Question about Maytag MZD2766GES Side by Side Refrigerator
Refrigerator not getting cold - freezer still pretty cold - perhaps not all the way raphael@raphaelbachrach.com
  • 17 more comments
  • Anonymous Jun 22, 2008
    Hi Raphinina, I too am having the same problem . Fridge side is not getting cold but freezer is working fine. Anybody have any suggestions? My fridge is 5 years old
  • raphinina Jun 23, 2008
    The freezer is NOT icing over - so this answer does not seem to apply -- any other thoughts? Raphinina
    Our unit is about 4 years old - compressor seems to be running - Refirgerator is only slightly cold at highest setting ONLY in a few areas (crisper drawer) and freezer is mostly freezing - but probably not as much as supposed to for such a high setting - I can't believe this is unusual nor too hard to fix
  • bait12 Jul 01, 2008
    coil frozen, freezer freezing but not all the way refrigerator is on the warm side compressor is warm fans running
  • Anonymous Jul 02, 2008
    not as cold as before
  • biguygrandpo Jul 18, 2008
    inside freezer frosted - fridge not cold - evaporator well frosted or frozen
    Do I need a defrost heater & thermostat assembly?
  • gurowar Aug 01, 2008
    I have an amana side by side refrigerator SXD26VE it is about 9 years old
    the freezer is cold but no cold enough to freeze water. Last time I had this issue the coils where frozen and I ended up replacing the thermostat and that seemed to have fixed the issue. That was 4 years ago, I thought I was having the same issue so I unplug and remove the thermostat to get another one but the store was close so I plugged it back in. It seems to work but the freezer isn't cold enough to freeze water is there something else I can check?
  • jacko04 Aug 13, 2008
    I think I have the same problem as most of yo described...Freezer it's fine but refrigerator not getting enough cold air...i have defrosted freezer overnight but still when powered back looks like refrigerator is getting some air flow on the higher (9) setting but that is most likely not enough, is there a part that i should be looking at replacing? When I move settings from low to high for refrigerator it doesn't change the amount of cold that is flowing in...Thanks for any help
    Jack
  • gnkencjck Aug 18, 2008
    I own an admiral refrig it is 2 years old and the refrig is getting some cold air flow but not enough to keep the refrig at 40 or so. The other day the fan was making a horrible noise and the noise stopped and is turning kicking on and off but the flow to refrig is not as strong as I think it should be. PLEASE HELP/ I took the fan cover off in the freezer and the fan is turning very fast and kicks on and off.
  • Anonymous Sep 03, 2008
    kenmoer side by side frezzer good refigerator not cold enught
  • Anonymous Oct 15, 2008
    I have a Kenmore side by side refrigerator freezer. My freezer is working fine but my refrigerator is not getting cold. What could be wrong?
  • lrzab Nov 15, 2008
    my frig is running consantlt and noisy frig part not cooling but freezer is i do have some frost builup on radiater should i just thaw out or is my defrost thermostat bad.
  • Anonymous Nov 17, 2008
    Freezer is cold enough to freeze everything. There is no frost of ice build up in the freezer. The refrigirator is not very cold at all and the motor continually runs. I have both the refridgerator and freezer set to the coldest setting to see if anything happens.
    Thanks!
  • anandadog Nov 26, 2008
    We have a Maytag side by side refrigerator, and the freezer works fine, gets cold easily, but the refrigerator side is hopeless. Most of the time it just doesn't get cold and food goes off. Sometimes it works for a period of time, but then will suddenly get warm again. Turning it off and on again seems to help sometimes, but we need a solution to the problem, as too much food has been thrown out.
  • ron rader Nov 28, 2008
    i have a side by side. kenmore model 106.56536400 Cold Spot. the symptoms are the same where as the freezer is ok but we have lost cooling on the other side numerosu times and lost food. Sears has replaced the sensor board twice and the motor module once. what can solve this problem?
  • edwinn Dec 02, 2008
    my refrigerator is about 5 years old. The freezer still works but not as cold as it should be , however the refrigerator side is not cold even at the highest setting.
  • mayes39073 Jan 22, 2009
    kenmore refigeraror model# 9557611, serial # 3512707. will not get cold. have check the drawn, that's ok. compressor is working ok. Is the therostat worn out and need to be replaced
  • Anonymous Feb 10, 2009
    I have a Jenn Air side by side about 10 years old. The refrigerator is barely cold on the highest level. The freezer is working fine.
  • thirdmeridia Apr 23, 2009
    No cooling at all in the 6-yr old refrigerator, freezer not cold enough. We removed the interior bottom panel of the freezer & sure enough there was an ice dam. We melted all of it with a hair dryer. Now, everything is working as it should. I hope that it lasts longer than 2 weeks.
  • 828 Answers
Defrost system problem; Check back wall of freezer for frost buildup which indicates the defrost problem.
Posted on Jun 20, 2008
I finally took everything out of the freezer and took off the panel which was frozen solid so i defrosted that with a hair dryer and then i vacuumed the back which was covered up in dust, including the coils . Now the whole refrigerator is cooling just fine. I wonder how long it would stay that way....maybe for another 5 years?
Posted on Dec 10, 2008
If you have not already tried, clean the dust out from the vents. Typically there is a vent at the bottom front that can be removed easily. Also, unplug the unit and remove the panel near the bottom rear where the icemaker water and power cable go in.
Vaccuum out both areas gently with a shop vac. Careful, there is delicate insulation in there you don't want to tear up. But if you do it's no huge deal.
I've had my fridge 10 years and I've had to do this a couple of times. Last time I had a repairman come out because I didn't understand the problem. This time I did it myself.
I have the same problem can someone help
Posted on Jul 12, 2008
I starting having this issue about few weeks ago... The freezer is fine, but the fridge becomes warmer by the day - the temp in the fridge is hotter than the room temperature. Since Maytag was of no help... I removed all items from the freezer and found that the back panel was all iced up. Took the panel off and found the entire cooling pipes were enclosed in ice - cutting off the airflow to the fridge. All fans, ice maker, etc were functional. Manually defrosted all the ice in the freezer, including any vents leading to the fridge (one at the top right, three in the bottom right), with a hair dryer. Now the fridge was getting the cold air it needed. The fridge ran for about two weeks without issues, and again the same issue. Sure enough, the the cooling pipes are engolfed in ice again.
Maytag support is more of a problem than help. First they denied assistance, then they provide assistance and generate a repair ticket, because this is covered under a recall they have/had, and scheduled a repair man fix the issue. The repair man had informed us he was on his way, after waiting a whole day, but three hours later found out Maytag had cancelled the ticket!!! Maytag's troubleshooting guide is nothing more than "Is the fridge light ON?". We have had been Maytag customers since the 1970s... Loved the old units, they worked like a champ... I purchased all Maytag appliances for multiple homes I built... BUT MAYTAG CAN KISS ALL THAT GOODBYE!
[sorry... this has been a very frustrating experience for us].
Thanks for the postings. Can anyone please tell me the what part I need to replace and where I can get one? Many thanks in advance.
Posted on Jul 01, 2008
Mine was just like that the other day. I had a repair service man come look at it and the timer on it went bad. He fixed it and now it is working fine. Mine is only 5 years old too.
Posted on Jun 25, 2008
I just bought a pretty old, used GE fridge. (It's a freezer on top model.) The fridge is cold but the freezer isn't cold enough. It just barely makes ice part of the time. Ice cream defrosts and bread...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 24, 2010 | GE Refrigerators
Kitchen aid top freezer is developing ice and refrigerator is not getting cold
well well looks like we have a defrost problem... either a board, defrost heater or timer or termination switch.... let me get the model number and we can get this fixed pretty easily... visit whirlpoolpartssurplus.com where you can reach me there ext 0.
Apr 27, 2009 | KitchenAid Architect KTLA19KRSS Stainless...
Kenmore 21 refrigerator not getting cold - freezer still pretty cold (top) - perhaps not all the way
you have a defrost prblem or a leak in the sealed system.if you see frost built up on back freezer wall then it is a defrost problem also check evaporator fan motor to see if it is running.if machine is in defrost you wont hear it.so when compressor is running see if fan is running.
Mar 06, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Amana Side-by-Side Refrigerator Not Cold
can be a few things, if you open the freezer door do you hear afan running?? perhaps the fan is no good?? is there a large amount of frost on the lower plate of back wall of freezer??? very common issue to have a bad defrost thermostat.
Feb 19, 2009 | Amana ARSE66MB Side by Side Refrigerator
Refrigerator not getting cold - freezer still pretty cold - perhaps not all the way raphael@raphaelbachrach.com I purchased a Kenmore fridge in Aug. 2005 (no freezer - fridge only). During a couple weeks...
I see several things wrong here. There is a vent or duct that allows some cold air from the freezer to the refrigerator. This vent may be blocked. Look to see if anything is in the way. Next, you may want to stay on Sears to fix this problem. Call them and ask for a time to be there. Then call daily after that and eventually they will respond. The squeaky wheel gets the oil! The problem may be in the compressor or evaporator. Hopefully, this is still under warranty. Let me know how you do.
Feb 14, 2009 | Freezers
assuming you have had the appliance unplugged for a while, plug back in and it may well work ok. if so, get back to me and i'll take it further
Aug 31, 2008 | Refrigerators
Refrigerator not getting cold - freezer still pretty cold - perhaps not all the way raphael@raphaelbachrach.com refrigerator not getting cold - freezer side is working
Sounds like a defrost problem or dirty coils under the machine. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 01, 2008 | Maytag MZD2766GES Side by Side...
REFEGERATOR NOT GETTING COLD
  • possible causes:
Maytag MZD2766GES Side by Side Refrigerator Logo
3,037 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
