Question about Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer
SET UP 2204 FOR FREE PLAY. - Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer
    Champion:
  • Wurlitzer Expert
  • 211 Answers
The 2204 uses a credit unit called a Playrak. (I'm not sure but it might have 'Coin Registration Unit' written on it.) It's the unit that swivels 90 degrees out of it's housing.
There is a large fibre gear in the middle of it, clearly visible, which has a spring mounted in such a way that it drags the wheel round one notch when a credit is taken off. You put coins in, it clocks one way.....you make a selection it clocks the other way until it pushes a single leaf switch apart and you are out of credit.
So what you do is first clock up credits, then disable the cancel effect by simply flipping the spring to the other side of the centre of the gear....(so it pulls the gear the OTHER way round). So every time the cancel solenoid kicks, the spring actually stops the gear going round and clocking off the credits.
It'll make more sense when you see the bits I am refering to.
Dave
The Jukebox Doctor.
Posted on Jun 21, 2008
How to fix the sunroof on 2204 acura tl
Year???
Sunroof won tilt or auto open close Have to hold button to close open...
https://ca.cargurus.com/Cars/Discussion-t2950_ds616402
You might register with Autozone to see if they have a free service manual for your year of vehicle. This is not Michael J. Fox's DeLorean (wink).
Sep 08, 2017 | Acura Cars & Trucks
Digital audio dab 2204 Just want to knw how many watts is the amp.
Websites Get Hacked, Backup Data 2GB Free Website Backup In Cloud!
Sep 22, 2011 | Digital Audio Car Audio & Video
I had to change the batteries and now it only reads in "kg" how do i change that on the model 2204?
Since your problem started with a battery change, I am going to assume that method 1 is most likely going to fix your problem...Good luck!
Method 1
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
Method 2
Body Fat Monitor/Scales: BF-542, TBF-551, TBF-521, TBF-531, BF-681, BF-682, BF-679, BF-680, BF-578, all Ironman products, and all InnerScan products.
Select the preferred weight mode by using switch on the back of the measuring platform.
Jan 12, 2011 | Tanita 2204 Body Fat Scale
COBY TFT LCD TV/2204 works fine connected to TimeWarner cable without HD box. Get same channels as Samsung TV without box in Kitchen. However, I cannot get my old Compaq laptop to drive the 2204 as a...
the native res. for the TV is 1680 x 1024.
you may want to try a different resolution
like 800 x 600 or 1024 x 768. not the native resolution
of the laptop.
Dec 27, 2010 | Coby TFTV2225 22 in LCD TV
Cable jack twisted off
If you are refering to the Coax cable connection at the back of the TV this isnt good news as the tv will need to be sent in for service to the repair depot.
US - 1-800-305-2204
CAN - 1-800-305-2204
Jun 16, 2010 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
My scale is now set on pounds. I would lik to change back to Metric
Oct 18, 2009 | Tanita 2204 Body Fat Scale
Tanita 2204 Scale weight reading problems
Try the following steps:
1) press both the "set" and the triangle button
2) press the triangle button until you get the desired unit of measurement: a) Kilogram, b) stone lbs or c) lbs; and
3) press the "set" button.
Nov 16, 2008 | Tanita 2204 Body Fat Scale
Print workshop 2004
I didn't realize there is a print workshop 2204. Do you mean Broderbund's Printshop version 22?
Yes, this should work okay with Windows Vista.
Many older programs will work fine with WinVista, they were just not written to take advantage of the OS features.
Mike
Nov 13, 2007 | ValuSoft Print Workshop 2003 for PC
Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer Logo
176 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
