Question about Kenmore 22812 Bagged Canister Vacuum
Need to twist hose to keep power on
When vacuuming, the power doesn't stay on. To keep it on, we need to twist the hose at the point where it enters the handle assembly to keep it turned on. Any suggestions? I took the handle assembly apart as best I could, but I didn't see anything obvious that was frayed or disconnected.
  • 2,326 Answers
The loose connection will be internally and in some cases is not detected visually.
Do you have any connector where they connect together?
Posted on Jun 20, 2008
    Brigadier General:
  • 3,614 Answers
You must changed the wire it could be damaged that why the power eventually cut off..
How do you unclog the back of vacuum?
Yes you need to remove the hose and while you are at it you can clean other parts of the vac too
Dec 14, 2017 | Hoover S3410 Spirit Bagged Canister Vacuum
The hose at the bottman keeps coming out so im left with no suction
I'm sorry to hear you're having difficulties with your DC14. If the internal hose isn't staying in place, please follow the steps shown in the video below to make sure it's correctly attached at both ends.
If this doesn't resolve the issue, please call us on 0800 298 0298 (UK), or 1-866-693-9766 (US), so we can provide further assistance.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Mar 26, 2012 | Dyson DC14 All floors Bagless Upright...
Was using vacuum and sock is now lodged in vacuum hose. How can I get the sock out?
The easiest way to remove an article of clothing from the hose is to remove one end of the hose from the vacuum, and reach in with a piece of wire with the end bent into a hook. A wire coathanger will work well for this. Just straighten out the coathanger, take a pair of pliers, and put a small bend at the end of the wire, in a J, or hook shape. Then, reach the wire into the hose, and when you feel the obstruction, twist the wire, so that the hook gets stuck on the sock. Then, pull it out, and reattatch the end of the hose back on the vacuum.
It doesn't matter which end of the hose you remove, just whichever is easier, and hopefully closest to the clog.
Do not try to push it out, as it will just bunch up tighter. It must be pulled out.
Jun 17, 2011 | Kenmore 31913 Progressive Direct Drive...
Power brush keeps going off and on ,when off i keep pressing red button and switches on ...stays on if you keep it up slightly and not fully down
Just had the same problem. Took apart whole power head to look for broken wire and found none. If you see part way up the hose there is a coller with 4 torx screws holding together. This collar is a swivel that allows the hose to spin without twisting or kinking. Take the 4 screws out and open up. You will see 3 contacts that look like fingers that rub on 3 mating steel rings. Wipe the tips of the fingers and wipe clean the rings. Gently bend the fingers out wards so that they apply more pressure to the steel rings. Reassemble and try. Should take no more than 15 mins. Worked for me good luck!
Jan 06, 2011 | Dyson DC15 All Floors - The Ball Bagless...
When I vacuum with the power nozzle, it keeps cutting off. Do I need to replace the hose or the power nozzle?
Not necessarily. It's hard to tell without checking it out. I strongly recommend taking it to an authorized Aerus Electrolux store and letting the service tech check it.
If you have the "Sidekick", you can try using it. If it still cuts out, it's the hose. If not, the wiring in the power nozzle is loose or worn and needs to be replaced.
Keep in mind that you may not need to replace the hose or power nozzle, just have some wiring repaired.
Nov 07, 2010 | Electrolux Epic 6500 Vacuum
Electrolux central vaccum works sporadically
The the hose, wands and power nozzle to the nearest AERUS store for repair. You have a short that needs to be fixed. They should just be able to replace the wire assemblies inside the wands, handle and power nozzle.
Jun 09, 2010 | Electrolux Central Vacuum
Canister vacuum keeps turning off, can push buttons on wand handle to restart but shuts off again as soon as you start to move handle
its sounds like the problem is either the power head wire which when your using it and twisting it left and right, turns it off.. Or it could be in the hose where the connect meets with the unit.
Here's a number to call to further assist you. 1-800-322-2965
Aug 14, 2009 | Miele S548 Bagged Canister Vacuum
My VAX Vacuum has lost ALL suction power. I've
vax power pet 1 filter keeps getting clogged up so dirt not going into cylinder
Jul 05, 2009 | VAX Appliances Vax X5 Bagless Upright...
Kenmore 22812 Bagged Canister Vacuum Logo
64 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
