Question about Kenwood ProTalk XLS TK-3131 (15 Channels) 2-Way Radio
Keewood Protalk 2 way radio xls receives , but doesn't transmit
I have a protalk xls that will receive audio but will not transmit. When I attempt to transmit a message, it does a beep and the screen displays in a similar way to when it is just turned on.
I have already read the manual and reset it- any other ideas would be appreicated.
    Sergeant:
  • 250 Answers
Hello jf1111,
It could be a low battery. Does the screen go completely blank when you attempt to transmit? Two way radios draw a lot more power when transmitting then when receiving so a low battery might cause the radio to cut out when you press the Push-to-Talk and then the radios might appear to turn back on when you release the PTT. If this behavior persists even after charging the battery then the battery or charger (or both) might be defective.
If the battery isn't the issue then the radio could be programmed incorrectly. Does the problem occur on all channels or just one? The Kenwood ProTalk requires dealer programming with a software kit to set the frequencies for each channel. A channel that is programmed for an out of bounds frequencies would generate an error when the PTT is pressed. You might need to have the programming checked out by your local Kenwood Two-Way radio shop.
Best Regards,
Ken
"Go Ahead. Use Us."
Posted on Jun 23, 2008
    Scholar:
  • 66 Answers
Agent Ken is right, 2-ways do use a lot of power just to transmit. But the battery isn't the only problem, nor is the programming, it is the manufacturer. Kenwood makes respectable 2-way radios, but I've never been a fan of them, if you want powerful transmit and better range, I'd recommend you use Midland 2-ways. They're much more reliable and way more powerful. As an expert in radio communications, I'd have to say that Midland is you ticket to a better radio.
Good Luck!
Posted on Jul 08, 2008
I have a number of Portalk xls 3230 hand held radios from a number of years ago. Just bought 2 more. Can I use them together and how?
if they all operate on the same frequency there will be no problem
if there is take them to a radio repair shop, and have the frequence band adjusted to the base station frequency
Aug 09, 2016 | Kenwood ProTalk XLS TK-3230 Business Two...
Kenwood Protalk tk-3200U8P will receive, but not transmit. When talk button is push a loud beep will sound. Any suggestions?
Assuming it is programmed correctly, it is a weak, undercharged or bad battery. Transmit takes a lot more power than receive. A beep or no transmit, even if the Transmit light comes on can still mean the battery condition described.
Feb 11, 2015 | Kenwood Radio Communications
I need to know what replacement antenna to get for my tk-3130
I found the manuals at:
http://www.hitechwireless.com/products/Kenwood-TK%252d3130-ProTalk-XLS.html
This radio is a UHF radio but it doesn't saw on the site what the frequencies are or the type of antenna connection, BNC, SMA, ?
The manual shows 464.5 MHz to 467.925 MHz so an antenna for 464 - 468 MHz would do.
Manual also at: http://kenwoodusa.com/
Contact form at: http://www.kenwoodusa.com/Contact/
See if they have a replacement antenna for you.
Oct 24, 2013 | Kenwood Protalk XLS TK-3130 (2 Channels)...
I have a tk-250 I can receive calls but cant transmit when I go to talk and all it does it beeps what do I do
You may have the "tx offset" turned on and may be trying to transmit on a frequency that is considered "out of band" for the radio. Or the frequency you're attempting to transmit on is simply out of band for that radio. It depends on where in the world you're using the radio. If it was a Euro or Japan radio and you're in the US or South America, the bands are different.
Sep 16, 2013 | Kenwood ProTalk XLS TK-3131 (15 Channels)...
I can't hear the other radio on the kenwood ProTalk XLS
DQT - "Digital Quiet Talk" You have inadvertently turned on "digital squelch". Turn it off and you'll hear again.
Apr 17, 2013 | Kenwood ProTalk XLS TK-3230 Business Two...
I have 10 kenwood protalk xls tk 3130 two of the radio's allow you to talk and you can hear on all ten, but the other eight when you try to talk it is nit heard on any of them. I have reset all ten...
You have two that transmit and receive?, if so, you're doing better than some. The other 8 seem to receive well, which makes them ideal for monitoring stations.
I would not fork out too much cash to get them fully operable, as it really isn't worth it, the chances are they have at some stage or other been dropped, knocked about and worn out with (mis)use.
Better you savadamuny, and concentrate on the two that are operational.
Cheers,
Peter
May 18, 2012 | Kenwood Radio Communications
My new kenwood protalk tk 3130 wont talk to me old 3130
Look at the user manuals for both radios and compare the frequency assignment for each channel. find the ones that match and program the radios to talk to each other.
Patrick
Nov 18, 2008 | Kenwood ProTalk XLS TK-3131 (15 Channels)...
FreeTalk 3131 compatible with proTalk radios?
Hello Christian,
Some of the Kenwood ProTalk series radios may be programmable by the dealer to operate in the 462-468 MHz range used by GMRS and FRS radios. However the radios are not FCC approved for those channels and do not comply with requirements for FRS and GMRS radio equipment.
You are going to be better served by picking up a FreeTalk 3131XLS like your friends have. In terms of style and features this radios is very similar to the ProTalk but is type approved for use on GMRS.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 21, 2008 | Kenwood FreeTalk XL TK-3101 (15 Channels)...
Battery
Not sure I understand what you want. If you need to buy some new batteries, do a google search. They're available at many sites....
Geno
Feb 21, 2008 | Kenwood ProTalk XLS TK-3131 (15 Channels)...
Kenwood ProTalk XLS TK-3131 (15 Channels) 2-Way Radio Logo
391 people viewed this question
Top Kenwood Radio Communications Experts
eradiostore
eradiostore
Jaime Hernandez
Steve
Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
