Question about Arris Wireless G Broadband Router (wr850g)
I cant figure out my password
When i go to my Default Gateway two Boxes pop up, 1 for a username and another for Password. After various internet searches i learned that the standard password/username is Admin-Motorola. But when i tried this the password was incorect. I asked everybody in my family if they had changed the password, and none have. I was wondering how i can find the existing router password.
Thank You
  • 689 Answers
You can reset the router, There is a reset button when you press and hold it will change the settings to factory default, so you can use default password.
Good Luck
Posted on Jun 20, 2008
Where do I get the code
Almost all routers and access points have an administrator password that's needed to log into the device and modify any configuration settings.
Most devices use a weak default password like "password" or the manufacturer's name, and some don't have a default password at all.
As soon as you set up a new WLAN router or access point, your first step should be to change the default password to something else.
You may not use this password very often, so be sure to write it down in a safe place so you can refer to it if needed.
Without it, the only way to access the router or access point may be to reset it to factory default settings which will wipe away any configuration changes you've made.
This can be done by opening your internet browser (i.e. Internet Explorer, Firefox, Safari, Opera, etc.) and typing in the address bar 192.168.1.1.
Once you hit enter, an authentication panel would pop-up requiring you to enter a username and password.
Note: If entering 192.168.1.1 does not bring up anything, your default gateway may not be that.
For Windows, just go to Run command (Windows Start button, then click Run), and then type "CMD".
A DOS prompt would pop-out and you would just need to type, "IPCONFIG". Look for the words "Default Gateway", the numbers beside it are the ones you need to enter into your browser
Usually, its 192.168.1.1 or 192.168.0.1 so most likely you wouldn't have to do that.
Another Note: The usual username and password is "admin" (without the quotes).
For some routers, the username is admin, and the password is blank.
Jan 09, 2014 | Computers & Internet
How can i put a password in my wifi for privacy
1. Access the Administration Panel of your Router This can be done by opening your internet browser (i.e. Internet Explorer, Firefox, Safari, Opera, etc.) and typing in the address bar 192.168.1.1.
nitin_master.png Once you hit enter, an authentication panel would pop-up requiring you to enter a username and password.
nitin_master_0.png Note: If entering 192.168.1.1 does not bring up anything, your default gateway may not be that. For Windows, just go to Run command (Windows Start button, then click Run), and then type "CMD". A DOS prompt would pop-out and you would just need to type, "IPCONFIG". Look for the words "Default Gateway", the numbers beside it are the ones you need to enter into your browser
nitin_master_1.png Usually, its 192.168.1.1 or 192.168.0.1 so most likely you wouldn't have to do that. Note: The usual username and password is "admin" (without the quotes). For some routers, the username is admin, and the password is blank. If you haven't changed this, the username and password is the default. If you don't know the default username and password, you could check it at www.routerpasswords.com
2. Set the SSID or Username When you're inside the Administration panel, just go to Basic Wireless Settings and find the setting for Wireless Network Name or SSID.
nitin_master_2.png You should key in your desired username on the field of Wireless Network Name or SSID. Don't forget to Save the Changes you made.
nitin_master_3.png Note: Notice that I've enabled Wireless SSID Broadcast? If it's enabled, once a computer detects connects to your router, the computer would just need to key-in the password. If it's disabled, you would have to key-in the username and password before you could connect. Although it is more secure to set Wireless SSID broadcast set to disable, some of my devices (especially mobile phones) can't connect when it is disabled. So, I had to enable SSID Broadcast.
3. Set the Password. You should now go to Wireless Security. There you would see the Security Mode. To make things simple, just choose WPA Personal. (UPDATE: For bettery security, you can choose WPA2 Personal - the next steps would still be the same)
nitin_master_4.png You should now set a password by entering one under WPA Shared Key.
nitin_master_5.png After that, save the changes you made again. And there you have it. It's very easy to set a username and password for your Wireless Router or Wi-Fi router. Once you set one, only those who you have informed of the password would be able to connect and use your Internet connection through your Wireless router - so keep your password safe.
Nov 20, 2010 | Linksys Wireless-G WRT54G Router
Want to change user name and pass word
You can do so by opening the GUI page of the router:
First connect it to the computer through a Ethernet wire and then check the default gateway (go to command prompt and type ipconfig)
put in the default gateway address in the internet explorer address bar
Log in to GUI..the default username and password is following
Username: admin
Password: admin
or
Username: admin
Password: password
Log in and change the username and pasword...you would also be able to change the wireless password (WEP key) from same
Sep 25, 2010 | D-Link DSL-2640B Wireless 11/54Mbps ADSL2+...
Cant find my WEP for 2wire331
If your PC/laptop is wireless to Router - try this
http://www.fixya.com/support/r5198336-details_router_or_network
OR
If your PC is wired connected to Router, try this
Click on START button
Click on Run ( you will find small window to enter command )
Type CMD ( or COMMAND ) and click OK button
( you will see black window on screen )
Type the command where the Cursor is blinking
IPCONFIG ( hit enter key )
From the list find DEFAULT GATEWAY
Default Gateway is IP address of Router
Open Internet Explorer
Enter the No. you find for Default gateway in the address bar ( without www or .com, just the no. ) - Click Go
You will find the Router page open
Incase if it ask you for username and password - type Username = Admin and Password = Password ( or the username and password which you have set )
Under Wireless settings / Advanced Wireless setting - you will find the WEP Key
Jul 01, 2010 | 2wire (1000-000005-002) 802.11g/b Wireless...
I cannot gt into the router
Hard reset properly for 30 secs. & Powercycle and try again.
Mar 17, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
If I reset my router, do I need the CD to reconfigure or change the password
You don't actually need the CD to reconfigure your router or change the password or anything related to your router. So long as the router is connected to your computer via ethernet cable you can access the browser configuration page of your router.
1. connect your router to your computer via ethernet cable
2. If you are using Windows XP
- click start
- click run
- type cmd
- in the black screen type ipconfig and press enter
- look for the default gateway (example 192.168.1.1)
- Open Internet explorer
- type in the address bar: http://the default gateway (example http://192.168.1.1) then press enter and it'll ask you for the password
- usually the username is blank and the password is admin or the username is admin and the password is pass or password
If you are using Windows Vista / Windows 7
- Click the pearl button
- Click on start search at the bottom of the pop-up window
- type cmd (don't press enter yet)
- right click the black icon on the top of the window after typing cmd
- click on the run as administrator
- click on continue if there's a prompt
After successful accessing the configuration page you can now configure your router freely.
Jan 11, 2010 | Gateway Wireless-B Router (wbr-100)
I cant access the router's web-based setup
1. go to start -> run -> type cmd
2. at the prompt type ipconfig /all
3. note down the IP address of your default gateway
4. enter this ip address in internet explorer. eg. http://192.168.1.1
5. enter in your routers default username & password. ( usually admin for the username and admin for the password.)
Mar 17, 2009 | Computers & Internet
Need to change netgear router rp614 from dsl to cable
Hello
First connect one of the ethernet ports (LAN) to your computer.
In windows to this:
XP: Start -> Run -> write CMD and press ok-> Black window pops up-> write IPCONFIG and press Enter. -> Look for Local ethernet connection and write down the ip adress outside default gateway (f.ex 192.168.0.10 or 10.0.0.1).
Vista: click windowsmenu icon-> write CMD in search field and press enter -> Black window pops up-> write IPCONFIG and press Enter. -> Look for Local ethernet connection and write down the ip adress outside default gateway (f.ex 192.168.0.10 or 10.0.0.1).
Open a webbrowser and clear det adress field, enter the adress (with the dots and no www.) you wrote down from default gateway and press enter.
If you get promted for a username and password the default is: username: admin password: password (you can find it on the side of the netgaer box under deafult accsess.
If you cant get in try to do a "hard reset" (push the reset button for 30 sec with a pen).
You are now in the web user interface for you netgear.
On your lefthand side, you should have a blue menu, click on the first option on the top and run the setup wizard, dont change anything (dont choose that your connection needs a password to connect) just use the default settings. Remember to press save on the botom.
You should now be ready to use your netgear router.
If this guide didnt fix your problem, i need more details to help you.
Check with your new service provider if they require a username and password to connect (PPPoE).
Feb 07, 2009 | NetGear WGR614 Wireless Router
I cant find the password for my 2wire wireless gateway "help"!!!
You can reset the password by removing the cmos battery from the motherboard for about 5 seconds, replace & reboot. Hope this helps.
Dec 26, 2008 | Computers & Internet
How to set up password for the router
You should connect your computer to the router with an ethernet cord.
1.Click on Start - accessories - command prompt.
2. On the command prompt, type ipconfig look for the default gateway. Take note of the number found in default gateway.
3. Open Internet Explorer then type the number from the default gateway in the address bar.
A window will pop up and will ask for he username and password. By default, username: admin sometimes they leave it as blank and the password: password sometimes it uses admin as the password.
Keep me posted.
Nov 26, 2008 | Computers & Internet
Arris Wireless G Broadband Router (wr850g) Logo
178 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
bobkoure
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
