Panasonic PT-47WXC43G the picture has green edges on them
  • 6,487 Answers
Where only one color is showing, suspect an incorrectly adjusted individual background/bias control or bad part on the CRT neck board for that color.
  • Individual brightness/background/bias control(s) - mark setting of pot for the problem color and then see if a slight adjustment removes the retrace lines. See the chapter: "TV Adjustments". Of course, if this happened suddenly, the problem is not due to a misadjusted control though a dirty pot is possible - turn it back and forth - this might clean it and restore normal operation.
  • Component or connection on CRT neck board - insufficient voltage to or incorrect biasing of the video driver for this color can result in the CRT never totally blanking. Compare voltages and signals, and swap components between good and bad channels to confirm.
  • Blanking circuit - this may be a part of the video/chroma chip or separate. Check and compare waveforms of good and bad colors to determine if the blanking pulses are making it to the video output.
There is a slight possibility that a bad CRT may result in visible retrace lines. To eliminate this possibility:
  • Disconnect the filament - all evidence of a picture, raster, and retrace lines should disappear once the filaments/cathodes have cooled (15 seconds or so. If there are still visible retrace lines, the CRT is suffering from cold or field emission from someplace (may not even be the cathode).
  • Turn down the screen (G2) control on the flyback (usually). If one color remains no matter how you set the control, again there is some kind of weird emission from the CRT. However, if white/gray retrace lines remain, the problem may be in the screen supply.
Hope that helps........
Posted on Jun 23, 2008
    Genius:
  • 1,847 Answers
Try power cycle.
Panasonic PT-47WXC43G green ONLY is bowed on bottom and top
It still convergence chip problem, check big resistors nearby these chips that would be open or devalued and causing problem, specially in green convergence area, your green tube/ gun is just fine and just not getting convergence output signal to show correct image.
I would suggest to download service manual copy of this tv for small fee from any website and fix the issue with schematics help.
Thanks.
May 02, 2010 | Panasonic PT-47WXC43 47" Rear Projection...
No picture on pt-47wxc43g
Call a good TV Tech and have him check c509 ECWF2474JSR .47uf -J- 200v It's the yoke return cap. Also check the convergence amp IC's. If they need to be replaced use the STK 392-120 instead of the original STK 392-110.
Jul 29, 2009 | Panasonic PT-47WX49 47" Rear Projection...
PT-47WXC43G green convergence no longer in alignment...
you can get the following repair kit at the following link. which contains the parts and the CD which has the instructions on how to do the repair. The kit you need is called the PT-53WX53G, PT-56WX53G, PT-
47WX53G, PT-47wx33G, PT-47WXC43G
and PT4743G. Convergence repair kit its at the following link.
http://www.tvrepairworld.com/
Jul 15, 2009 | Televison & Video
3D color
Yes its an easy repair. you need to replace both convergence ICs number STK392-110 you can get new replacement ICs at the following link and they provide free instalation instructions with pictures they also have free tech support if you should need it by on line instant messageing. Heres the link.
http://servicemanuals.vstore.ca/
May 26, 2008 | Panasonic PT-47WX49 47" Rear Projection...
PT-47WXC43G
no the ICs wear out the PS3 could contribute a little. But you will need to replace both STK392-110 Convergence ICs. You can get them at this link with free instalation instructions with pictures so you can do the repair yourself. Here is the link
Apr 24, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT -47WXC43G 42 inch TV
replace the convergence amp ICs both of them. They cost about 15.00 each
Mar 09, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Convergence chips 110 installed but unsuccessful
check the resisters or send the board in to ptscorp.com
if you find bad resisters chances are you blew the ic too
Feb 26, 2008 | Panasonic PT-47WXC43 47" Rear Projection...
Panasonic Pt-47WXC43G
If you go to the following link you can get the service manual and unlimited chat support to fix your set. It only cost 10.99 and if you click on the contact us link and provide your email address they will email your manual and the instructions on how to gain acces to the chat support service. I am one of their techs.
Jan 01, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Televison & Video Logo
78 people viewed this question
Top Televison & Video Experts
