, 2008
    the message on the screen was:
    stop c000021a
    { fatal system error}
    the window logon process system process terminated unexpected with a status of 0X00000080 (0X00000000 0X00000000). the system has been shut down
  • Anonymous Feb 16, 2009
    I have the same problem can you help me?
My windows player can't play
Posted on Jan 19, 2009
  • nheyls Jan 19, 2009
    my windows player can't play
Sir my pc has automatically restart and does not worked proprely they can give the fatal error plzz helpp me
Are you getting a Blue Screen error and can't read it because the computer keeps restarting?
If So, turn off the computer, then turn it on and immediately start hitting the F8 key repeatedly until you see Safe Mode. Scroll down past safe mode and you will see an option to Disable Automatic Restart. The next time you boot up you will be able to see the error message.
If it is a Blue Screen Of Death (BSOD) error message, you might need a system disc.
Mar 26, 2012 | Dell OptiPlex GX620 PC Desktop
Tip
How to boot up in safe mode from Windows XP
Showing the steps to boot up in safe mode from Windows XP.
If Windows XP is the only operating system installed on your computer, booting into Safe Mode with these instructions.
1.If the computer is running, shut down Windows, and then turn off the power.
2.Wait 30 seconds, and then turn the computer on.
3.Start tapping the F8 key. The Windows Advanced Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. 4.To resolve this, restart the computer and try again.
5.Ensure that the Safe mode option is selected.
6.Press Enter. The computer then begins to start in Safe mode.
7.When you are finished with all troubleshooting, close all programs and restart the computer as you normally would.
To use the System Configuration Utility method
1.Close all open programs.
2.Click Start, Run and type MSCONFIG in the box and click OK
3.The System Configuration Utility appears, On the BOOT.INI tab, Check the "/SAFEBOOT" option, and then click OK and Restart your computer when prompted.
4.The computer restarts in Safe mode.
5.Perform the troubleshooting steps for which you are using Safe Mode.
6.When you are finished with troubleshooting in Safe mode, open MSCONFIG again, on the BOOT.INI tab, uncheck "/SAFEBOOT" and click OK to restart your computer.
Select your steps to boot up into safe mode to your Windows XP System.
Other relative articles: Crack windows password from system SAM files
How to reset Windows administrator password if forgot Windows Xp/2000/2003/2008/Vista/7
on Apr 16, 2010 | Computers & Internet
My computer keeps turning its self off before it gets to the desk top screen.
i think your operating system is crashed or corrupted. try to boot in safe mode. for boot in safe mode press f8 at the time of startup and select safe mode. if your system boots in safe mode. If its a crash of operating system then run chkdsk for c drive and select two options with tick marks. it asks to scan at next time startup. select yes and restart your system. after scan it will fixed.
Jun 16, 2010 | E-Machines eMachines Desktop PC
Philips laptop has fatal error message - system
Hello Vixen,
Sorry about the problem.
I will try as much as possible to give you a detailed steps you can try.
And they are going to be two Options.
First options is this:
If you have a Windows Installations CD.
Insert it into your CDROM Drive, then when you put on your system,
Go into the system BIOS/Setup by pressing 'Del' key or any other key (e.g F10) required to enter setup, while the system is booting.
Now look for where you have Boot Sequence or Boot Order.
Select the CDROM to be the one where the system will boot from.
then follow the On-Screen instruction and select repair.
Next Option is if you don't have the Windows Installation CD.
Put on your Computer,
While it is booting, Keep tapping the F8 Key, and this will bring up the Menu where you will have to select the different options of booting.
First of all try out "Last Known Good Configuration".
If it doesn't work, then try booting into safe mode.
If it boots in Safe Mode, then click on start---> Accesories--->System tools---> then System restore. Then restore you system to an earlier time.
Now, If all that still doesn't work, then Select Safe mode Command prompt.
When you get to command prompt, type: chkdsk or chkdsk /p and press enter.
This will scan your system for errors and correct it.
If this does not work, type scanreg .
This will scan your systems registry for errors and fix it.
If Trying All these does not work, then Go back to Option 1.
Which means you will have to get a Windows Installation CD.
I am giving you all this trouble-shooting steps with the assumption that you are using Windows XP. (Because you did not specify your type of OS).
But In case you are using Windows Vista,
then under option 1, after inserting the CD, and booting from it,
just follow the on-screen instructions and select:
"Fix what is preventing my Windows to boot Properly" , under the options.
All these are the FULL trouble-shooting steps you will need to get your system working.
But if after trying all of them out it still does not work,
Then you will have to take them system to a good technician.
Kindly keep me posted and let me know how it goes.
Thank you for using FixYa.
Good luck
Nov 25, 2009 | Computers & Internet
Inspiron 1200 "Fatal Error" , cannot F8 into safe mode
Press "F8" while booting up. It should give you an option to go to safe mode.
Jun 29, 2009 | Dell Inspiron 1200 14.1 XGA LCD...
On my lap top i receive message-"error loading operating system"
Trying booting into safe mode by pressing F8 while the computer is booting up.
Choose safe mode with the arrow keys and see if it boots that way.
Mar 20, 2009 | HP Compaq nx9030 Notebook
HP Pavillion dv9000 fatal error
On the windows boot screen you should be getting choices for safe mode, safe mode with networking, etc ...
Select "Disable automatic restart on system failure'
And let me know what error message(s) you have ... write it all down
Jan 14, 2009 | HP Pavilion dv9000z Notebook
MY DAUGHT WAS USING MY COMPUTER AN SHE DOWNLOADED SOMETHING WITHOUT ME KNOWING AN,I HAVE SOME ICONS ON MY COMPUTER THAT WILL NOT DELETE OFF HOW DO I FIX THIS PROMBLEM
You can trying using safe mode
To get there depends on your OS
If your using Windows 98:
  • Restart the computer.
  • Just after the POST diagnostics and memory count, start pressing the F8 key
  • On the Startup Menu, choose Safe Mode
or you may use the system configuration Utility Method.
  • While in Normal mode, Close all programs.
  • Click Start, Run and type MSCONFIG in the box and click OK
  • In the System Configuration Utility, on the General Tab, click the Advanced Button
  • In the Advanced Troubleshooting Settings dialog box, check Enable Startup Menu. Click OK. Click OK again when the System Configuration Utility reappears.
  • You will be prompted to restart the computer. Click Yes. The computer will restart in Safe mode.
  • When you are finished with troubleshooting in Safe mode, open MSCONFIG again and uncheck "Enable Start-up Menu." under the Advanced Menu, then click OK and restart your computer
Windows Xp:
  • If the computer is running, shut down Windows, and then turn off the power
  • Wait 30 seconds, and then turn the computer on.
  • Start tapping the F8 key. The Windows Advanced Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. To resolve this, restart the computer and try again.
  • Ensure that the Safe mode option is selected.
  • Press Enter. The computer then begins to start in Safe mode.
  • When you are finished with all troubleshooting, close all programs and restart the computer as you normally would.
  • Close all open programs.
  • The System Configuration Utility appears, On the BOOT.INI tab, Check the "/SAFEBOOT" option, and then click OK and Restart your computer when prompted.
  • The computer restarts in Safe mode.
  • Perform the troubleshooting steps for which you are using Safe Mode.
Windows as part of a multiboot system
Use this method ONLY if you have multiple operating systems installed on your computer.
  • When the Boot loader menu (list of the available operating systems) appears, use the arrow keys on the keyboard to select the version Windows what you want
  • Press Enter, and then immediately begin tapping the F8 key. The Windows Advanced Options menu appears.
  • Scroll to and select the Safe mode menu item , and then press Enter.
Windows Vista:
  • Turn the computer on or Restart the computer
  • Start tapping the F8 key. The Windows Advanced Boot Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. To resolve this, restart the computer and try again.
  • Ensure that the Safe mode option is selected (the top option)
  • When you are finished with troubleshooting, close all programs and restart the computer as you normally would.
Oct 20, 2008 | Computers & Internet
I keep getting a blue screen that says fatal system error. My computer is a toshiba satellite x205-s7483. Th computer wont start up and takes forever but when it does the computer runs slower, freezes or...
it is a fatal error mostly occured in windows like xp. it is also the prevention of disturbing with the memory.
we have some tips to recover from there. first you have try to boot as last known good configuration option in the windows startup option. (you press F8 key, when the computer boots up).
if it is not working, try to boot in safe mode.
if it is also not possible, you have to go with your xp cd or operating system cd. first boot with operating system cd and go for the repair option to recover your operationg system.
Jul 21, 2008 | Toshiba Computers & Internet
Windows error
First, make sure there are no discs in any of the drives as this could disrupt the boot process. Prior to seeing the HP screen you should get a prompt as to press F10 to go into system setup. Once in system setup choose the option to go to system restore or system recovery. From there you should be able to restore your computer to a sytem restore point that was set up with a checkpoint at set intervals by Windows XP. If that is unsuccessful you may have to utilize your recovery discs.
Good Luck.
Jun 27, 2008 | HP Computers & Internet
Gateway GT5220 PC Desktop Logo
105 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
