Question about Vacuums
Cluged vacume hose, new carpet
Cluuged vacume hose, new carpet, have been through two vacumes already.
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=689534
Generic problem for all Vacuums
Clogged vacuum hose, new carpet
Posted by dpatricksr70 on Jun 20, 2008
Clogged vacuum hose, new carpet, have been through two vacuums already.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. When vacuuming it is a good idea to give your vacuum a burst of air once in a while to clear the hose and push the dust and dirt into the bag, simply just lift up on the powerhead or vacuum hose and give it a burst of air every 5 or 10 minutes. Also, we you like to know the brand name and model # of the vacuum. Some of the ways are to use a round metal ball or marble to see where the clog is in the hose and then you can use such things as the end of a broom handle, or you can use a wire coat hanger and bend the end to make a little hook and then try to grab the clog and say fish it out – or if you have another canister or shop vac you can tune on both canisters and try to pull the clog apart and sometimes that works as well – just be careful so that you do not puncture the electric hose because they are expensive in the area of $100.00 or more in some cases. If you need further assistance please feel free to contact your local vacuum cleaner dealer in your area.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 23, 2008
Vacum has suction, but won't pull debris from the floor
The vacuum may not be set for use on carpet.
Jan 19, 2017 | Vacuums
How to more easily vacum plush carpet with oreck XL vacum
The only Oreck vacuum cleaners that are rated for plush carpets are the two Magnesium models.
Jun 25, 2014 | Oreck XL Ultra Bagged Upright Vacuum
Where do you hook up hose
Years ago I used to sell and demo kirbys up to the G-5 model,I believe you have to sit in front of your vacume,raise the wheels as high as they can go and on the logo face tun the crank one way,this loosens the belt and give a little tug and the roller sucking chamber will drop.Pull the chamber away.,now take your hose and stick it over the shaft and lock it down with the wing nut and then you can use all your vacume attachments.UNLESS YOUR TALKING - vacume bag hose- this is just a simple twist and click on the vacume exhaust chamber. Now if your hose is unhooked in your vacume bag it self,you will have to get a new bag attachment or get a repair man to look at it.
Jan 08, 2012 | Kirby G6 Bagged Upright Vacuum
My Hoover vacuum cleaner is not picking up from the carpet like it used to. Like it's having difficulty picking up strings, fuzz, etc. from the carpet. Suction power seems to be fine. The belt and the...
YOUR VACUME SHOULD HAVE A HOSE THAT PLUGS INTO THE LOWER PART OF THE VACUME OR MAY COME APART AT THE BOTTOM . IT SOUNDS LIKE THE TUBE IS STOPPED UP AT THE FAN MOTOR
Jan 16, 2011 | Hoover Vacuums
New carpet has clogged the vacume hose. How do I clear it out
The easiest way I've found is to disconnect the hose at both ends, and GENTLY push a broom handle through it while removing the stuff from the other end. Unhooking it allows you to lay the hose straight. Adjust your head height to where you just hear it hitting the carpet, then raise it one notch. The brush is designed to (and this is a secret the salesmen won't tell you) just touch the top of the carpeting to get it moving so the dirt becomes loose, the suction does the rest. Too low and it just forces the carpet to lay over and traps most of the dirt.
Nov 02, 2010 | Kenmore 23812 Progressive PowerMate Bagged...
Not picking anything up off the carpet
You need to replace the belt. You can get replacement belts here:
Replacement Vacuum Belts
Feb 16, 2010 | Vacuums
The vaccum doesn't pick up dirt, it sprays out
There is probably a second or third filter (besides the canister) that needs to be cleaned.
I doubt that it's rotating the wrong direction.
Apr 25, 2009 | Dirt Devil M084600 Dynamite Bagless...
Bissell turbo revolution
you can wash that sponge filter by hand but you must let it dry compleatly before putting it back in the machine, I found a filter pack for the lift off vacume at walmart, make sure teh bottom filter is clean as well. the lift off vacume has 3 filters there is one filter in the tray under the dirt cup, one in the top cup, and the hepa filter in the back the 2 foam filters must be clean or you can have reduced suction, the lift off vacume I have I found thrown away because they never cleaned it outthe brush was dirty and full of strings the belt was worn, the hose under the vacume was full and stopped up the hose in the back was compleatly stopped up all filters were compleatly clogged, and the hepa filter was missing entirely. Not to insult you or anyone but i've found that a lot of people are jsut to lazy to clean their vacume out it fills up with dirt they throw it away and get a new one, i've gottten many like new vacumes for this reason, this bissell is working like brand new now. and I just replaced the belt and all filters in it saving me approx. 150.00 for a new one
Dec 21, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
We have the Eureka EZ Kleen upright. We have suction through the hoses but not the main vacuum. The brush turns fine but the vacume does not **** anything up.
THE HOSE BETWEEN THE DETACHABLE WAND AND THE BRUSH ROLLER AREA MUST BE CLOGGED WITH CARPET FIBERS. CLEAN IT OUT AND IT SHOULD WORK.
SFC ANDERSON, RICHARD T US ARMY
Jul 08, 2008 | Eureka Vacuums
Vacuums Logo
299 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
