Question about LG LH-D6230 System
No Audio from Input
It had problems to read the discs so i open the box and cleaned up the lens and worked fine, and it was a dvd disc playing and i saw a microswitch button on the component tablet and i pushed, and the dvd player turned off, like a restart, and since then i can watch the dvds and listen them but i dont have audio from any other source, i can see the both input video but no sound, from radio either. Thanks for your help.
  • ngufoo Jul 21, 2008
    My 5.1 channel became 2.1 channel. What is going on? It play normally
    last few days. When i check in SETUP menu, surprised that audio setting
    change to 2.1 channel. No matter how i reset it , off power, push the
    microswitch on the PCB board, still cannot turn it back to normal.
    Anybody can help.....from malaysian
  • chiefosei2k4 Oct 19, 2008
    no sound coming form my system, just audio, everything is hooked up correctly, anyone with any suggestions?
My 5.1 channel became 2.1 channel. What is going on? It play normally last few days. When i check in SETUP menu, surprised that audio setting change to 2.1 channel. No matter how i reset it , off power, push the microswitch on the PCB board, still cannot turn it back to normal. Anybody can help.....from malaysian
Posted on Jul 21, 2008
When I open my Philips DVD player and put in disc it will not load and tells me NO DISC. Please help!
You might want to try using a DVD lens cleaner disc like the Philips CD/DVD Laser Lens Cleaner SVC2330 or SVC2520 or equivalent from many AV accessory vendors to help restore the cleanliness of the player read lens, so that its ability to read discs is restored. These discs have a tiny brush stuck onto the "playing" surface that polishes the lens, when the disc is played as normal. There is often an audio commentary to go with the cleaning.
Sep 13, 2017 | Philips Televison & Video
Dvd does not read loaded disk
Have a detailed answer on wiki.answers under how to fix a dvd player. My conclusion is : 1. If the cd or dvd player won't start a disc (might display 'no disc') open the box and get good access to the laser lens (quite easy in many models). Clean the lens with an ear-bud (q-tip) and add some alcohol (I used after shave) on to aid the clean if there are still reading problems. Persevere with cleaning before trying option 2.
2. If it's selectively rejecting certain dvd's (and the problem might have become worse with time) consider ever-so-slightly bending the fine wires that suspend the lens over the laser, in an upward direction. Be very careful and read all the observations above first (on Wiki).
Jan 20, 2013 | Televison & Video
Technika combi unit dvd player wont read discs anymore
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it cannot read data/files on DVD discs.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Regards.
Jan 12, 2012 | Televison & Video
I get a no disc message on my LG RC897T when I try to play a factory disc, however it plays any disc that I have burned on my computer. It also plays cds fine.
Good luck.
Aug 11, 2011 | LG RC897T DVD Recorder/VCR Combo
Its says no disc when I have a dvd in it?
Yours sincerely.
Elect_Comp.
May 16, 2011 | Sanyo DVW-6100 DVD Player/VCR
When I try to use my dvd player I put a disc in it says loading them it comes up and says bad disc, it will also do this if there is no disc inserted into it, can you help me? I don't know the model #...
Yours sincerely.
Elect_Comp.
May 15, 2011 | Koss KS4110 DVD Player
DVD player purchased 8/4/10 will not read disc. Model SD7300. Have used the cleaner disc.
Regards.
Apr 14, 2011 | Toshiba Televison & Video
WON'T PLAY CD'S READS "NO DISC"
  • Check the disc you're using for scratches and dirt. If the disc is damaged it won't play properly, regardless of the CD player's ability to function. You can use a CD repair device like the "Disc Doctor" to repair the CD or purchase a new CD.
  • Clean the laser lens with a CD laser lens cleaning disc. CD laser lens cleaning discs can be purchased at most electronics retailers or online. Insert the laser lens cleaning disc and follow the instructions.
  • Insert a correctly-formatted, undamaged disc into your player. Listen to see if it begins to read the disc. If it continues to make no sound and gives you the same message, then the problem is probably that your disc is not spinning in the device.
  • Clean the lens while the DVD player is open. A dirty lens is most likely the cause of your no-disc error. The lens should be cleaned with isopropyl alcohol and a cotton swab.
  • Dec 11, 2010 | Sony CMT-EP505 CD Shelf System
    I think my lens is weak, the cd has to be ejected and inserted a couple of times before it works
    Like any system, Xbox consoles require occasional cleaning to remain in peak condition. If you're experiencing skipping, poor sound quality, increased loading time, or any number of technical annoyances, simply cleaning your Xbox lens may correct the problem. The lens is responsible for reading all the data on your Xbox game discs; it is the most important part of the entire system. Cleaning the lens takes only a few minutes with the right cleaning product and know-how.
    Difficulty: Easy
    Instructions
    Things You'll Need:
    * CD lens cleaning disc
    1.Purchase a CD lens cleaning disc. It is important that you buy a lens cleaner for a CD player, not a DVD player. Classic Xbox consoles are not DVD compatible, but they can play CDs. Some lens cleaning discs are marketed specifically as Xbox 360 cleaners, but these may not work in an original Xbox if the disc is DVD-formatted.
    2.Turn on your television and Xbox just like you normally would to play a video game.
    3.Open your Xbox's disc drive, placing the lens cleaning disc in the drive face-up. A lens cleaning disc works by sweeping small brushes over the laser lens surface. These brushes are located on the bottom of the disc; be careful not to touch the brushes---the microfiber brushes are delicate and can become damaged easily.
    4.Close the Xbox and let the machine power up; make sure your television's volume is turned on. Your Xbox should automatically take you to the system's standard CD player menu. If this does not happen, select the menu manually using your Xbox controller.
    5.Begin playing the first track of the cleaning disc. Listen carefully, because audio directions will play indicating the steps necessary for properly using your cleaning disc. Each brand of lens cleaning disc will have different steps, but they are typically very simple, involving tasks like skipping ahead to different tracks or briefly putting the CD in fast forward mode. If you cannot hear the audio directions, consult the written instructions packaged with the disc.
    6.Remove the cleaning CD after you've followed the audio directions---a typical cleaning cycle only takes a few minutes, and the audio directions will tell you when cleaning is complete.
    7.Carefully place the lens cleaning disc back in its case, avoiding damaging the brushes on the bottom. Lens cleaners can be used multiple times, so plan on using the cleaning disc regularly to help avoid future problems with your Xbox console
    Aug 19, 2010 | Microsoft Xbox 360 Console
    RE: Problem with SAMSUNG DVD-R135
    If I understand correctly It would play DVD-R just fine & then it was no longer able to read them. If this is the case, are you using the same brand of DVD-R discs? Some read better than others Try using Imation they seem to read in alomost anything. If you still have problems I would suggest opening the unit & cleaning the lens with a cotton swab lightly soaked with rubbing alcohol. Especially if it has been used in an enviroment wich is dusty or the unit has been smoked around. If it worked correctly in the first place I would assume a firmware update would not fix the problem. It is harder for the drive to read a burned disc than a pressed disc so that is why I recomend cleaning the lens. It has always worked for me.
    If it still will not work then I would say that the laser pickup is failling, If thats the case in time it will no longer read retail DVD's
    Feb 17, 2008 | Samsung DVD-R135
    LG LH-D6230 System Logo
    263 people viewed this question
    Top LG Audio Players & Recorders Experts
    PNiss
    Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
