Swintec 7040 Typewriter Logo
Posted on Nov 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I get the Swintec 7040 to just do straight typing instead of when I hit the return. It must be in some type of mode. Also, how do I clear the left/right margins and reset them?
Anonymous
Level 3:
Genius:
  • Master 1,218 Answers
  • Posted on Nov 19, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1218
Questions
0
Helped
288145
Points
1893
Sounds like you also don't have a manual....press the "code" key until the little arrow in the display sits above the NP indicator.
You can download a manual for a Nakajima AE-830 ( ITS THE SAME MACHINE.) from www.nadist.com
2answers
How do I increase the margins on the typewriter
To set a margin beyond the left or right margin, move the carrier (or cursor) to that margin, press the Margin Release key, then proceed to move the carrier (or cursor) to the desired position. Then, press the Left or Right margin key to set the new margin. A beep will sound indicating the new margin has been set. When you set a new left or right margin, the previous margin is automatically cleared.
Alternatively, you can type beyond the right margin by pressing the Margin Release key and then continue typing when the carrier (or cursor) stops at the right margin. To type beyond the left margin, press the Margin Release key and then the Backspace key to move the carrier (or cursor) to the position where you want to start typing.
Remember to always use genuine Swintec ribbons and lift-off tapes for your Swintec 7040, which can be found at Swintec Typewriter Supplies .
Swintec 7040 typewriter - what is the code key and mode key for
The code key works with all the keys in the top row to set up those functions, bold, underlind, KDII, etc. The function allows you to type on the display befor printing.
DickyO
How do you show the print on the screen b4 u type
Pressing the mode key (L. side of keyboard) the arrow will move on the display you want to leave it on LP.
DickyO
When I type straight letters I get symbols and numbers an example I typed the phrase "Hi How are you?" w w-2 v/j a-qI appeared on my paper I have no idea how to clear this and return it to normal script
There is a switch on the keyboard that must have gotten moved..for symbols..or the printwheel is in wrong. Take the pw out and reseat it. it should spin when it is snapped back in. you may have to close the cover for it to go to it's Home position.
squipps
Typewriter will only type straight lines
It sounds like you either don't have a printwheel in the T/W or the spokes are broken. What you are seeing is the hammer face.
DickyO
Swintec 7040
If what you are saying is that you get 2 vertical lines instead of a letter start with a new printwheel, what you are seeing is the hammer face when it misses the printwheel.
DicktO
First check check the pitch selector switch to be sure it is not in proportional spacing. if it isn't push down on it and see if it goes away, if is goes away the keyboard needs repaired.
DickyO
Top Swintec Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Mitch Vass
Mitch Vass
ADMIN Andrew
ADMIN Andrew
Are you a Swintec Office Equipment and Supply Expert? Answer questions, earn points and help others
