Question about Ricoh Office Equipment & Supplies
Ricoh CL 4000DN SC 241 Error - Ricoh Office Equipment & Supplies
boyrevel
  • 71 Answers
SOURCE: sc 542 error code
Error SC 542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won?t come ready until the prior error condition is cleared. The magic keystrokes, clear the error code: The Fix In order to clear error SC542, you must perform procedure 5810. Press and hold online + escape, then power on. Use up and down arrow keys to select SP2 Press Enter Use up and down arror to locate SP5 Press Enter Use up and down arrow keys to select 810 Press Enter Confirm the selection Power off and on. The error code is now cleared.
Posted on Aug 14, 2007
Bubbabear64
  • 2794 Answers
SOURCE: ricoh aficio 2027
SC542 is a warm up error from the fuser.
SC 870 is an address book error.
Turn the power off on the copier. Wait 30 seconds and then turn the power back on. See if it goes away.
Let me know if it doesn't.
Posted on Jul 12, 2008
mastersaintx
  • 928 Answers
SOURCE: Ricoh Afficio cl 7000 sc 552 code what is it?
Try the procedure below. Its a hardware error on the device
Press Enter
Press Enter
Press Enter
Power off and on.
Posted on Aug 18, 2008
Bubbabear64
  • 2794 Answers
SOURCE: RICOH 2015 error code sc 500
Main motor/ transport motor lock/ fusting motor error.
The only thing you can do is check for any obstructions in the machine.
That needs to be looked at by a service because the problem could be a motor, a pcb, or a power supply.
It can be a lot of troubleshooting to do.
Posted on Oct 19, 2008
yooperbud
  • 8637 Answers
SOURCE: RICOH LASER AP2610N - error - SC 998
Normal 0 Could have a corrupt driver.
Disconnectthe printer or at least be sure it is turned off. I'd doboth and when the CD software program asks you to connect the printerto the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 30, 2009
I got error sc 554 for ricoh mp1600
Ricoh Copier Error Code SC 554 problem Reseting SC 554 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Ricoh Error Code SC 554
Heating roller overheat (hardware error)
The heating roller thermistor detects 240°C or more.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Oct 17, 2016 | Ricoh Office Equipment & Supplies
Press Enter
Press Enter
Press Enter
Power off and on.
Aug 18, 2008 | Ricoh Aficio CL7000 Laser Printer
How to reset SC 302 code ?
sc302 is usually PCU or charge roller.
As you say you have recently replaced the Drum/PCU, is the drum turning correctly?
Check charge connectors and connectors on the back of the pcu. To reset that code, simply turn main power off and on again. If problem comes right back....the machine detects the cause still exists. May be an issue with the HVT.
Sep 01, 2014 | Ricoh RICMP201SPF AFICIO MP201SPF,...
Sc 241 ricoh mp c300
LD error
LD error continues for 0.5 seconds. (After LD error is detected, a release of LD error is written to the GAVD circuit during monitoring.).
LD unit defective
Dec 03, 2013 | Ricoh Office Equipment & Supplies
Problem Ricoh CL 7200 error SC 542
fuser assy replace it and reset code or have tech come out and fix it
Jul 19, 2013 | Ricoh CL-7200 High Yield Toner Refill Kit...
Ricoh 3045 sc865-01 , any solutions ?
In general the SC 860-900 refer to HD acces error.
SC 865 - the hard disk detected an error.Error detected other that the bad sectors error SC 863 or the CRC error SC 864.Reset the error code by turn the operation switch and main power switch OFF and ON.Try disconnect and reconnect the hard disc connectors and verify the cable.
Feb 20, 2013 | Ricoh Aficio 3045 Digital Copier: 45cpm....
Ricoh CL 7000 down due to an SC-685
Do you have the copier feature option installed?
It is most likely just a loose connection on the interface between the main printer unit and scanner section. Turn off main power (red button), and re-seat the connector.
Please let me know and rate solution :)
Apr 17, 2009 | Ricoh Aficio Colour 3006 Color Copier
Have a Ricoh Aficio Cl 4000DN and have replaced the CPU Drum
You most likely have a defective "yellow" PCU . Try replacing that.
Otherwise you have a high voltage problem
Feb 23, 2009 | Ricoh Aficio AP3800C Laser Printer
Ricoh CL 7000 error code SC 387
This Code relates to color gamma error in the Yellow development. Possible causes Low toner density in the Y toner,Toner supply Y mechanism problem( not supplying enough toner),Laser exposure problem, image transfer problem. My suggestion would be to ensure you have toner in the cartridge( but by this time it has depleted the developer), and you will need to replace the development unit and possibly the drum Unit. My best guess would be the development Unit.
Munybuny
Apr 24, 2008 | Ricoh Aficio Colour 3006 Color Copier
Ricoh copier aficio 401 error sc 419
hi im jules_09.
sc 401 means transfer roller leak error.a transfer current leaksignal is detected.posible causes is 1.transfer power pack is defective 2.poor connection between the transfer terminal and the trnsfer power pack
sc 419 mean quenching lamperor.1 quenching lamp defective 2.poor conection between power pack and quenching lamp.
check all component but pay attetion to the current leak at the transfer because there both connected at the power pack
Nov 01, 2007 | Office Equipment & Supplies
147 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
