Question about GE PDS22LBN Bottom Freezer French Door Refrigerator
Freezer setting I'm trying to set my GE upright freezer to a colder setting. Which direction should the dial go? It was on 3. Should it go towards 5 or 1? CA 21 SMB RWH Laura
Sea Breeze
  • 4655 Answers
SOURCE: Refrigerator suddenly not cold, freezer seems fine.
Sometimes this happens when the control board located on the back is defective. The board part number is WR55X10656
Visit my web page below and enter the model number GSS22JFPCC into the search feature. We also offer free assistance and help for the problem you mentioned. Click on link below, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Posted on Mar 29, 2009
SOURCE: GE GSS25WGMCC, Ice Forming On Freezer Interior Surfaces
i had the same problem and i replaced the defrost heater and it worked fine for about one month but now having the same issue. Most of the time from what I have heard it is the defrost heater (about $60 part). I might have another issue going on with mine like a defrost thermostat. Your defrost heater is right under the panel on the inside of the freezer section. remove white panel on back side of freezer section and remove two screws and two wires and replace it and you should be fine.
Posted on Apr 25, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Freezer at 21 degrees , refer at 44 degrees, will
If your model number is the Profile/Artica PSS26 model the most likely reason for this is a burned out defrost heater. Look into back of the freezer and tell me if a layer of frost is building up on the rear wall of the freezer compartment. If yes then unplug and remove the rear panel in the back of the freezer to expose the evaporator coil. If frosted over then you need to defrost with a hair dryer or leave a bucket of hot water in the freezer compartment until the ice melts away. Sometimes the defrost drain is frozen over and then the beginning of the frost becomes heavy quickly and temperatures begin to increase in both sides of your side by side. Lately I seem to be here and ge no response from anyone. I want you to a the least let me know if you need my help to resolve this. Sometimes the main control board causes this but not as likely as the defrost thermostat and defrost heater. Sea Breeze
Posted on Sep 05, 2009
marka19
  • 1430 Answers
SOURCE: GE bottom freezer began making a clicking noise, will not run
The clicking could be the start relay.If the start relay is bad, the compressor will not start and you will hear a clicking noise in 2-5 minute intervals. The clicking noise is the overload cutting the compressor off when it overheats from trying to start with a bad start relay. To find out if this is bad first unplug the refrigerator. Remove the lower cover from your refrigerator. Then take the cover off that is on the side of the compressor,you will see wires going to this. Now you should be able to see the start relay plugged on to the side of the compressor and unplug it. Now the best way to tell if it’s bad is to shake it. If it rattles, it’s bad and needs to be replaced. If not, most of the time it’s ok. But rather than saying the compressors bad, you might want to replace it anyways because it don’t cost much in most cases (less than $25). If you replace it and it doesn’t work then the compressor is bad and you’ll need you call a repairman. (Note that compressors are very costly and are normally not worth fixing). You can also enter your model # at www.appliancehelponline.com for diagrams and illustrations.
Posted on Apr 09, 2010
aasc
  • 1606 Answers
SOURCE: My GE Adora freezer section constantly gets down
I would advise replaceing # 4 AND # 5 thermistor . The # 4 , tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils ( remove the inside rear freezer panel ) , with 2 white wires going to it . Part number WR55X10025 for both . The # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off due to selected temperature .
Posted on Jun 13, 2010
How does thetemperature dial on upright phillips freezer work
Usually 6 would be the higher (colder) setting.
Aug 14, 2014 | Refrigerators
Setting tempture
Turn the temperature control in the direction furthest away from the off setting.
Nov 19, 2013 | Magic Chef Freezer. 8.8 cu. ft. Upright...
What is the normal temperature setting for a ge upright freezer, dial from 6 to off?
Your need to use a thermometer and adjust the dial till you have between 0 and 10 degrees.
Jul 10, 2011 | GE 20.3 cu. ft. / 575 liter Upright...
Is the dial to adjust temp coldest set at low numbers or high number?
The dial inside the fresh food compartment, the bottom compartment
set to middle or above (higher numbers mean colder). Usually 5 to 9 if it has numbers.
Freezer knob in the middle if it has one. (If you set a freezer knob to "colder" it cuts
off the cold air to the lower compartment). Hope this helps
Jun 29, 2011 | Kenmore Top Freezer Refrigerator
Refrigerator less than two months old. Freezer side fine refrigerator side stopped working altogether. All food ruined. Who should I contact. purchased from Home Depot.
This is a very common issue, If the freezer compartment is cold and making ice the
problem is simply airflow from the freezer into the refrigerated section.
Typically when one senses the refrigerator is warm they max out the settings
on both dials the thermostat with its 1-10 settings as well as off for the compressor.
This controls the compressor and temperature.
The additional setting or dial is for colder freezer or refrigerator as well , However
it simply opens or closes a flapper door between the freezer and refrigerator boxes.
When that dial or setting is maxed , it closes and makes the freezer colder, yet leaves the refrigerated section starved for sufficient airflow to maintain a cold box in the refrigerated section.
Just set the dial that does not turn the compressor off to the middle setting.
One can leave the thermostat that does control the compressor in the max setting , just not the colder freezer setting, If you notice colder isnt colder refrigerator, Its actually colder freezer, A common issue found on 25% of all refrigerator calls a simple setting adjustment.
Its easy to think that maxing out the settings makes for a colder refrigerator, it doesnt, it makes a colder freezer and warm rerigeration section.
If a freezer is making ice, theres nothing wrong with the unit other than airflow setting.
Add a comment
Dec 24, 2010 | Maytag Refrigerators
My GE TFX30PP is constantly running and doesn't turn off. The freezer is very cold but the frig side isn't cold enough. A repair guy put in a new "cold contol" sensor but it didn't help.
I would also clesan the condenser coils off.
Add a comment
Dec 24, 2010 | GE Profile Performance 29.8 cu. ft....
Temperature control
I have a danby mini fridge and freezer and noticed the same problem. The temperature dial has NO NUMBERS ON IT! it just has a strip that goes from light to dark blue. That's it. I looked in the manual and it doesn't say anywhere which way is colder...it makes sense that the darker the blue the colder the temperature but why keep us guessing?
Mar 15, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
GE PDS22LBN Bottom Freezer French Door Refrigerator Logo
52 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
