Question about Vacuums
New carpet, clugs the vacume hose. how to unglug?
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=689522
Generic problem for all Vacuums
New carpet, clogs the vacuum
Posted by dpatricksr70 on Jun 20, 2008
New carpet clogs the vacuum hose.
How to unplug?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Also, we you like to know the brand name and model # of the vacuum. Some of the ways are to use a round metal ball or marble to see where the clog is in the hose and then you can use such things as the end of a broom handle, or you can use a wire coat hanger and bend the end to make a little hook and then try to grab the clog and say fish it out – or if you have another canister or shop vac you can tune on both canisters and try to pull the clog apart and sometimes that works as well – just be careful so that you do not puncture the electric hose because they are expensive in the area of $100.00 or more in some cases. If you need further assistance please feel free to contact your local vacuum cleaner dealer in your area.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 23, 2008
Vacum has suction, but won't pull debris from the floor
The vacuum may not be set for use on carpet.
Jan 19, 2017 | Vacuums
How to more easily vacum plush carpet with oreck XL vacum
The only Oreck vacuum cleaners that are rated for plush carpets are the two Magnesium models.
Jun 25, 2014 | Oreck XL Ultra Bagged Upright Vacuum
No suction in dyson vacum
have you tried cleaning that round foam thing? if that is cleaned and air dried it usually will work after that.
Jan 06, 2012 | Vacuums
My Hoover vacuum cleaner is not picking up from the carpet like it used to. Like it's having difficulty picking up strings, fuzz, etc. from the carpet. Suction power seems to be fine. The belt and the...
YOUR VACUME SHOULD HAVE A HOSE THAT PLUGS INTO THE LOWER PART OF THE VACUME OR MAY COME APART AT THE BOTTOM . IT SOUNDS LIKE THE TUBE IS STOPPED UP AT THE FAN MOTOR
Jan 16, 2011 | Hoover Vacuums
The vacume was plugged. Believe I unplugged it, but now it just blows air OUT, does not **** in. Everything is emptied and cleaned. Don't know what to do next. Just had new carpet installed today, and...
Even tho its empty and clean, if the hosing is blocked up then it will not **** up anything.
The hosing down below the attachment hose may still be blocked up and that will have to be cleared for it to suction again.
remove the attachment hose look down the hose at the back. you can also flip over the machine and look for the attachment hose to come to the brush roller. I assume it is blocked up there and not picking up properly.
Good luck.
Nov 06, 2010 | Hoover Elite Rewind Bagless Upright...
New carpet has clogged the vacume hose. How do I clear it out
The easiest way I've found is to disconnect the hose at both ends, and GENTLY push a broom handle through it while removing the stuff from the other end. Unhooking it allows you to lay the hose straight. Adjust your head height to where you just hear it hitting the carpet, then raise it one notch. The brush is designed to (and this is a secret the salesmen won't tell you) just touch the top of the carpeting to get it moving so the dirt becomes loose, the suction does the rest. Too low and it just forces the carpet to lay over and traps most of the dirt.
Nov 02, 2010 | Kenmore 23812 Progressive PowerMate Bagged...
While vacuuming, the unit will stop/shut down. A short time later the unit will operate again but not for much longer. All filters are clean/new.
Check your hose for a clog. It's likely there is a plug somehwere. Run it (not while vacuming the carpet) with all three filters removed. See if you get good suction. If not then look around for a plug of dirt and hair somewhere.
Jul 24, 2010 | Bissell 3750 Lift Off Bagless Upright...
We have the Eureka EZ Kleen upright. We have suction through the hoses but not the main vacuum. The brush turns fine but the vacume does not **** anything up.
THE HOSE BETWEEN THE DETACHABLE WAND AND THE BRUSH ROLLER AREA MUST BE CLOGGED WITH CARPET FIBERS. CLEAN IT OUT AND IT SHOULD WORK.
SFC ANDERSON, RICHARD T US ARMY
Jul 08, 2008 | Eureka Vacuums
Cluged vacume hose, new carpet
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=689534
Clogged vacuum hose, new carpet
Clogged vacuum hose, new carpet, have been through two vacuums already.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. When vacuuming it is a good idea to give your vacuum a burst of air once in a while to clear the hose and push the dust and dirt into the bag, simply just lift up on the powerhead or vacuum hose and give it a burst of air every 5 or 10 minutes. Also, we you like to know the brand name and model # of the vacuum. Some of the ways are to use a round metal ball or marble to see where the clog is in the hose and then you can use such things as the end of a broom handle, or you can use a wire coat hanger and bend the end to make a little hook and then try to grab the clog and say fish it out – or if you have another canister or shop vac you can tune on both canisters and try to pull the clog apart and sometimes that works as well – just be careful so that you do not puncture the electric hose because they are expensive in the area of $100.00 or more in some cases. If you need further assistance please feel free to contact your local vacuum cleaner dealer in your area.
Go Ahead. Use Us.
Jun 20, 2008 | Vacuums
Vacuums Logo
57 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
