Panasonic HDTV 1080i Lamp out - Televison & Video
  • 3 more comments
  • Don Jaun Aug 22, 2008
    Panasonic 1080i 52" LCD HDTV - Got no picture and feel bulb is out - problem: can't get it out and have no manual that explains it - Please help if you can
    Don.claassen@avat,com or 319-360-5404
  • Anonymous Oct 15, 2008
    I have no picture
  • stephanie_wh Apr 11, 2009
    i have no picture on my tv it turns on and turns back off
  • Anonymous Apr 17, 2009
    ok well when i turn on my panasonic hdtv it'll take forever for it to actually be turn on and yah it shuts off after the green blinking light and then the light'll turn red and blink...it just takes forever for it to actually be on i dont' know how to solve this problem
  • Anonymous Apr 29, 2009
    I have the same problem - unfortunately, I know what the solution is, too. We've had this set since 12/03 and this will be the 5th bulb in as many years. We were covered for the 1st four years with an extended warranty, otherwise the lamp runs about $300.
We have a blue line across the bottom of our screen how do we fix it?
Posted on Dec 05, 2010
5 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: panasonic hdtv 1080i all of the sudden has double
Go INTO the customer menu and select CONVERGENCE--what you are looking for is will blue or red not move in some direction?
If you find in your case blue OR red is wacked and will not adjust let me know--I can post here start to finish instructions for this repair on this set.....
You only need to be able to know how to solder and get at the chips--you can buy a pair of the chips on Ebay for less than 14 dollars plus shipping.
If you cannot do it yourself--let me know and I will give you options.
I am here to help people--if this information helps you rate this solution--I do this here for free.
SD TECH
Posted on Nov 03, 2009
Testimonial: "Quick feedback with helpful questions."
  • 13 Answers
SOURCE: Panasonic HDTV 1080i Lamp out
If the lamp is actually out - replace it - if the lamp is still working just reset the lamp hours - at 10,000 hours it automatically says that but it is just the lamp time needing a reset.
Posted on Jun 02, 2009
vinnyq
  • 157 Answers
SOURCE: i got the 1080i panasonic hdtv which lamp
I would check the lamp first. These are the most common failures and can be replaced by the consumer with step by step directions in the user's manual. Check the lamp by removing the lamp door and checking the bulb. If you see either a shattered or cloudy bulb, then you need to get a new lamp.
Posted on Oct 13, 2009
Ecollier2012
  • 3459 Answers
SOURCE: convergence panasonic HDTV 1080i bbe hi definition
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 18, 2010
Do my panasonic hdtv 1080i need a converter box in order to work?
None of the newer style TV's need a converter box because all the tv channel tuners use a digital signal. The tv signal in the air is now digital when using a tv antenna.
Sep 13, 2015 | Panasonic Televison & Video
Does my panasonic hdtv 1080i pt-50LC14 have a lamp
Yes it does! Behind the front bezel under the screen. you can buy it here. http://projectorlamps.com/panasonic-dlp-tv-bulbs-pt-50lc14.html PT 50LC14 Panasonic Genuine High Quality Original Projector Lamps now...
Refer to the manual or the instructions that are shipped with the lamp.
Apr 25, 2015 | Panasonic Televison & Video
I got the 1080i panasonic hdtv which lamp indicator light flashes 4 times and wont turn on.what could be the problem.
Oct 13, 2009 | Panasonic PT-53WX53 53" Rear Projection...
I have a Panasonic HDTV 1080i 52inch TV that is 6 years old. When I turn it on, the green power light just blinks and there is no picture at all. Any advice?
Check the lamp. Detach the front cover, read the warning, unscrew the cover, look inside, undo the one and only screw you can find, and pull out the lamp module. (Without touching the lamp) have a look at the light. Can you see it smokey in colour, or is the filament broken? This is how the PT-50LC13-K that I found in the garbage behaved, and the lamp filament is toast. Just thought I'd share.
Oct 10, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Blury screen on panasonic 1080i hdtv
seeing double and a lot of green on my panisonic hdtv 1080i what do i need to replace?
Aug 23, 2009 | Panasonic Televison & Video
Panasonic HDTV 1080i Lamp out Panasonic 1080i 42" HDTV - - saying "lamp needs to be replaced, reset lamp" - - what does this mean and how do I fix it??
Jun 01, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
My picture is dark and have changed the brightness
Hello!
Well it seems that your lamp is about to go out, replacing the lamp might jus do it ! Also make sure you get a Philips lamps, they work like a charm.
And regarding the long plastic cover just be a little bity patient and you'll make it come off, just make sure you do remove all the screws.
Apr 18, 2009 | Panasonic PT-53WX53 53" Rear Projection...
This model is notorious for needing a new lamp about every 2 years. The lamp is accessed through the front by removing the long plastic cover under the screen (it just pulls off). Under that, to the left of center, is a square cover with one grey plastic screw. Loosen the screw and pull the lamp assembly out. It should just slide right out. Turn it around and look at the lamp. If the lamp face or reflector looks "cloudy" or "misty". Replace the lamp with Philips part number TY-LA1000. Just Google the number and you will find them available for around $100
Mar 18, 2009 | Panasonic PT-43LC14 43" Rear Projection...
Televison & Video Logo
2,789 people viewed this question
Top Televison & Video Experts
Electro Med Services...
