Question about Motorola Mobility RAZR V3
Display The top display where I have the menu options is not working
    Brigadier General:
  • 7,752 Answers
You need to take the phone and have the flexcable replaced.
Posted on Jun 22, 2008
Make google my homepage
Display the Menu Bar. Then Tools, Internet Options and in the Home Page box type www.google.com and click OK.
To display the Menu Bar: Right Click on the top bar of Internet Explorer and Left Click on Menu Bar.
Dec 19, 2013 | Computers & Internet
How do you tune in a sense 51 - 19dvdw tv to channels
First check your aerial.
If other devices such as PVRs or other TVs can receive a signal then the Sense 51-19 should be OK also
Turn on the TV.
Press the "TV/.AV" button until the letters "DVB" (Digital Video Broadcast) appear on top right of screen.
Wait until patterned blue screen is displayed and the message "No Signal" is shown.
Press "SYS MENU" 3 times
"General Menu" should be displayed with Language option in highlight.
Press the "CH+" button once to move the highlight to the "Reset" option.
Press the "TV/TXT-DVB MENU" (this has the letters "SET" engraved on the button itself.
The TV will mute and a sub-menu will be displayed in the top left of screen.
Use the "CH+" or "CH-" to scroll to the desired option.
Cheers
May 23, 2012 | Televison & Video
How to delete phone numbers
How Do I Create, Delete, Transfer & Manage My Contacts On My SGH-i897 (Captivate) Phone?
Creating A Contact
  4. Tap on Contacts
  6. Press the Menu Key menu%20key%2025x.jpg and tap on Create
  8. Tap on a location for the contact to reside (recommend phone due to supporting more data fields)
  10. Tap the each field, adding the desired information
  11. Tip: Tap the - or + signs to remove or add a field
    creating%20contact%201%20200x.jpgTip: To add even more fields, scroll down to the bottom of the contact and tap Add more fields.
  12. Tap Save to save contact.
Top
Deleteing A Contact
  4. Tap on Contacts
  6. Tap on a contact
  8. Press the Menu Key menu%20key%2025x.jpg and tap on Delete
  10. Tap on Ok to confirm deletion
Top
Importing/Exporing From MSD Card
Importing
  4. Tap on Contacts
  6. Press the Menu Key menu%20key%2025x.jpg and tap on More, Import Export. Tap on Import from SD card
  8. The handset will ask to where to create and file contacts, the option for Phone was selected
  1. The handset will ask to where to create and file contacts, the option for Phone was selected.
  2. Note: If you have several vCard files, you may receive an additional screen prompting for options to import a single file, multiple files, or all.
Top
Exporting
  4. Tap on Contacts
  6. Press the Menu Key menu%20key%2025x.jpg and tap on More, Import Export. Tap on Export from SD card
  8. The handset throw a confirm prompt for coping, tap Ok to continue
Top
SIM Management
  4. Tap on Contacts
  6. Press the Menu Key menu%20key%2025x.jpg, tap on Miore, tap on SIM Management
  8. Tap on either Copy Contact To or From
  10. Tap on either Copy Contact To or From
Top
View/Filter Customization & Display
  4. Tap on Contacts
  6. Press the Menu Key menu%20key%2025x.jpg, tap on Display options
  8. Tap on the desired display filters and then tap done
  9. display%20options%20200xx.jpgTip: Instead of tapping display options, tap More, Settings. Tap on Order of display name and choose how the name is displayed
    display%20name%20order%20selection%20200x.jpgorder%20of%20display%20name%20settings%20200x.jpg
Top
For more information on the SGH-i897 Captivate, a Galaxy S phone, please click the banner below.
Oct 05, 2011 | Samsung Galaxy S GTI9000 Smartphone
My lg xcanvas 42 plasma is in korean language.i know english.how to change
Hi.
You need to reach the Option menu, and to set the language. You will have to do this working on the Korean menu. I hope that the pictures below may help:
Press MENU button on remote, and go to OPTION menu, which is the one with a tag picture, right on top of the padlock pic.
Use the arrow buttons to select language. use arrow right to confirm and up and down to select.
Below a manual for this model:
LG 42LC2D
Regards.
Ginko.
Jan 28, 2011 | LG 42LC2D 42 in. LCD HDTV
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
OSD OPTIONS:
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
screen,
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
modes.)
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
Jun 21, 2010 | Gateway EV 910 19" CRT Monitor
PCV-RX580
ok, you press F2 or F3 to enter into the bios setup.
Thanks
Oct 27, 2009 | Sony VAIO Digital Studio PCV-RX580 PC...
Multimedia audio controller for my compaq evo pentium 4(my sound is not working)
1. Right click on Mycomputer, select properties
2. Select hardware
3. Select Device manager
4. double click on the sound,volume and controller
5. if any yellow color pointed is displayed on any option then right click on the option and uninstall it
6. then select Action from the menu bar on the top and select scan for hardware changes
**** after doing this.. you can check the follwoing steps for trouble free ******
7. double click system device
8. if any yellow color pointed is displayed on any option then right click on the option and uninstall it
9. then select Action from the menu bar on the top and select scan for hardware changes
10. then it will start scanning your new hardware and ask for the installation drivers.
Jun 29, 2009 | Compaq Audio card Sound Card
Speakers not working
2. Select hardware
Jun 21, 2009 | HP Pavilion dv6000z Notebook
I have compaq presario C700 Laptop model no. C772TU having sound problem in windows XP SP-2.
soundcard problem solution
2. Select hardware
4. double click system device
7. then it will start scanning your new hardware and ask for the installation drivers.
if not sovled try this..
8. Right click on Mycomputer, select properties
9. Select hardware
10. Select Device manager
11. check is there any yellow color pointed is display on any option if yes,then right click on the
12. then select Action from the menu bar on the top and select scan for hardware changes
13. then it will start scanning your new hardware and ask for the installation drivers.
14. then goto system device
15. double click system device
16. if any yellow color pointed is displayed on any option then right click on the option and uninstall it
17. then select Action from the menu bar on the top and select scan for hardware changes
18. then it will start scanning your new hardware and ask for the installation drivers.
19. close it
20 restart your computer
I believe your problem may solve..
regards
Ehsanullah.
Jun 18, 2009 | Compaq Presario 700 470024-192 Notebook
How do i get brighter pictures
There are only two options for adjusting the brightness of pictures in this camera, exposure and flash setting.
1. Flash Options: The flash is off by default. To turn it on you must press the button with the crooked down-arrow label between the DISP and MENU buttons, and the flash status will display in the top right-hand corner of the display screen. OFF displays the crooked down-arrow and a circle with a line through it. Press the button once for AUTO, displays the crooked down arrow with an "A" next to it. Press the button once more to force the flash, displays the crooked arrow only in the top right-hand display. Regardless of mode, the display will blink rapidly while the flash is charging and remain solid when it is charged and ready for use. Keep pressing the crooked down-arrow button to scroll continuously through the three OFF/AUTO/ON options.
2. Exposure setting: Press MENU, then the left arrow on the top right-hand four-way button on the camera until the COLOR menu is selected. Scroll down to EXPOSURE and press the MENU button again. You will see EV on the display. Use the up and down arrows to increase or decrease the exposure setting. 0.0 is default, you can go up to +1.5 or down to -1.5. Press MENU to exit when you're done. +1.5 would be the maximum brightness setting.
Oct 13, 2008 | VuPoint DC-M306AT-VP Digital Camera
Motorola Mobility RAZR V3 Logo
14 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
