Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Green vertical lines
My Sharp "LC-42D62U" periodically (but now for an extended period) displays green and red vertical lines across the screen regardless of whether the TV, satellite, or DVD is being watched.
  • portagent Oct 07, 2008
    my sharp lc-45gd7u is almost 4 years old now and recently notice several horizontal and faint vertical lines across the screen. To count there are probably about 60 x 1.5 inch little bars every where.
    It is hooked up to a Denon AV reciever but switched it to dish direct and same result.
    What gives?
    thanks Louis
    Problem Solver:
  • 14 Answers
Possibly needs a new control circuit board or lcd panel
Posted on Jul 25, 2008
What are the thin vertical black lines on my screen?
Bad LCD Panel very expensive to fix. if it is under warranty or if you bought an extended warranty use it to have the set fixed.
Jun 29, 2014 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-40C32U: Black screen, various vetical colored lines for extended period after turning tv on (volume button changes appearance of vertical lines)
Sounds like panel fault. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Screen-shots do defective LCD panel are given. You can see and compare it to that of your TV's.
Apr 21, 2014 | Sharp Aquos LC-32D40U Television
Threw something at flat screen tv
Could be dust on a circuit board...blow out the insides with clean air. If not, you can't fix it yourself...internal problem for expert!
Dec 26, 2012 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I have a sharp acquos 42 inch lcd tv, which has worked flawlessly for about two years but, is now starting to show vertical lines that are green and sometimes they turn kind of red. They seem to appear...
The way the symptom was explained, the problem is with the LCD panel itself. Lines on screen are cause by some factors such as tft's or the control flexible contact that attached to the panel might become loose overtime, the flexible can be repaired but not at service station level. You will need to visit authorized sharp service station to have a look and get concrete diagnosis. they can decide whether the lines are repairable or not.
Jul 02, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My 52 inch sharp aquos has green and black vertical lines across the entire screen
Try different source like VCR, DVD, or satellite to see if it is the source thats bad.  Check to see all your connections are on good and tight.  If still no luck, then your tele is fu.k.d and you got bad LCD crystals or faulty inverter.  Take the thing back to the store for exchange or refund if your within your 30 day window.  Call the manufacturer if your within your 1 year window.
Oct 30, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Black horizontal line, red parallel vertical lines
REPLACED LCD PANEL
Manufacturer Sharp Part Number RF-R1LK420D3LF2 Description 42" WIDE LCD PNL -
Sep 28, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Shadowy lines
sharp has a problem with this model-try to turn the contrast down to cover up
or you can contact sharp-good luck they will not support their own product
next time you buy a tv get the extended warranty-there is no more quality in todays tvs
sorry for the bad news
Sep 02, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Westinghouse LCD TV - broad vertical green and blue lines
try to go to the factory reset and see if that helps. If not, you can then check your connection. if you use component (red, green and blue for video and red and white for audio), make sure all the color matches when you plug it in. if everything have been checked then you need to replace the main board and it should correct the problem.
Jun 22, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I have a sharp aquos 52" with a thin vertical red line in center
If you have a thin line running down the screen, you may be looking at a service issue right off of the bat. Here is a few things I want you to try before calling sharp, 1. Reset the unit from the setup menu
2. Unplug the unit for 2 minutes then plug back in. If that does not work. Take digital pictures of the line and call sharp immediately. Make sure you tell the rep you want to sign up for the aquos advantage program that they have(extends your warranty 3 months free of charge!) because that will get you priority service on with your issue. If they cant resolve that line ,9 times out of 10 they will replace the unit. hope this helps you
Feb 15, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Green vertical line on the right side of screen
Warranty still alive?
Hope so; the problem could be an expensive one.
The screen appearance is controlled by allowing light from a backlight through by turning pixels off and on.
This switching is done by a matrix that turns on vertical and horizontal pixels of the right shade at the right time to produce the image you see.
One of the control elements for the vertical that controls the transmission of green light from the backlight, has died (no longer switching off and on when told) and these are normally a part of the LCD screen assembly itself and not easily replaceable.
I would be talking to Sharp - this shouldn't happen in 6-7 months of use.
Jul 09, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
1,945 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
