Question about Compaq Computers & Internet
Compaq my computer power supply fun does not rotate , the machine cant boot but the board shows some power
  • 85 Answers
Without a visual inspection it sounds like the PSU is damaged, it is possible that the standby power is reaching the motherboard but the main circut is bust. i would replace the PSU with one of the same watt rating.
Be aware that incorrectly installing a power supply can cause damage to other componets or yourself. If in doubt see professional advice
Posted on Jun 20, 2008
Cant find motherboard pdf schematics to download and repair my pcs
The only way to find these is to poke around on the internet with .RU domains.
Feb 20, 2014 | Computers & Internet
Booting up computer after a power outage
did you check the power supply if it is working?.look for the exhaust fan if it is rotating. then look at the mother board if the fan at the processor is also rotating if not check the supply first at the PSU if ok.
Jun 05, 2012 | Lenovo Computers & Internet
After powering on monitor says no sync
I've almost the same problem. When the system turns on the monitor doesn't sync. After a variable trials with down/up the sync is enabled and the computer starts.A very clear event occurs : when the monitor can''t sync ( and system doesn't boot)you can hear very clear a high fan rotation. When I look/hear in the system the Isuspect the cpu fan. The system boots ( monitor syncs) when the fan rotationgoes from high to low. So the system hangs on an internal check on the rotation speed of the cpu fan.I've googled a lot , but until now doesn't find an answer . Possibilties which I think about : replace cpu fan , clean cpu fun ( but it looks clean).I cannot measure the fan rotation speed when the system is hanging. At normal rotation all info can retrieved witth the program cpu-z.Did you already have a solution ?
Dec 07, 2011 | Compaq Presario 5000 PC Desktop
Normally when a computer beeps repeatedly it means either you power supply has failed or *********** board, to test this get hold of another power supply that you know is working and use that one to boot your mechine, if you have the same problem then unfortunatly *********** board has failed and will need to be replaced. hope this helps
Sep 26, 2010 | Computers & Internet
Power light flashing HP Compaq Presario SR1230NX PC Desktop I powered the unit down; when I tried to powered it up the only reaction is a green led flashing. The led is located in the back close to the...
Sounds like the Power Supply is bad likes its not able to power on itself. Best thing to do, try a different known good power supply and attach it to the motherboard, if you get the same symptom with the machine not powering on then its a bad motherboard. If the machine does power on then you know your original power supply is bad.
May 28, 2009 | HP Compaq Presario SR1230NX (PJ518AA) PC...
Computer stays on bios page
Hello there
first i would remove the battery on the board and see if it is good if so replace it and now remove the power supply to the motherboard for 2 min and press the power on button and the reset button
now plug in the power supply to the motherboard back on and plug in the computer now you should just have top reset the time and date ok?
best regards michael
Apr 05, 2009 | Compaq Digital PC 3100 PC Desktop
No booting
plz try with new power supply
May 22, 2008 | Computers & Internet
Canon CLC 1150 - E804
it may be the fuse board or the relay near the fuse board that is arcing
May 19, 2008 | Canon CLC 1150 Color Copier
I need some help form you
sounds like you have a duff PSU, it will need replacing or it will cause the system + PSU to overheat
Oct 12, 2007 | Compaq Armada M700 Motherboard w/Pentium...
Computers & Internet Logo
187 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
