Question about Kenmore 24032\24036 Top Load Washer
Leaks I have a Kenmore Elite,during the drain cycle and sometimes the spin cycle it leaks on the right side as your facing the machine.I have had the machine apart but find no signs of bad hoses or a cracked tub,any suggestions? Jim
  • Anonymous Jun 23, 2008
    My washing machine has a cold water drip inside the drum when the machine is not on.
  • Anonymous Sep 07, 2008
    water leaks when water runs in the tub and when the rinse cycle comes on this all happens on the right front
    Sniper:
  • 68 Answers
It sounds like you have a leaking pump. The pump is easy to replace:
#1 Use a shop vac and pull all the water out of the drain line. This will keep you from having to clean up about 1 gallon of water off of the floor.
#2 Lift the front of the machine enough for you to get under and see.the pump just inside the front of the washer.
#3 Lift the 2 retaining clips off of the pump. This will allow you to pull the pump off of the motor.
#4 Remove the 2 clamps off of the hoses.
#5 Install the new pump into the hoses, and reinstall the clamps.
#6 With the retaining clips installed into the motor housing, install the pump.
#7 Attach the retaining clips, and set the washer back on the ground.
You have now replaced the washer pump.
If you have any questions, let me know
Please rate this solution
Posted on Jul 29, 2008
  • 481 Answers
To jim, you may want to check the water pump closer, sometimes the water pump will leak a little during a cycle and the water will leak somewhere on the floor, not necessarily near the water pump.
to the second post (guest), it sounds like you have a bad water valve. the valve is not closing properly and causing water to leak thru.
Posted on Jun 27, 2008
Why does it leak all over floor after last spin cycle?
my washing machine leaks water onto the floor during each spin ...
https://answers.yahoo.com/question/index?qid...
Feb 3, 2010 - During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. ... It happened to us due to over loading. ...something can get betwen the two tubs it this all fails your tub seal is ...
Sep 30, 2015 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore 80 didn't drain during the spin cycle and leak underneath machine. Makes buzzing noise in the wash cycles.
The pump is likely damaged if it was leaking. Look for a ring of melted plastic on the face side of the pump. Check to make sure the hole is not rounded where the motor shaft enters the pump.
I'd replace the pump just to make sure the washer doesn't flood some time in the future even if the pump turn out to be ok now.
Vlad,
First Choice Appliance Service. Sacramento, CA
Jul 05, 2012 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Water pours in on spin cycle
The first thing i would check is your boot around the door for a rip or tear. Also check the drain line for any types of leaks. You can also remove the bottom panel there will be three torx screws and you can look at your drain pump while in spin and drain cycle to see of the leak located in that area.
Hope this helps _MJ_
Jan 29, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore series 70 washer leaks during rinse?
the was exhaust hose is either plugged or cracked. also check the drain it is put into as this sometimes will be puleeged with fabric from the clothes you wash
Jul 10, 2009 | Kenmore 22422 Top Load Washer
Washer will not turn on...
My washer makes a wierd clinky sound during wash and rinse cycle and it has began to stop spinning the water will drain but clothes will be soaked. Also sometimes during spin cycle it will agitate instead of spinning
Jun 22, 2009 | Kenmore Elite 45986 Front Load Washer
Leaking water during spin cycle
Likely the tub seal is failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 28, 2009 | Kenmore Washing Machines
Water leaks during drain cycle and the machine
Hi
If the water leaks during drain and spin only: A washer that leaks only during the drain/spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Please do rate this solution as "FixYa" if found useful.
Thanks
Rylee
Mar 17, 2009 | Washing Machines
Water leak from Kenmore elite
If the leaks happens during drain cycle, this is usually because of a leak on the drain pump hose, or because of a faulty drain pump that is leaking.
As the appliance must be taken apart and the pump may need replacement, it is better to call a repairman to do the job.
Check that leak is not from drain hose, from water supply hoses, or from gasket first.
Dec 29, 2008 | Kenmore Elite HE4 Electric Dryer
Water pouring out of my Kenmore HE3t
Teach, usually all leaks are visable. Have your husband remove the lower panel by removing the 3 #11 torxs on the bottom panel and pull down and off. Now you can see the tub drain hose and filter. First check the dispensor drawer. Remove it and check to see if you have anything blocking the inlet tube to the tub. Sometimes a seal from a fab or detergent cap blocks the entrance. When the disp. is out just reach in with a finger in front and you will feel the inlet grate. Next inspect the boot. Make sure there are no cuts or rips. Once you feel that this checks out ok, replace the disp. drawer and put the machine in the test cycle. On the left side press drain/spin. On the right side press spin speed until No spin is lit. Then press the prewash button 4 times until C:00 is displayed. Now let it do it's thing. It will fill, rotate, drain and spin. It will end with C:08 in the display. With the bottom panel off during the test, see if you can find the source of the leak. You can push cancel/drain anytime to stop the test. Catriver.
Jul 08, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
103 people viewed this question
Fordexpert
Archaeology
Archaeology
2mikecurtis
