Question about Panasonic VIERA TH-65PV500 65 in. Plasma Television
Viera TH-50PX70BA When I turn the TV on it's automatically in stand-by mode. Whrn I press the buttons on the remote control, the red light flashes like it's working, but nothing happens. I have also checked that all of the connections are firmly in place. Any thoughts on how to fix this are much appreciated!
  • JILLHOYE2 May 07, 2009
    NONE OF MY CONTROLS WILL WORK. i CAN TURN THE TV ON AND OFF BUT OTHER THAN THAT NOTHING WORKS ON THE REMOTE OR ON THE BUTTONS THAT ARE ON THE TV
I called out a TV repair-man in the end!!!
Posted on Jun 21, 2008
Sky remote code for panasonic viera TH-50PX70BA
[0051]
678 254 278 154 242 368 191 302 128 544 241 065 395
379 389 103 576 136 650 278 136 678 254 065 650
Jun 10, 2012 | Panasonic Viera TH-42PX80U Plasma TV
Code for Sky remote for AlbaALCD15DVD2 tv Thanks TH
Hello
Sky remote codes to check with Alba TV are:
037 065 246 399 263 064 446 609 275 077 515 244 398 239 400 459 191 383 607
696
705
742
471
Sky+ Remote Control Unit Programming Procedure Follow the steps below
1* Select any channel on the TV.
2* Point your Sky+ remote control away from the TV and press the tv button.
3* Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4* Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5. Point the Sky+ remote control at the TV and try the volume button.
If this works try the other TV functions.
If these work then the correct code has been selected.
It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 to 3 and work through all the relevant 3 digit numbers from the Sky Plus remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
OK.
Sep 20, 2011 | Televison & Video
Need a four digit code for comcast universal remote for panasonic th-42px80u
Hello
Four digit universal remote codes for Panasonic TV are:
0171 0148 0054 0170 0062 0374 0381 0437 0950 0003 0070
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Mar 27, 2011 | Panasonic Viera TH-42PX80U Plasma TV
I am trying to program a new BELL remote control and i need the tv code to control the tv tks
  • 1. Turn on the device you want the remote to control; this can be your television, DVD player, or VCR.
  • 2
    Press and hold the appropriate mode button for the above device, until all the other mode buttons light up.
  • 3
    Hit the blank power button.
  • 4
    Press the up arrow on the remote repeatedly until the device turns off.
  • 5
    Hit the "#" button to lock in the code.
  • Jan 23, 2011 | Panasonic Viera TH-42PX80U Plasma TV
    Power light blinks 13 times
    need replaced A-BOARD
    Manufacturer Panasonic Part Number TNPH0716ABS Description A- BOARD
    After the installation of a new A board, unit has the characters "CHK" on screen. The usual reset procedures of [VOL -] and [MENU] or [OK] or [SLEEP] will not get rid of "CHK".
    1. Enter the service mode by holding down the [VOL -] button on the TV (main unit) and simultaneously pressing the [INFO] button on the remote control three times.
    2. Press the number [2] key on the remote to highlight [SRV-TOOL].
    3. Press the [OK] button on the remote control to select [SRV-TOOL].
    4. Use the [DOWN ARROW] on the remote control to scroll down to [PCTC].
    5. Use the [RIGHT ARROW] button on the remote to open the box to the right, then press and hold down the [MUTE] button on remote to display Time/Count.
    6. Press and hold the [RETURN] button on the remote control until the TV turns off.
    7. Immediately press and hold down the [VOL -] button on the TV (main unit) and the [MENU] button on the remote. The TV should come up in the Self Check mode.
    8. Remove AC power.
    Jul 06, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
    Sky + code
    please follow the steps below:
    TV
    RED + SELECT (flashes twice)
    TV
    0051
    try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
    cheers
    Little Dish Fitter
    May 09, 2009 | Panasonic Viera TH-42PX80U Plasma TV
    Remote control code
    1. Press tv on your Sky remote control.
    2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
    3. Press tv again
    Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
    Panasonic Code: 0051
    4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
    5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
    Feb 15, 2009 | Panasonic TH-42PZ80B 42 in. HD-Ready...
    Pairing Sky+ Remote with Panasonic Viera remote
    3. Press tv again
    Dec 29, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
    Panasonic Viera TH-42PV7HS Plasma keeps shutting down
    Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
    Oct 07, 2007 | Televison & Video
    Panasonic VIERA TH-65PV500 65 in. Plasma Television Logo
    377 people viewed this question
    Top Panasonic Televison & Video Experts
     Grubhead
    Grubhead
    Demonic-2011
    Demonic-2011
    Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
