I have a brand new Linksys 54g router (WRT54g) I have this plugged into my switched 10/100 lan, all the wired PCs on the LAN can see it (3 PCs) my laptop wireless with a linksys 54g PCMCIA card can also see it and all the other PCs (file browsing etc.) All the PCs run XP, the main PC has an ADSL connection which is shared using ICS and all the PCs can browse the Internet fine, except the laptop with its wireless card installed although it can see the ADSL connection!
Any ideas as I am pulling my hair out now!
BTW I have flashed the firmware on the router to the latest version, and completely reinstalled the networking on the main internet gateway and the laptop.
Try setting the default gateway on the laptop to the ip address of your ICS gateway machine. Some routers separate the wireless and LAN connections on different subnets.
Try comparing your laptops ip information with that of one of the working wired computers. You can do this by going to Start up to run and type cmd then click "ok"
At the black prompt screen type "ipconfig" without the "".
You want to compare the IP Address, Submet Mask, and Default Gateway.
If one has an ip of 192.168.1.* and the other has 192.168.0.* then the wireless and wired are on seperate networks.
If the subnet masks are something like 255.255.255.0 and 255.255.255.1 they are on seperate subnets. Both should be fixable by putting in the same default gateway.
For example if your ICS gateway is 192.168.1.1 then set that as the default gatway on the wireless laptop. This can be done by going to start >> Control Panel >> Network Connections then right click your wireless connection and goto properties then double click on the "Internet Protocol (tcp/ip)" option. This will list all of your ip information (if its static) if its dynamic (ip gotten from router) you can still click "Use the following DNS server address" and set preffered dns to the gateway ICS ip. Or click "Advanced" and click Add under Default Gateways and add the gateway ICS ip there.
Was this solution helpful? Show your Appreciation by rating it:
