Question about Nokia N95 Cellular Phone
My LCD on my N95 keeps flickering on and off
It was a bit humid on my vacation and since then, my N95 LCD Screen flickers off for about 20-30 Seconds and I have to wait for it to flicker back on for another 20 or so seconds but then it keeps flickering off again.and then back on. How can I fix this problem?
  • Anonymous Mar 19, 2009
    where can we go to fix this?
  • Anonymous Mar 30, 2009
    lcd on my nokia n95 8g flickers and eventually goes white. if left alone for a while it often corrects itself but it seems to happen at inconvenient times.
  • 282 Answers
It could be a ribbon/flex cable issue,it could be moisted adn needs to be replaced.
Posted on Jun 24, 2008
Just replace the FLEX (ribbon cable) this is th best way to solve your unit...
Good luck!!!
Posted on Apr 08, 2009
I have a 40inch Samsung le40r88bd that keeps flickering and is getting worse is there an easy fix?
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
https://www.youtube.com/watch?v=i-jQZ-TQdgU
Jun 4, 2012 - Uploaded by Tampatec
How to Fix Samsung TV Flickering Blinks Flashing Flat Screen Picture EASY most common way MODEL ...
Flickering picture
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsMar 13, 2013 - A flickering picture on your TV can be caused by the following conditions: Television settings; Incoming signal issues; Electronic interference ...
How to fix Samsung LN46C630 screen flickering issue
Jan 16, 2016 | Samsung Televison & Video
Need fix how do i make it stop flickering
Coby lcd tv keeps flickering Flat Panel Televisions ... - Fixya
www.fixya.com > ... > lcd tv keeps flickering > Flat Panel Televisions
Coby flat panel televisions lcd tv keeps flickering related questions and answers. Ask your Coby ... Why does my Coby 40 TFTV4028 LCD TV keeps flickering.
Coby adjust air fuel mixture Flat Panel Televisions ... - Fixya
www.fixya.com > ... > adjust air fuel mixture > Flat Panel Televisions
Coby flat panel televisions adjust air fuel mixture related questions and answers. Ask your Coby ... Coby 32 in tv ... to last channel, and will stop, and will display the first channel it has got. Then we have to make adjustments on channels. ... Ad. Question about 40 TFTV4028 LCD TV. 1 Answer ... Flickering can be adjusted.
Won't turn. on red standby light changes to on but then
Jan 04, 2016 | Coby 40 TFTV4028 LCD TV
Luxor 40 914 tvb
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 13, 2014 | Televison & Video
I bought new screen of ebay but it flickers
Did you check both ends of the LCD Screen cable? The end that goes behind the lcd screen at the top and also the other end that attaches on the board. Also put a piece of tap over where the connections meet on the lcd screen to keep it in place.
Did you reseat (unplug then plug back in) the 2 cables that are in the LCD Inverter located at the bottom of the LCD Screen?
Apr 02, 2012 | Samsung R519-53S Notebook
RCA 37" FLAT SCREEN NON STOP FLICKERING/FLASHING SCREEN
you need to remove main ckt, (m.board) some part need to re solder specially in hot area. (lost contact i one of the flickering problem you encountered.
Mar 26, 2010 | RCA L37WD12 37 in. LCD HDTV
N95 replacement screen flickers after 20 mins of
remove the screen and reinsert it.....may be some loose connections.. try using another screen...if problem persists then update the firmware or else change the screen....
Nov 24, 2009 | Nokia N95 Cellular Phone
My R51 thinkpad screen keeps flickering and is quite garbled it blanks out alot and stays black until you hit FN + F7 (the key to switch from laptop screen to desktop screen) in wich case the screen would...
Sounds like the lcd is toast.
Hook the laptop up to an external monitor and see if you get normal video. If you do, chances are it's the lcd. You'll have to replace it.
Jun 19, 2009 | IBM ThinkPad R51 Notebook
Screen flickers for about 20-30 seconds sporadically
Try looking at the LCD screen at a sharp angle to see if ghost-like video can be seen during the 'off' time of the flicker.  If video is still present even though not that visible, then either the backlight or its power supply are failing. The color problem could also be caused by a backlight lamp that is not ionizing completely.
Dec 14, 2008 | Acer AL1912B 19" LCD Monitor
LCD screen 'flicker'
Try setting the video output option to NTSC (if it's on PAL). I know this sounds funny, but I have heard some rumblings about this option somehow creating a LCD flicker. If it doesn't work, I apologize in advance for wasting your time! My camera is on NTSC and I haven't seen any flicker on the file numbers on the LCD.
Sep 19, 2005 | Nikon D2H Set Digital Camera
Nokia N95 Cellular Phone Logo
631 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
