Question about Frigidaire FDL45P1 Dehumidifier
Figidaire 25 pint dehumidifier
I have he unit set up to run continous. water runs out the hose but the tank also fills. when its full the light comes on and it shuts off. what am i doing wrong. tried removing the tank and running it, but it soon shut down and the full light comes on again.
  • 828 Answers
Check the point on the tank (Bucket) where the hose connects to. Make sure there is no obstruction at the outlet of the bucket to the hose connection. Next make sure the hose has no kinks or no loops that may trap air to the drain. If necessary for a long run to the place of drainage raise the dehumidifier to a higher level for better drainage.
Posted on Jun 29, 2008
How to make unit drain through hose, instead of filling bucket?
Assuming you have a hose connected to the bucket for drainage, it is necessary that the end of the hose be lower than the top level of the bucket or the bucket will fill before the hose drains. I see many people who have their units on the floor and run a hose up into a sink and wonder why the bucket fills. Gravity works.....if you cannot find a lower place to drain the water then you must raise the unit up on a table or stand of some sort to get the bucket higher than the drain.
Sep 16, 2015 | Friedrich 25 Pints Dehumidifier 115v power...
The dehumidifier drain hose does not drain when a hose is connected properly and is set at ``Continous Run``.The light on Continous setting is orange,is this normal? Raymond Benoit
http://www.searspartsdirect.com/partsdirect/part-number/Whirlpool-Parts/Dehumidifier-Parts/1172075/0042/106/Model-AD25BBK0/1198/0907000?keySuffixId=NA&productTypeId=x&searchModelNumber=AD25BBK0&subCompDesc=Cabinet&brandDesc=WHIRLPOOL&modelDesc=DEHUMIDIFIER&blt=11
I would suspect the float first, IF the unit is level. But it could also be blocked with gunk and you will need to check the drain holes. I have always found a guitar string is an affective clean out of drain lines and holes.
The orange light indicates that your bucket is full, so if it isn't then it is most likely the float above.
Jun 19, 2011 | Whirlpool AD25BBK Dehumidifier
Hello, I need a dehumidifier of 50pint or more that stop when the humidity level is reach and will restart when is too high. I look for a lot of brand and model and I cannot find one thanks for your...
The fifty pint capacity might be a challenge ... think about this ... 6 + gallon tank @ 7+ pounds per gallon ... 42 pounds of water to drag from the dehumidifier to the drain? Who is going to do that?
All dehumidifiers run at some % of humidity (via Humistat), (like you are asking about) i.e. come on at some % above the setting and go off when the setting is reached. I suggest you find one that has a standard one or two gallon tank that also features a hose connection in the tank. Run the hose from the tank to the floor drain in your basement or a drain near what ever room you are trying to dry out. When you connect the hose --- you will have to put a hole into the fitting on the tank for water to flow. The idea of the tank is that the machine will run on the setting until the tank fills up ... at which time the tank full switch will not allow the machine to run again until you dump the water (and you want to drag a 6+ gallon tank, 42+ pounds, around?) . If there is a hose attached, the tank never fills up.
Some dehumidifiers feature a pump to which will pump the water to a near-by drain. You may be able to rig such a setup yourself using a small pump like a fish pond pump or similar.
You may want to consider using two dehumidifiers (with or without hoses) rather than one BIG machine. I run two machines from a major USA retailer (one in each end of the basement) and they run into the near by sump and the system works fine @ my house.Thanks for your
Thanks for your question @ FixYa.com
Jun 05, 2011 | Dehumidifiers
The water won't run continuously out, instead the tank fill up. I have it set up to run continuous but the tank keeps filling up. I have the Westpointe dehumidifier.
Some dehumidifiers don't require that the bucket be in place, when a drain hose is attached to the unit. I'm not sure that's the case with yours, because I'm unfamiliar with the Westpointe brand. You should also check the drain connection that the hose is connected to. It may be clogged, which forces the water into the bucket instead of draining through the hose. If you have something flexible like a long plastic Zip Tie, that can easily be run into the hose connection and slowly pulled back out, while rotating it should loosen any clogs. Be prepared for water to follow. Do not use a wire coat hanger to do this and be sure the unit is OFF and unplugged from the wall, before attempting it.
Hope this helped you to troubleshoot and solve the problem. Please let me know.
May 03, 2011 | Midea MDC-45AE Dehumidifier
I put a hose on my 50 pint drain and it still just fills the tank, what do I do? PS the hose is not plugged
Is there a actual hole in the tank where your hose connects? Is there a piece of dirt clogging the hole in the tank.
Water runs down hill ... if there is a hole in the tank for the water to get out and the hose is clear and it is going down hill ... it must drain. The entire length of the hose has to be flat or down hill and no kinks.
Let me know what you find please
a
Oct 02, 2009 | Frigidaire FDL50R1 Dehumidifier
Help! Water keeps filling the tank instead of going out the hose
Had the same problem. Make sure you tighten the house a little with pliers. Also, make sure the dehumidifier is up a lot higher than where you're draining it into. Mine drains into a utility sink. But I have the dehumidifier propped up onto a dresser. I cut a small piece of hose to run into the sink. Seems to be working now.
It will take 5 min or so to establish a water flow, so be patient after you hook everything up. Good luck.
Jul 07, 2009 | Danby DDR586R Dehumidifier - 58 Pints...
Brand New De-Humidifier not pulling water into bucket or hose !
I have lost my manuel. I do not know how to use the hose for when I go away for a few days.
Apr 28, 2009 | Whirlpool Gold AD70USS 70 Pint Per Day...
No water filling in tank (whirlpool Gold AD70USS 70 Pint Per Day)
the unit has a sealed system leak that need to be repaired by sears 1-800-905-9505 for service
Apr 13, 2008 | Whirlpool Gold AD70USS 70 Pint Per Day...
Power lose
I have a 45 pint. I have to slide the bucket in and out of the unit multiple times. Make sure to wait a few seconds after each time to see if it will recognize no water (sometimes the red light comes on, but then changes it mind). Also, I've found that leaving the bucket a little crooked will make it respond. It sucks, I know. Mine is only a year old too. Should not be a problem like this!
Sep 14, 2007 | Frigidaire FDL45P1 Dehumidifier
Dehumidifiers Logo
662 people viewed this question
Top Frigidaire Dehumidifiers Experts
buzz flewhart
buzz flewhart
Ken Thomas
Are you a Frigidaire Dehumidifier Expert? Answer questions, earn points and help others
