Question about GE Washing Machines
Model# WCCB1030H0WC Serial RM190013G Commercial washer wont run, replaced board and timer, also found basket loose and tighted nut still no help. Do you have an authorized repair person in Alb. NM zip 87109. Please call or email Joe at 720-934-2354 or joep@martinray.com tks joe
the dr
  • 447 Answers
SOURCE: Intermittent spin cycle on Kenmore 90 Series washer
You may try the speed selection switch.....Ive had problems with these.
Posted on Jan 23, 2008
dutchman05
  • 487 Answers
SOURCE: Water won't stay in washer ...
either the pump is broken or the drainhose is lose or too low.
There is also in this machine something called a drain protector. This might be faulty too and i think that would be the cheapest to see about that first
LINK for the water drain including all parts
LINK for all machine parts motor and pump
Posted on May 01, 2008
jsrock516
  • 5911 Answers
SOURCE: Kenmore Elite Oasis Washer
The problem is the User Interface board behind the control panel. This is a noted problem that often occurs with this model washer. The only option, I hate to say (unless you want to listen to the washer beep all the time) is to replace the board.
The part(s) you need are available at searspartsdirect.com. Simply type in your model number and look under the "Control Panel Parts" heading for item number 7 (User Interface - part #8564393). You may also consider item number 12 (User Interface Harness - part #3407184) to rule out the possibility of a bad wiring harness. You can try to do end to end continuity checks before considering a replacement just to be sure. The contacts are sometimes difficult to get to with a multimeter, though.
This is a fairly simple repair to accomplish on your own. Just follow these steps:
1. UNPLUG the washer.
2. Remove the three screws in the back of the console.
3. With the screws loosened, the console will come of by lifting from the back first. Use care not to damage the small wire harness under the console.
4. Remove the wire harness from the User Interface board and remove the knob (by pulling) from the front panel. Lay the entire control panel face down on a soft surface (like a stack of towels).
5. Carefully remove the white plastic cover plate that is installed over the control board.
6. Once the cover is removed, carefully remove the old interface board by prying gently on the series of tabs around the perimeter of the board. There may also be some mounting screws to remove as well.
7. With the old board removed, carefully install the new board by inserting the control knob shaft through the hole first. Then, gently snap the board in place, making sure all the tabs around the perimeter of the board are in place. Reinstall any small mounting screws. NOTE: Do not handle the surface of the board with your hands. Handle the edges only, to avoid electrostatic discharge from your body causing damage to the board.
8. Reinstall the protective plastic white cover over the interface board.
9. Flip the console upright and reinstall the wiring harness and control knob (The knob only goes on one way).
10. Carefully insert the console in the front grooves on top of the washer, first. Then lower the back and reinstall the screws.
The repair is pretty straight forward. However, if you have questions, please post back and let me know. I hope this helps you.
PS I tried to find parts for this washer at others websites, but could not find a listing for it.
Posted on Jul 19, 2008
  • 91 Answers
SOURCE: Kenmore Model 417.44072300 Front Load Washer Kenmore Model
unless you have alot of money to throw away ,, will run you about 600 to repair washer ,,,not a really good investment ,,
Posted on Jan 04, 2009
canbruce75
  • 1776 Answers
SOURCE: Kenmore Washer, Loose Timer Knob
There should be a spring clip that holds the timer knob on. It or the timer knob may need replaced. Here is a picture of the timer knob and the spring clip. Sure hope this helps and best wishes.
Posted on Jul 24, 2009
Putting a clutch together
hi there you need to take the clutch cover off after draining the oil ,remove the bolts going into the clutch basket take the springs out as well if you have the cash put in new springs when installing the clutch ,after you take the outer off then take out the plates and have acheck on size and wear ,then there should be a large nut and lock washer tap down the tab that stops the nut spinning loose then put your foot on the back brake and undo the nut this will be very tight if you have a air rattle gun this makes life a lot easier .then replacing the clutch basket it would be good sense to put a new bearing in the clutch houseing then put it back together in the oposite direction cheers hopes this helps cheers
Mar 27, 2014 | Husqvarna TE 610 Motorcycles
Maytag washer top load ser# mvwx600xwo It's making
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Washer-Parts/Model-MVWX600XW1/3048/0153200/W1104178/00004?blt=06&prst=&shdMod=
go here and look at parts,the nut number 14 in diagram comes loose and this causes noise from parts not lining up,this is an easy check,pull the washer forwards and then tilt it back against the wall, remove the bottom panel and then remove the shield part number 20 in diagram,check the nut and see if you can push the parts up that are above the nut,i've found this nut loose in a few machines,when you buy the new nut it has blue lock tight on the treads,if it is loose and you have some blue lock tight you can try adding some to the treads or buy a new nut if this is what you find,otherwise without being there i couldn't really help you out but check that nut first.
Apr 07, 2013 | Washing Machines
I have a model GHW9150PWO. I have plastic shaving behind front rubber and the plastic around the drum is all chewed up. The barrell appears loose. I'm fairly handy and I want to know if this is...
Hello, Thank You for using FixYa. I will be helping you today.Check that the pulley nut in back did not come loose..If it is tight you may need to replace the spin basket And tub.Also make sure when the center pulley nut is tight there should be no play in the pulley or spin basket.
Thank You and please rate my answer if it was helpful..
Jun 17, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer clunks when spinning & the plactic sheild between stainless steel tub & gray rubber seal is chewed. Any solutions to the problem would be greatly appeciated. This is a Whirlpool Duet model...
Hello, Thank You for using FixYa. I will be helping you today.Remove the back panel the center nut on the pulley may be loose and most of the time the pulley needs to be replaced when this happens. If you remove the nut you can see the pulley should be tight around the shaft its in no play or movement. If its ok tighten the nut and you should be good. If its not loose you would have to replace the front and rear outer tubs and spin basket which is well over $500.
Jun 12, 2011 | Washing Machines
How do you disassemble the Badger5 1/2 horsepower sink erator.model #5-81
The badger has two parts:
1) The sink strainer basket that attaches to sink with three screws visible from below.
2) The disposal which connects to sink basket with connector ring.
There is a rubber washer between disposal and sink basket
If you drop disposal loose from the sink, you can get spoons and other stuff out.
The disposal itself does not come apart for repairs.
I wrote tips for replacing disposal, which include information you might be able to use:
When I worked apartment maintenance, we replaced disposal with same brand disposal.
That way we didn't have to change out sink basket or move pipes around under the sink.
How to: Disconnect 2 nuts on p-trap and trap falls loose.
Rotate steel connector disk that holds disposal to sink basket, and disposal comes off.
Before installing new disposal.
Attach electric wire to new disposal, and push in reset button.
Attach dishwasher tube to new disposal. Knock out plug inside dishwasher opening.
Push new disposal up into place, and attach to old sink basket.
There is a rubber washer between disposal and sink basket, use new washer.
Attachment ring catches at three points, all three have to connect.
You can use bottle jack to lift disposal if you have problem.
Re-assemble tubular pipe.
If this is your home, you want new sink basket that comes with new disposal because it looks shiny and new.
Buy a tub of plumbers putty also.
Remove old sink basket and clean sink opening.
Put finger-size roll of plumbers putty around sink opening, and then push new strainer basket into plumbers putty.
Tighten basket from below, wipe away excess putty around sink opening.
Install new disposal as described above.
Tips for tubular pipes:
When taking apart tubular pipes, start at p-trap and take apart as few pieces as needed to do job.
On image below, loosen both upper and lower nuts, trap falls loose, and then work on disposal.
Any tubular drain pipe that gets moved while working under sink needs to be disassembled, cleaned and re-assembled.
Metal pipes have rubber washer >> always use new rubber washers.
Plastic pipes have plastic washers > plastic washers can be cleaned and re-used.
Plastic washers have flat side that goes toward nut, tapered side away from nut.
When reassembling tubular pipe, we use rectorseal on washers and joints.
Slap a good amount on washer just before pushing washer in place and attaching nut.
Rectorseal will ensure tubular drain pipes won't leak.
Add a comment for more free help.
Also take advantage of fixyas phone service.
For a price, fixya expert speaks with you over phone while you work on disposal.
Jan 03, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
One of the grinder broke inside the unit, is this a replaceable part?
If disposal has loose parts inside, you have to replace the disposal.
If disposal still work and doesn't vibrate and loosen pipes under sink, then it's ok.
The don't sell replacement parts for disposals.
I wrote tips for replacing disposals:
Attach electric wire to new disposal.
Use new connector washer.
On image above, loosen both upper and lower nuts, trap falls loose, and then work on disposal.
Jan 01, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
What cause my washer to make a rumbling sound when it is stopping from the spin cycle?
This assumes that you have a KENMORE top load, direct drive, neutral drain washers are made Whirlpool.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
The problem points to the brake.
The washer uses a brake system to stop the basket at the end of the spin cycle.
Just like a brake on a car, it's designed to slip a bit so that the basket / car doesn't come to an abrupt halt.
Over time, the brake shoes can jam against the brake drum and bring the basket to a halt too quickly with a lot of noise.
A way to solve this (that I tried and it works) is to pull the basket tube / brake assembly and if the brake shoes look OK, spray a small amount of silicone spray on the inside of the brake drum.
Following is a description of how to remove the cabinet, pump, motor, transmission and basket drive tube on Whirlpool / Kenmore / Roper direct drive washers.
As an aside, you don't need a special spanner wrench to remove the spanner nut. I've found that a short (10") pipe wrench hooked over one of the spanner nut tabs and tapped with a hammer will usually loosen the nut. Also, rather than hitting the Drive block directly with a hammer, put a short piece of wood under it first to protect it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Following are the Whirlpool Service manual for this type of washer and the Whirlpool parts list for their commercial washers although the consumer models are basically the same.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Jun 06, 2010 | Kenmore 2303x Top Load Washer
At end of spin cycle the drum doesn't stop immediately; Instead it takes about 4 seconds and has loud noise like airplane during this time...
KENMORE top load, direct drive, neutral drain washers are made by Whirlpool.
(See the following Whirlpool /Kenmore Service manual)
the problem points to the brake.
Over time, the brake shoes can wear or the springs can get weaker or break.
Following is the Whirlpool parts list for their commercial washers although the consumer models are basically the same.
Whirlpool has replacement brake shoes and springs.
Mar 29, 2010 | Kenmore 25842 Top Load Washer
GE commercial washer wont spin or drain
If your washing machine is 20+ appliance years old, it's probably due for replacement.
Jul 15, 2017 | GE WNRD2050DWC 3.5 Cu. Ft. Commercial...
Timer type
Give your parts distributer your model and serial number and they can get you the proper timer.
Oct 03, 2008 | GE WCCB1030 Top Load Washer
Washing Machines Logo
49 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
