Question about Toshiba TP50H50 50" Rear Projection Television
Finding a screen / cutting down a screen
I have a completely smashed screen, Toshiba does not make a replacement anymore, can you cut down a larger toshiba screen? Are they the same?
  • Toshiba Master
  • 8,617 Answers
The outer one you can, but the inner one if you notice has a circular pattern, I have had customers try but they have complained of clarity issues after doing so. Try getting a used one.
Posted on Jun 20, 2008
It turns on but nothing comes on the screen, last nite it just cut off completely
Looks like an LCD power inverter problem.
If your LCD have some shadow when you turn it on( turns completely black ) and turn it off the screen become gray. Means the light behind the panel board of the LCD is not working.
That problem maybe the wire that's been cut off in the left hinge area or the inverter is not working anymore.
You have to open and check those inside the computer and LCD cover.
If you have no experience on such repair, you have to bring it to the nearest tch to repair it.
Hope FixYa helped you out!
Aug 23, 2011 | Toshiba Satellite L455D-S5976 Notebook
I have a Samsung LN46C650 and sometimes the picture goes black and the audio cuts out for a second or two. It occurs at least once a day but it happens at random so I cannot duplicate the situation. I'm...
I have the same problem. At first the tv would just blink occassionaly and the sound would cut out just like yours. We realized if we turned the tv off then back on, it would be fine. Well, that's not working anymore, and as opposed to a blink, the tv picture is cutting off all together, can't imagine it will do anything but get worse. I called Samsung about another problem I had with the tv, the autofit screen size selectioon was great, however over time, on some channels there got to be a progressivley larger white line at the top of the screen. At first we could adjust the picture up to completely close the line. Now it is too large to cover up. Samsung said, "that's normal."....progressively worse performance?
Sep 06, 2010 | Samsung LN-T4665F 46 in. LCD Television
Laptop cut off
Go to "Control Panel", click on it, then click on "Appearance and Themes" click on "Screen Saver", Look towards the bottom of the screen and find "Monitor Settings", click on "Power". Check to see if the setting have changed, I set all my settings to "Never", that way I can shut them down when I want to.
I hope this helped.
Please do not forget to rate me
Jan 22, 2010 | Toshiba Satellite A100-S8111TD Notebook
Toshiba REGZA 37AV555D smashed screen
Yes the screens can be replaced and if you're half decent with a screw driver (and have the patience of a monk) it's probably worth attempting yourself.
Ball park figure for a new screen is around £150 but I recommend you get on eBay and buy either a used screen or smashed up laptop and take the screen off that. It should work out a much cheaper repair.
Dec 15, 2009 | Toshiba MK8026GAX (hdd2191) 80 GB Hard...
Need screen for 61" toshiba theaterveiw projection tv
The part numbers for the screens for the TP61H60 are:
Fresnel (interior screen) 23837528
Lenticular (exterior ribbed screen) 23837528
They used to run about $170 for each plus shipping which was expensive due to their size. The problem is that they are discontinued. I have had success using screen from other manufacturers in different sets, i.e. a Hitachi screen in a Sony TV. Even if you can find a larger size screen you can cut it down using a utility knife and a straight edge. I have done that as well.
Good Luck!
Rob
Nov 26, 2008 | Toshiba TP61H60 61" Rear Projection...
IMAGE IS ZOOMED ON SCREEN
use the format button, might be called screen size. You are looking at a format that the screen cannot show completely, I can cut the top and bottom off or make it widescreen and lose the edges on my TV
Feb 24, 2008 | Toshiba MD20F51 20 in. TV/DVD Combo
Toshiba Satellite 5105-s501 Restarts Windows then shuts down intermittently
Yes it could be, the notorius GeForce2Go is a replaceable card on that model. I have seen, lines, blurry text, and Boot loop issue caused by it. Be warned, the replacement card is expensive.
Cheaper & better finding a complete laptop with busted screen.
and removing the card only. Then you will also have other spare parts.
Dec 11, 2007 | Toshiba Satellite 5105-S501 Notebook
Toshiba 50A60 Lenticular cracked.
I don't have a particular source, but if you fail to find one you may try using a similar screen fopr a different model if you're a bit handy. Depending on how the screen is fastened, you might even be able to fit a regular canvas (roller curtain type or similar, user with video projectors)
If it has to ba some kind of specific frame on it you miahgt have to "hack" it, and it might not be that pretty. If it's just a screen fastened inside a frame, kind of like the glass in a picture frame you can get one in the same size, or a bit bigger and cut it down to size yourself.
Nov 26, 2007 | Toshiba 50A60 50" Rear Projection...
Toshiba TP50H50 50" Rear Projection Television Logo
50 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
