I try to format my per drive and his 60GB red color but is not formatting and when i format it with FAT it format but not working well. I need help on how to format it.
  • 197 Answers
If you have your OS cd sometimes you can format from that
Posted on Jun 20, 2008
7.9 gb file too large for empty 16 gb flash drive
U probalby is using windows XP or something like that wich can only format ur pendrive as "FAT" file system wich have max 4GB capacity per file, in order to fix your problem you need an external software for formating ur pendrive or use win 7 if you have win 7 just backup your data and format the pendriver and where it says " File system" will come with "FAT" as standard just click and select "NTFS" format it and be happy^^
Nov 12, 2012 | Computers & Internet
I have a maxtor one touch 4 1 TB and I used it for a PC w windows 7. Now I have an apple computer and want to format it so I can read both pc and mac
FAT 32 format can be accessed by both pc and mac. the drive should be already Fat 32 formatted, but still, the files stored from the mac will not be able to be read by windows and visa versa in most situations.
you will run into trouble if you have to fat 32 format it yourself, as windows will only format up to 32 gigs of it in fat 32- you will have to make multiple 32 gig partitions to use the entire drive, and would be unable to keep more than 32 gigs of info per backup or folder, bacause of all the seperate partitions.
Nov 30, 2010 | Computers & Internet
Cannot format octagon veridisk T118 usb
Try this
Microsoft Windows 95, 98, ME syntax
Formats a disk for use with MS-DOS.
FORMAT drive: [/V[:label]] [/Q] [/F:size] [/B | /S] [/C]
FORMAT drive: [/V[:label]] [/Q] [/T:tracks /N:sectors] [/B | /S] [/C]
FORMAT drive: [/V[:label]] [/Q] [/1] [/4] [/B | /S] [/C]
FORMAT drive: [/Q] [/1] [/4] [/8] [/B | /S] [/C]
/V[:label] Specifies the volume label. /Q Performs a quick format. /F:size Specifies the size of the floppy disk to format (such as 160, 180, 320, 360, 720, 1.2, 1.44, 2.88). /B Allocates space on the formatted disk for system files. /S Copies system files to the formatted disk. /T:tracks Specifies the number of tracks per disk side. /N:sectors Specifies the number of sectors per track. /1 Formats a single side of a floppy disk. /4 Formats a 5.25-inch 360K floppy disk in a high-density drive. /8 Formats eight sectors per track. /C Tests clusters that are currently marked "bad." Microsoft Windows 2000 and Windows XP syntax
Formats a disk for use with Windows 2000.
FORMAT volume [/FS:file-system] [/V:label] [/Q] [/A:size] [/C] [/X]
FORMAT volume [/V:label] [/Q] [/F:size]
FORMAT volume [/V:label] [/Q] [/T:tracks /N:sectors]
FORMAT volume [/V:label] [/Q] [/1] [/4]
FORMAT volume [/Q] [/1] [/4] [/8]
volume Specifies the drive letter (followed by a colon), mount point, or volume name. /FS:filesystem Specifies the type of the file system (FAT, FAT32, or NTFS). /V:label Specifies the volume label. /Q Performs a quick format. /C Files created on the new volume will be compressed by default. /X Forces the volume to dismount first if necessary. All opened handles to the volume would no longer be valid. /A:size Overrides the default allocation unit size. Default settings are strongly recommended for general use.
NTFS supports 512, 1024, 2048, 4096, 8192, 16K, 32K, 64K.
FAT supports 512, 1024, 2048, 4096, 8192, 16K, 32K, 64K, (128K, 256K for sector size > 512 bytes).
FAT32 supports 512, 1024, 2048, 4096, 8192, 16K, 32K, 64K, (128K, 256K for sector size > 512 bytes). Note that the FAT and FAT32 files systems impose the below restrictions on the number of clusters on a volume:
FAT: Number of clusters <= 65526 FAT32: 65526 < Number of clusters < 268435446
Format will immediately stop processing if it decides that the above requirements cannot be met using the specified cluster size.
NTFS compression is not supported for allocation unit sizes above 4096.
/F:size Specifies the size of the floppy disk to format (160,
180, 320, 360, 640, 720, 1.2, 1.23, 1.44, 2.88, or 20.8). /T:tracks Specifies the number of tracks per disk side. /N:sectors Specifies the number of sectors per track. /1 Formats a single side of a floppy disk. /4 Formats a 5.25-inch 360K floppy disk in a high-density drive. /8 Formats eight sectors per track. Microsoft Windows 2000 and Windows XP recovery console syntax
format [drive:] [/q] [/fs:file-system]
drive: Specifies the drive to format. /q Performs a quick format. /fs:file-system Specifies the file system to use (FAT, FAT32, or NTFS) Examples
When using the format command, remember all information on the drive you wish to format will be completely erased.
format a:
Would erase all the contents off a disk. Commonly used on a diskette that has not been formatted or on a diskette you wish to erase.
format a: /q
Quickly erases all the contents of a floppy diskette. Commonly used to quickly erase all information on the diskette.
format c:
This would erase all the contents of your C: hard disk drive. In other words, unless you wish to erase all your computer's information, this command should not be done unless you're planning to start over.
Or
Right click My Computer-->Manage-->then go to Disk Management
and select the to format right-click it and click format. Thats it Your drive will format and You can also choose in which file system you want to format your drive.
For further help or to thank me mail me on my email ejaz89@live.com
Aug 06, 2010 | Computers & Internet
Formatted and installed a WD 60gb hd as slave and is not detected
Did you format this drive to NTFS or FAT32. It may not rcognise it as a slave drive on a format other than NTFS
Apr 11, 2010 | Western Digital Caviar WD600BB 60 GB Hard...
When I am put my 8 gb Transcend usb deive into pc, the message come ''u need 2 format the disk in drive I:b4 u can use it'' ,ten I click on format disk, a message come ''windows was unable 2 complete the...
First I would advice to try to format it via disk management.
Second is try to format via CMD menu.
ok
try this.
To open disk management go through:
Control panel>administrative tools> computer management> then disk management on the left> then right click and format fat file system or as per to your convenience...
Mar 19, 2010 | Transcend 8GB SSD, 2.5- Inch, IDE, SLC...
Iomega fat 32 formatter program does not allow me
If you really must have fat 32 (maybe for MAC use ?) then windows itself does not support doing a fat format on large drives.
However there is a fix Yup thats why they call it FIXYA
Here is a link to just what you need
Hope its what you need and good luck
Nov 20, 2009 | Iomega 250GB Ego Portable HD Red 250 GB...
Cannot format Removeble Disk
even i have similar problem.
I tried following command from command prompt:
format F: /FS:FAT /Q /X
and it worked.
where:
format => command to format drive
F: => drive name
/FS:FAT => command to use FAT file system
/Q => to perform a quick format
/X =>dismount the voulme forcefully
Jul 30, 2008 | Electronics - Others
Pioneer HU UB Series Power Shortage (Pioneer DEH-p5000UB)
Could be that your Passport is NTFS formatted - the Pioneer units will only read FAT 32 formatted drives. Mine is working great with a 60GB drive.
- SM
May 29, 2008 | Pioneer Car Audio & Video
Can not convert it to fat or fat32 file system
Using disk manager, try to delete the partition. Then start over again.
Hope that helps...
Geno
Feb 27, 2008 | Seagate (9W2892-337) 80 GB Hard Drive
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
