Question about Bose Cinemate Digital Home Theater System Speaker
Extend cable from control module to bass module?
Can I splice some wire to extend the distance between the control module and the bass module?
Also, any tips on taking apart the bass module and control module?
Thanks
  • 53 Answers
Alex, I know you posted this question over a year ago, but my husband has the same question and we cannot find an answer ANYWHERE! Did you ever figure out how to cut & splice the wire b/t the control module & the base module? Please share if you did!
Posted on Jul 12, 2009
Warn winch 2006 Suzuki Eiger Winch will retract cable but will not extend cable
Use a test light at the contactor to see if the switch and wiring are good.If you see an input from the switch up to the contactor,make sure the connections are all clean on the control input terminals at the contactor.(The contactor is the device that changes the polarity of 12V to the winch to extend or retract-essentially a double throw double pole relay).
Oct 01, 2013 | Suzuki 2006 Eiger Automatic 400 4X4...
What is a network extender?
Wikipedia says: An Ethernet extender (also network extender or LAN extender) is any device used to extend an Ethernet or network segment beyond its inherent distance limitation which is approximately 100 metres (330 ft) for most common forms of twisted pair Ethernet. These devices employ a variety of transmission technologies and physical media (wireless, copper wire, fiber-optic cable, coaxial cable).
Feb 14, 2013 | Computers & Internet
Fused Terminal Block on Refrigerator
  1. Signal Integrity
    • One benefit of using a terminal strip to connect the thermocouple wires is signal integrity. Since the thermocouple has a temperature probe located on the end of the wires, a signal must be sent from the probe to the thermocouple. The equipment and machinery will work intermittently, if the signal strength is not maintained. For example, if the probe senses the flame on the furnace, it sends a signal to the thermocouple. Once the flame goes out, a signal is sent to the thermocouple, which shuts off the gas.
    Shield
    • The terminal strips have a covering, or shield, to protect the thermocouple wires. You can open the strip and gain access to two metals for testing. You must cut off the insulation surrounding each metal wire and insert them into a terminal strip to make the proper connection. The cover protects those bare wires from dirt and debris. The cover can be removed when troubleshooting the thermocouple and wiring. Without the terminal strip, you would have to cut off each wire's insulation to test the signal strength and voltage between the probe and the thermocouple.
  2. Transmitter
    • A thermocouple sensor that has to carry signals over a long distance requires a thermocouple transmitter to strengthen the signal. Using terminal strips makes it easier to connect a transmitter to the thermocouple device. The terminal strips also lengthen the thermocouple wires. If you need to extend the distance from the probe to the thermocouple, you can add additional wires and splice them with terminal strips to increase the distance. It is like adding an extension cord to an outlet, so you can extend the distance between the outlet and the television.
    Connection
    • Another benefit of using a terminal strip is that the strip enables a better electrical connection between the two thermocouple wires. Without a terminal strip, you would have to introduce signal compensation metals for the thermocouple sensor to get an accurate temperature reading between the two metals. Since the terminal strip uses the same metals found in the thermocouple wires, your electrical connection will not lose voltage. A decrease in voltage can trip the thermocouple.
Jan 09, 2013 | Dryers
How can I make the speaker wire longer???
To extend speaker wire you need to splice it. The proper way to do this is with bu tt connectors. You will also need a crimper, but a cheap set from the hardware store will do the job just fine. Make sure all components are off and unplugged when doing this. It is also a good idea to splice 1 conductor at a time so that you don't accidently cross the wires and end up shorting your system. Once your wires are spliced through, it is also a good idea to re-insulate your connections with electrical tape.
Jan 04, 2011 | RCA RTD317 Theater System
Does anyone know how to make a bass knob remote out of phone line? What the color code? I have 4 different color wire here but i don't know what to do to make a bass knob remote.
It is NOT clear what you are trying to do... HOWEVER if you are attempting to extend a bass potentiometer remotely, you CANNOT use the four wire flat telephone line as it is unshielded and you will pick up hum.
Dec 04, 2010 | Marshall Amplification Marshall IBS Bass...
I have a 2002 Ford Taurus with factory radio. I want to put an aftermarket radio in. All the mounting kits I have found have the rear defrost button on the opposite side as where mine is. What should I do?
If you can, loosen the ties that hold the wires for the button and see if they will reach the new location. If not, splice in a bit of wire to extend the reach. I recommend soldering the connection, but you could use crimp connectors with a larger wire. Make sure the wire you splice is a little bigger than the factory wiring.
Sep 05, 2010 | 2002 Ford Taurus
Not enough wire to feed thru 24 in. downrod
You will need to extend the wires by splicing. USE the same type wire as supplied on the fan with the same temp rating of insulation.
DO NOT use lamp cord!!!!
Jan 09, 2010 | Aloha Housewares (93645) Ceiling Fan
Need to extend sub woofer cables for a distance of 18 mts on product HTS6100 sound bar av system
If you are referring to the subwoofer speaker wires, normally, speaker wires of any length are available from most electronic stores and/or audio/video stores. Even those shops that do car audio installations would have them in their inventory. The only requirement/specification you would need is the power output of your system and the required length. The longer the distance, the bigger the wires the better.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 10, 2008 | Audio Players & Recorders
Power connection for L365 Fish finder
Fuses and Breakers
Attach the red or positive wire to a 5 amp circuit breaker. If the unit is connected directly to the boat’s battery, include a 2 amp in-line fuse. (In-line fuses are available at most marine supply stores.) The power cable includes a smaller "shield" wire. Connect this to a good ground.
Extending the Power Cable
If you need to extend the power wiring by more than 10 feet, use a larger wire size. This will allow the wires to deliver the correct voltage in spite of the longer wire distance. For runs of 20 to 35 feet, use #14 AWG cable. If you extend the power wiring, be sure all electrical connections are solid and durable. Soldering is the best way to make these connections. Insulate all connections using heat-shrink tubing or electrical tape. You may also use crimp connectors or a terminal strip, but be sure to use good-quality marine-grade parts.
Apr 15, 2008 | Computers & Internet
Extending the Antenna wire to reach new deck
If it is a Chevy then the antenna wire will not fit in the first place. best buy sells an adapter that ill extend that wire and make it the right size. The wire is like 7 to 10 dollars.
Apr 14, 2008 | Kenwood KDC-MP235 CD Player
Bose Cinemate Digital Home Theater System Speaker Logo
1,768 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
