Question about Canon P23-DHV Calculator
Loading paper First time user. Cannot load the paper. Have tried all suggestions to date. Nothing works. Paper does not advance even though machine is trying to do so. Paper goes through slot at rear of calculator but will not advance into the printing area. Help!! can not load paper never load before
  • teresa455 Sep 18, 2008
    cant load the paper roll
  • asj1jmj1 Oct 04, 2008
    same problem, I feed paper through slot in back but doesn't catch to load paper inside to print.
Cut paper at an angle and insert and push into back slot with tip of angle (apex) to the right of machine when facing it. It should engage number wheel when you hit addition sign, You may need tweezers to pull it thru if it doesn't advance.
Posted on Jan 23, 2009
2 Suggested Answers
PA8558
  • 28 Answers
SOURCE: Loading paper
A lot of times, the paper will not advance into the calculator without the paper being cut STRAIGHT ACROSS. Try cutting it straight across and then try to feed it in. The rollers should be able to grab the paper at that time.
If this helps, please rate me. Thanks, Patty
Posted on Jan 04, 2008
Canon pixma 3100 keeps saying load paper and won't print
If you have paper in the loading tray and it keeps giving you out of paper message then the sensor by the loading hopper is not working and would need to be replaced.
9 times out of ten though you might want to clean the printer and make sure the hopper is not just jammed this happens when you put too much paper in there at one given time.
thanks
Sep 17, 2009 | Canon PIXMA MX310 All-In-One Printer
Paper loading error
hi the sloution to the problem is that to go ahead and try to reset the printer and it will definetly work ,
if you get stuck on some problem try to get in touch with me on fixya
Jul 22, 2009 | Epson Stylus Pro 9800 InkJet Printer
Sir, can anyone help me with my fax (canon fax l295)for a problem, it was always indicating that "load paper" even though i put paper on the tray once it was start feeding it makes an paper jam error and...
You either have a paper path blockage or your feed rollers are worn. You'll need to take it apart to check though. Try removing paper, turning machine off and on and re-inserting paper. Remember to fan (separate) paper before loading, it could be static causing the sheets to stick together and jam in the machine.
Jun 11, 2009 | Canon L295 Plain Paper Laser Fax
Printer paper loading
Just achieved, after trying for 2 days
Paper should drape over like toilet paper.
Cut sides to form a point in the middle.
Feed through back of machine. Paper will have a tendency to point upwards.
Guide though metal roller, then hit feed........should go through.
May 12, 2009 | Canon P1-DHV Calculator
CANON FAX MODEL L220
Hi Greg.
Press the red STOP button.After loading paper.
Nov 07, 2008 | Office Equipment & Supplies
How do you load paper into the printing calculator?
Cut paper at a 45 degree angle and load into back slot with angle (apex) of paper to the right of machine when facing it. Be sure to push it thru when loading. You should see tip next to calculator number wheel. Hit the additon sign several times to advance. You may need tweezers to pull paper thru if it doesn't advance by itself.
Oct 10, 2008 | Canon P23-DHV Calculator
Epson R300
Make sure the photo paper is not curling when it goes in. I had same problem before, with paper jam error even though the photo paper did not appear jammed. I noticed the photo paper was slightly curled, so I flattened it out and that solved my problem. Also, if you are loading multiple sheets at one time, try just loading one sheet and see if that fixes it.
May 11, 2008 | Epson Stylus Photo R300 InkJet Printer
EPSON R1800
Clean the rollers down where the paper sets in the printer. Do not use cheap generic matte coated paper. Some generic matte coated paper will leave a film on your rollers and cause them to not grip the paper.
Apr 14, 2008 | Epson Stylus Photo R1800 InkJet Printer
Check paper size comes up all the time. Also pulls anywhere from 4 - 10 blank pages through at once.
dear sir pleaz select the correct paper size in the user data programing of your machine
Sep 10, 2007 | Canon FAXPHONE L80 Laser
Loading paper
5/14/09-
Okay...It took me forever to figure it out but I finally got it. On the back of the calculator there is a slot (back meaning where the black cord is connected to the calculator). fold the paper to make a perfect straight line. feed the paper through there and press thee upward arrow. it should work.
hope I helped...=)
Aug 15, 2007 | Canon P23-DH Calculator
Canon P23-DHV Calculator Logo
1,946 people viewed this question
old marine
old marine
