Question about Sony PlayStation Portable (PSP) Console
Stuck on hold
My psp is stuck on hold when the switch isnt on hold and when i put it on charge it off hold but as soon as its charged or i take it off charge it's back on hold.
    Problem Solver:
  • 4 Answers
Sounds like the hold switch itself is bad. You may need to RMA it, or take it to a local electronics repair shop.
Posted on Jun 20, 2008
I need to know if the power source could be the problem. I already replaced the battery and it worked fine for a week, and then died. I already took it apart once and fixed the dpad, so that's not a p
This could be due to a faulty charging cable, a burnt-out battery or the interference of software you have downloaded. Solve these problems by testing your PSP to locate the charging problem and proceed to implement the correct solution.
Revert to Factory Settings
1 Switch the WLAN button on your PSP so that it is in the "Off" position. Remove any memory stick or UMD that is in the system and put them aside.
2 Choose "Settings " from the left side of the cross media bar. Scroll to "Restore Default Settings." Press "X" to enter this menu. Press "X" to accept the restoration. The PSP will then revert back to its original settings.
3 Power off the PSP and plug it into an outlet with the AC adapter to charge for three hours. Power on the system to see if if the charging issue has been resolved.
USB Charging
4 Power on your PSP and scroll to the far left of the cross media bar. Choose "System Settings" and press "X." Scroll down the System Settings menu until you reach the option for "USB Charge." Press "X" and switch the setting to "On."
5 Return to the "System Settings" menu and choose "USB Auto Connect." Make sure the Auto Connect setting has been turned on. This allows your PSP to enter USB mode and begin charging whenever it is connected to another device.
6 Connect the PSP to a powered on PS3 or PC using the USB connector cable. The small end fits into the top of your PSP while the large end is inserted into a USB slot in your chosen system. The PSP will automatically enter USB mode as soon as it is connected.
7 Leave the PSP attached to the system for 30 minutes to an hour. When you detach your PSP, check your battery power. If it has gone up, then the charging problem is with your AC adapter. You can replace it or continue to use the USB charge function.
8 Plug your PSP into an outlet using the AC adapter cable and power on the system.
9 Enter the "System Settings Menu." Scroll down until you reach "Battery Information." Press "X" to open the menu.
10 Check the last option on the page which is labeled "Battery Status." If the status does not say "Charging," then the battery is not receiving a charge from the cable. While your PSP is getting power from the cable, you will need to purchase a new battery.
Oct 04, 2012 | Video Game Consoles & Games
My psp will nt charge or turn on it has been in myy locker for a while now when i plug it into my ps3 it will not charge
Try keeping your psp battery in a dry place for a day,then try charging.If this doesn't work..
Try the following:
a) Try charging using a usb cable...
c)Also try cleaning the usb port and power port or the place were u connect the charger to psp...
b) Remove ur psp battery and plug in the charger and turn on the psp... When it turns on put the battery back in (do not turn off the switch or psp when u put the battery back in)...
Mar 15, 2011 | Sony PlayStation Portable (PSP) Console
My psp 1001 is not charging. i plugged it in the socket when the power generator at my home was running and the psp stopped charging after the generator stopped and power shifted to the mains.
hello, try charging it threw the USB port and see if that works, if it does, then you know that the psp isnt the problem. It can be your charger or you may need to replace your battery.
Apr 24, 2010 | Sony PlayStation Portable (PSP) Console
GoGear Aria reset stuck in, will not turn on.
Have you reset the player? Reset the player by holding the off-switch and the volume-+ (plus) switch.
If this doesn't help try this: Connect your player to the pc that has the Philips device manager running, then reset the player by holding the off-switch and the volume-+ (plus) switch. As soon as the player shuts off, press and hold the volume- - (minus) switch. The Philips device manager will recognize the player now, and recommend a repair, let it do so.
Aug 18, 2009 | Philips GoGear HDD1830 MP3 Player
PSP cannot turn on
i think youll need to call to get service done............if your psp warranty isnt up they may give you a new psp
Aug 03, 2009 | Sony PlayStation Portable (PSP) Console
I cant charge my psp with usb
go to settings and check that usb charge option is on... and ake sure its in usb mode
Jul 14, 2009 | Sony PlayStation Portable (PSP) Console
Psp dont charge
i think its one of 3 things
1. the internal power connector
2. part abxy and power switch circuit board
3. bad battery
Feb 03, 2009 | Sony PlayStation Portable (PSP) Console
Dropped it wont switch on
Try this :
Put in the battery, and hold down the ON Button for 10 seconds. Then, take out the battery Hold down the power ON switch and put the battery in while holding the ON Switch... Let go of Power switch, and charge the battery for 10 hours
Try turning it on
Jan 04, 2009 | Sony PlayStation Portable (PSP) Console
Psp wont charge or hold a charger
It could be a bad battery or you can check under the psp if you can turn it on and make sure that under Settings > System Settings > USB Charge is set to on. If it is and it isn't charging then it's a bad battery.
Dec 22, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
279 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
