Question about 2wire 1800HG Router (RG1800HG00)
Router i don remerber my password on my router i forgot my password
  • 689 Answers
If you are talking about Router's system password, You need to go to Router's interface go to system > password, Choose password reset enter the system key which located below the barcode label and new password.
For details you can use link below
http://www.2wire.com/pages/pdfs/2Wire_1000_User_Guide.pdf
Good Luck
Posted on Jun 20, 2008
    Sergeant:
  • 320 Answers
2wire routers are usually owned by your ISP, you may try calling them. Otherwise you can do a reset on the router putting it back to factory settings. On the back usually next to the power plug their is a small button that can be pressed in by a pen/pencil/paperclip.
I would strongly recommend calling your Internet Provider first to make sure so you don't wipe out any settings.
I forgot the password of my router, Sagem F@st 2804 anyone on how to access again or reset the old password?
There is a button on the back of the router, it is inset and u need a pen or pencil to engage it. It's the factory reset, it will set the router to the factory settings. That means the password resets too. Then if u don't have the factory password google is your friend.
Aug 18, 2012 | Computers & Internet
Forgot user name and password
If you can't remember the UID and PW for the router's web interface, you will need to do a hard-reset on this. Hold the reset button (back of router) down for about 5 seconds and then let go. Allow the router to reboot itself (don't unplug it while it is doing this).
Now the UID is blank and the password is "admin".
I hope this helps!
Sep 24, 2011 | Linksys WRT120N Router
I set up wifi network in my home and forgot the password I used to set it up. Is there any way to recover that password?
Unfortunately, no. The only way to access your network again is to reset the router by holding down the reset button on the back (you might need to unplug it, then plug it back in while holding the reset button). That will reset your web interface (navigate to 192.168.1.1 in your browser while connected to the router)'s username and password to some form of the following:
Username: admin
Password: admin
Username: admin
Password: password
Username: admin
Password:
NOTE: The last combination is a blank password.
Once you've entered your router's web utility, you can set up your wireless again. Don't forget to write down the password...I wrote mine on the router itself, because honestly nobody can see it because it's in my house, so I don't have to worry about it being stolen.
Jul 27, 2011 | Linksys Wireless-G WRT54GS Router...
Forgot password and user name
Go to the router and reset it.
To reset it, press and hold the reset button on the router for 30 or more seconds.
The default username is admin, and the password is admin. To configure settings for your router, visit 192.168.1.1. on your browser.
Please don't forget to rate my solution, thanks.
Apr 30, 2011 | EnGenius Computers & Internet
Cannot set password at IP address provied. says authentication required. Help set up router per directions
Hi!
If you've forgot (or don't know) the password for your router, reset it by pressing the Reset button on its back (next to the antenna) for 20 seconds. Allow it 2 minutes to fully restart itself.
Afterwards, go to 192.168.1.1 and login using:
Username: admin
Password: password
(all lower case letters)
Refer to the User's guide to reconfigure your router; refer to page 6 and on...
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Best regards,
Pelu.
Apr 24, 2011 | NetGear WGR614 Wireless Router
I don,t have a password or username to setup my netgear rangemax wireless n wnr834b
well if you forgot the username and password then reset the router for 20-30 secs pushing the reset button. powercycle the router for 10 secs. then open the router page>
-- http://192.168.1.1 or http://www.routerlogin.com or http://10.0.0.1
-- username and password is " admin" and "password"
-- Left side click on Setup Wizard
-- Apply basic settings
-- go to wireless settings
-- change ur wireless settings according to ur need
-- and apply all the settings.
and try to connect all the wireless computers
Apr 07, 2010 | NetGear RangeMax NEXT WNR834B Wireless...
I don remerber my password on my router
Press the reset button behind the router and do the configuration once again.
Dec 30, 2009 | MSI Wireless-G RG54G3 Router
Forgot password
Just reset the router from the small hole at the backside of the router and you shall be fine but all the information ill be lost..
Jun 28, 2008 | Linksys Wireless-G WRT54G Router
Forgot security password
Save slight model differences between the different OfficeConnect routers, the procedure to do a factory reset is like this (from memory, for exact details you have to find a manual)
- power off the unit and remove all cables
- connect a normal (straight) network cable between the WAN port and either of the four LAN ports
- power on and wait until the status led is beginning to blink slowly, like 30 seconds
- then power off, reconnect everything and power on again
After this procedure you will have to input all settings from the very beginning, the default password is admin if I recollect correctly.
Jun 06, 2008 | 3Com OfficeConnect Wireless Router
Router
Chechy,
The routers I have had will default to the factory password if you press and hold the reset button in for a while. On the linksys brand it defaults to ADMIN. Lookin the manual for your router and looker for RESET and you may find something similar to this in the instructions. If you don't have them you can find them on line.
Let me know if you need more help.
Dec 17, 2007 | Computers & Internet
2wire 1800HG Router (RG1800HG00) Logo
131 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
