Question about Kenmore 24 in. 17052 / 17054 / 17059 Built-in Dishwasher
Does not drain
Our Kenmore Elite 17052 dishwasher no longer drains properly.
We checked the hose area at the disposal and disassembled the drain area in the washed and cleaned out the area - the drainage worked ok for a couple of washes then stopped again.
When I turn on Drain only I can hear the light buzzing of the motor but no drainage is happening.
What is this likely to indicate, please?
Thanks! David in Florida
  • Kenmore Master
  • 4,498 Answers
The light buzzing of the motor doesn't mean the pump is in good condition and actually is being driven by the motor, in fact a seized synchronous motor can make a convincing buzzing sound and not burn out for a long time. The pump intake could be blocked...
If the symptoms indicate there could be something wrong with the pump then visual confirmation is required and not merely the assumption.
Posted on Jun 18, 2017
aborcass
  • 2651 Answers
SOURCE: Dishwasher not draining
remove the clamp holding drain tube to disposer, unplug disposer, and see where clos is its gotta be right there, UNPLUGGED.UNPLUGGED you can stick a screwdriver thought drain hole in side of disposer to clear debris
Posted on Feb 23, 2008
leroyal
  • 2120 Answers
SOURCE: Kenmore Ultra Wash III Dishwasher will not drain properly
Fixerfailure, is the knock-out plug still inside if the garbage disposal inlet?
Stick a screwdriver in there to make sure.
spazmo1969, could be the rubber flapper is broken off in the pump discharge outlet.
Posted on Jan 06, 2009
  • 172 Answers
SOURCE: KENMORE ELITE DISHWASHER - MULTI-LIGHTS FLASHING
Look at your manual, usually available on net for reading or downloading. Blink lights are often used to code out a problem with various combinations and repetition rates to indicate trouble code number for look-up in manual.
Posted on Feb 22, 2009
jsrock516
  • 5911 Answers
SOURCE: i need to get the drain plug out of the garbage
Take a flat blade screwdriver and insert it into the drain port that you connect the dishwasher drain line to. Take a hammer and tap the screwdriver until the plug pops loose inside the disposal. Now, reach down inside the disposal and retrieve the plug. You should not have to disassemble the disposal to do this. I hope this answers you're question.
Posted on Jun 21, 2009
  • 10 Answers
SOURCE: Kenmore Elite model 665.17052400 dishwasher will not drain
Check disposal to see if d/w knock out was removed form disposal. If so check drain hose for kinks or restrictions.
Ie unistally hose from disp and see if d/w will drain into bucket. IF not uninstall d/w and check for kinks.
Posted on Jul 18, 2009
Why kenmore elite dishwasher will not drain?
If it is connected to a disposal remove the drain hose and check for a restricted area in the hose or disposal this is common also check the drain hose for kinks be sure to elevate the hose before the drain area. If the drain hose is clear and the drain is clear then you could have a bad drain pump in the dishwasher.Most problems are a restricted drain or hose
Jul 22, 2014 | Kenmore 24" Built-In Dishwasher with...
My kenmore mod. number 665 1578 4300 does not drain. what could be the problem
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Mar 07, 2010 | Kenmore Dishwashers
Water does not drain
Hi
Thanks
Rylee
Dec 11, 2009 | Kenmore Dishwashers
My kenmore ultra wash plus is not draining
Hi
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 04, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore ultra wash dishwasher model 15752000 is not draining completely after cycle has finished
Hi
Thanks
Rylee
Oct 21, 2009 | Kenmore Dishwashers
Runs the cycle but doesn't drain completely
Hi
Thanks
Rylee
Oct 12, 2009 | Kenmore Dishwashers
Water not draining kenmore dishwasher
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to some different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then you may want to consider calling a professional plumber. He may need to replace the drain valve or hose.
Thanks
Rylee
Aug 20, 2009 | Electrolux Kenmore 24 in. Built-In...
Dishwasher (Kenmore 665 Ultra Wash) won't drain. Suggestions?
HI.This is a drain issue. check the following areas for faults.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
Ok, if the hoses are ok and not clogged, this will confirm a major issue that concerns the drain assembly or pump impeller.
replace the pump(drain) if found to be faulty.
Jul 20, 2009 | Kenmore 15899 Built-in Dishwasher
Jul 18, 2009 | Kenmore 15899 Built-in Dishwasher
Dishwasher doesn't drain fully
Hello. Are you using liquid or powdered soap? In some models liquid soap will foam up and the drain motor can't pump out bubbles. Foaming can also happen if you pre-clean your dishes with liquid soap used for washing by hand. If it is foaming, you can poor non-dairy creamer or cooking oil into the bottom of the unit while it is in the wash cycle.
If foaming isn't a problem then the water level switch may be bad, the pump may be not pumping out as quickly as it should or you may need to take the hose off completely to make double sure that there isn't anything in it.
Did you check the air-gap next to your kitchen sink faucet. If you don't have an air-gap it may be hooked up to the garbage disposal and if you don't have a high loop in your drain hose the water can run back into the dishwasher especially if the disposal backs up.
Dec 03, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore 24 in. 17052 / 17054 / 17059 Built-in Dishwasher Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
