Question about HP Photosmart R707 Digital Camera
HP R707 camera
My HP R707 5.1 camera lens is stuckout and will not go back in or out when powered on. It only makes a beep sound and turns off automatically.
  • nick_deyulis Jul 17, 2008
    same thing happend to me
  • fablis Sep 09, 2008
    Problem Solver:
  • 13 Answers
Turn your adapter on your camera and then power it up,, then everything will be fine,,, i had the same thing,, and i figured it out by accident,, hope i helped ya,, ( so put the tiny adapter piece next to where u put the usb in)
Posted on Oct 19, 2008
Posted on Sep 09, 2008
2 Suggested Answers
  • 13 Answers
SOURCE: HP R707
get the adapter plug it in,, in the camera that little hole next to the usb,,, just like u will charge the battery, then turn the camera on,, just your camera lens will be back to normal,, hope i helped ya out.
Posted on Sep 30, 2008
I have a HP camera, when i turn on the camera the lens want come out.
Try to run self-diagnostics tests - press flash button while switching the camera on.
Jan 17, 2010 | HP Photosmart R707 Digital Camera
Zoom Lens stuck out, won,t close. Says camera problem #E45
that error code indicates the the Lens of teh camera is already defective., In most cases if the lens is stuckout or stuckin camera will not stay On or It will not Turn On at all. For this case you need to call Tech support to send you camera for repair toll free 1 800 235 6325 extension 12
Nov 12, 2009 | Kodak EasyShare V530 Digital Camera
Lens stuc and makes beep sound
I had the same problem and my brother just wiggled the lens shut carefully while turning the power on at the same time , it took about 5 tries and finally had the lens was all the way back in place and it works great.It was just the lens was stuck open and would not start up like that I guess. better then junkin it.
Sep 01, 2009 | Samsung BL103 Digital Camera
Three beeps when i try to turn it on
i had the same problem a while back. I fooled around with my camera lens a bit and it turned out that one side of the lens was sticking out a bit. I pressed down on this and pushed the power button and it worked. The next time I turned it on the same thing happened but if you keep doing the same thing it should work.
Hope this helps!
Aug 21, 2009 | Samsung L100 Digital Camera
No power after dropping it accidentally...
try pushing the reset button by the battery slot, use a paper clip and hold for 5 seconds without the battery in it. good luck
May 10, 2009 | HP Photosmart R707 Digital Camera
Missing rubber cover for HP R707 Digitol Camera
Please go to this link for an online manual for your camera, by clicking here.
You will find that it includes an appendix B with links to HP accessories and online shopping for HP products.
If you have no luck there, I suggest you contact HP support directly (www.hp.com/support) and make a request by including the model number of your camera and the part number. (Found by looking here)
and possibly here.
Finally, you might have best luck trying to resolve this with a live person on the hp phone support line.(see user's guide for local numbers)
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Mar 27, 2009 | HP Photosmart R707 Digital Camera
R707 lens open, lcd shows hp, beeps, then turn OFF
Try to reset the camera - remove the battery and press the reset switch for about 5 seconds. Reinsert the battery. If it works while connected to the charger, your battery needs to be replaced.
Feb 22, 2009 | HP Photosmart R725 Digital Camera
Cracked screen
Cracked screens in the r707 is easy replacement. I just tend to swap screens from another r707 that has a lens issue. I have noticed that there is two types of LCDs in the r707 camera. One is easy type to replace because all it has is a serial cable that is attached circuit board. The other is a little harder because it has, besides the serial cable, two additional wires that are soldered to the board. The lcd is actually attached the black half of the camera's case. You will have to remove all of the screws and then remove the front (metallic) half of the camera. There are two cables that attached the camera circuit board. One is the LCD and the other is button/SD flash board; both of which are attached to the back half of the camera's case. Remove the back case and swap out the LCD and reattach everything in the reverse order of dissassembly.
Nov 26, 2008 | HP Photosmart R707 Digital Camera
HP R707
Sep 11, 2008 | HP Photosmart R707 Digital Camera
Hp r707
Aug 10, 2008 | HP Photosmart R707 Digital Camera
HP Photosmart R707 Digital Camera Logo
121 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
