Question about Refrigerators
Refridgerator water odor
Hello and thanks for your service!
My kenmore elite refridgerator developed a problem that the water and ice that comes from it smells like rotten eggs or something. This might have developed during a time I was not using the water despenser much due to not getting a water filter for it. It's like the water lines inside the refridgerator developed a mold or something in them. After putting a new filter in it the smell was gone for about 2 weeks but is now back again. It's like the mold grew through the filter. Help!
Hal
  • hal_fisher Jun 20, 2008
    This smell does not come from the primary water line and is still present a few weeks after a new filter (long big one) is installed in the fridge. It actually smells like Halitosis. I mean so much so that it is probably the bacteria that is causing it. I guess the only fix is to replace all the lines, filter, and pump in the fridge.
I think I fixed the smell problem. Of course it may come back in a few weeks but what I did was I used a large syringe filled with vinegar and pumped that through the lines. I was able to get a really good seal using just the plastic tip of the syringe pressed really hard against my abdomine while I used the water despenser to let the pressure go through the line. I left the filter in because I think the bacteria had contaminated it as well. I kept refilling the syringe and pressing it into the fridge's water line and running the water dispenser at the same time until I got about 10 oz of vinegar in the lines. At that point I could taste the vinegar coming out in the water. I then ran out of vinegar (oops) so I started waiting till I could drive to get more vinegar but gave up after waiting over 1.5 hours (I had a reason why I could not just go and get more). At that point I was kind of worried I might pickle the lines and never get the taste of vinegar out so I reconnected the water lines and flushed the vinegar through (about 2,5 gallons). It seems to still be good tasting after the second day so at least I know the vinegar kills that bacteria, just not sure if I got enough vinegar through to completely fill the lines (it only tasted a little like vinegar when I ran out). I don't think a plumber would know to try this.
Hope this helps others.
Hal
Posted on Jun 21, 2008
  • hal_fisher Dec 08, 2013
    I used WHITE vinegar which is much stronger then the apple cider type. Also, this problem never came back, this fix it!
Where do I connect the water hose in the back for the refridgerator
what kind of water hose.this ice maker should fit 3/8 cut off value and sit in the back at the bottom
Oct 16, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refridgerator is warm, freezer is freezing
Defrost problem. Most likely the defrost heater or defrost thermostat.
Jul 02, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My ice maker on the freezer side door stopped working so I changed out the motherboard CCA in the back of the refridgerator & it started working again but the water did not. I need to replace the...
Blake are you talking about the dispenser control board? The ice maker tells the water control valve to come on for the preset amout of time to refill the ice trays most times about 7.5 seconds. and filling ice maker with tap water will test icemaker. If water freezes and the ice dumps the signal is sent to the water control valve Click here=> WR57X10050 here is a service manual=> PROFILE ARTICA SERVICE MANUAL CLICK HERE Have questions you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, Thanks, Sea Breeze
Jan 22, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Water in Leaking in the Freezer
Hi, this sounds like a problem with a blocked drain. For full instructions on clearing the blockage from my tips click HERE if you have any other questions please feel free to comment. Mike
Dec 21, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Doe's not defrost into lower drain pan.
Your drain line is clogged, just clean it out and you should be fine
Jun 26, 2017 | Kenmore Refrigerators
Mildew smell coming from bottom front of refridgerator.
Carefully empty the drain pan under the fridge and empty it.
Then clean with a bleach and water solution.
Feb 22, 2009 | Hotpoint HTM17BBSSA Top Freezer...
Hello? I have a new Eclipse Kenmore being installed Tuesday 12/23. What do I need to provide for a water supply?
I see your installation date has come and gone, but if you still need to hook up the water you can find an "ice-maker kit" from almost any home improvement store (such as Lowes, Ace, Home Depot etc....) This includes 1/4" bendable copper tubing and a valve that will tap a near by cold water supply pipe. If you find a kit with plastic tubing, I would steer clear and find the bendable copper. Plastic tubing kits are notorious for springing leaks. Buy some extra compression nuts and washers for the tubing while you are there, it may take more than one try to get a waterproof seal if this is your first time hooking up water and ice dispenser.
When hooking up the tubing to the back of the refridgerator, leave a couple coils of slack to allow the refridgerator to be pushed in or pulled out without straining the connection. There is usually a small clamp on the refridgerator back to hold the tubing steady, make sure you use this. This will help ensure a leak free connection. After you have the tube hooked up, push the refridgerator all the way back, then pull it back out and check for leaks. Sometimes the tube will start dripping a bit after the refridgerator is moved, so this step helps ensure you won't have leak problems.
Dec 22, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
343 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
