Question about GE WBVH6240F Front Load Washer
Ge front loader
Where do you find the filter
It took us a while but we finally found it. It is behind a panel. This panel is in between the top part of the washer(the section that has the door, in other words the actual container for the clothes) and the bottom drawer(if you have one). You have to remove the panel by removing some Hex nut bolts. After you remove the panel you see a plastic cap. After you unscrew the cap, you see the filter. Yucky things may start draining out immediately after you unscrew it so have something below it to catch it. We had tons of water come out on one occassion. By the way, the plastic cap looks kind of like the cap on your car you have to unscrew in order to put gas.
Posted on Jul 11, 2008
3 Suggested Answers
SOURCE: my ge front loader washer will not drain
We had same problem. The pump was all clogged up with fabric debris, and a part of a metal bra liner. I removed the pump and cleaned it out. Now it seems to work fine, and went through a complete cycle. Ther pump was accessed from the front, and was not too hard to remove.
Posted on Mar 01, 2009
erickg
  • 116 Answers
SOURCE: washer will not spin or agitate
you should be able to get your manual here
http://laundry.manualsonline.com/manuals/mfg/ge_appliances/ge_appliances_washer_product_list.html
Posted on Apr 16, 2009
How do I access washer filter pump?
Generally for front loaders. Disconnect power from circuit breaker or unplug power cord before starting. The filter in the hotpoint aquarius 1200 is in the front bottom side, hidden by a trim panel. Remove the trim panel at the bottom of the front side (screws underneath?) and find access at the right hand side. Keep a large flat container ready to collect water from drain filter. If helped pl click so.
Mar 23, 2013 | GE WSXH208A Front Load Washer
Where?s the filter on my GE WSXH208A Front Loader? Thank you beltronic205 (GE WSXH208A Front Loader won?t drain). I drained the tub by lowering the drain hose as suggested. But where is the filter, what...
There is no acutal filter on this unit...You cab remove the back panel to access the drain pump ...Or tilt the washer back and access it from the bottom...Remove the drain hose from tub to drain pump...(careful of flow of water from tub)...Check the hose for any blockage...If no blockage then your pump is bad..
Apr 20, 2010 | GE WSXH208A Front Load Washer
Where is the filter located on the front loader so I can clean it
check at the inlet water connecting end. Filter genarally inserted into the polypropelene pipe. This place only we thread the hose
Mar 29, 2010 | GE WSXH208A Front Load Washer
My ge front loader will not spin. the door is
My front load washer will not spin or the drum will not turn on the wash or spin cycle.
Dec 13, 2009 | GE WBVH6240F Front Load Washer
GE washing macine stops during the wash cycle
This is exactly what my machine was doing, as well. I fixed it by cleaning out the filter in front of the water pump.
Searching here, I found that you can remove the lower front panel (three screws along the bottom edge is all it takes) to get to the filter. With the panel removed, you'll see a round white plastic cover (about 3-4 inches diameter) that screws out. Get a bucket under the cover to catch the water that's in it (could be 2 quarts or more) and unscrew the cover.
The cover pulls out, revealing that is actually a screw-in plastic strainer. I found tons of coins, broken pens, paper clips, etc. in mine when I did this. A lot will be deep inside the black rubber hose that connects this filter housing to the washer drum. You can rake the stuff out with a bent wire clothes hanger. Shaking the black hose will help hurry the junk along and out of your machine. Screw the cover back on after the clean out and your machine should go back to normal.
Thinking about it, front loaders will have lots of small items flushed into the pump compared to top loaders. Coins you alway found in the bottom of the drum in a top loader, they all wind up in the filter of a front loader. And once it slow the drainage to a crawl the machine will shut down multiple times when it can't drain the water out completely, and it will never step up to it's max spin speed with all that water still in the drum.
Nov 26, 2009 | GE Energy Star WCVH6260F Front Load Washer
Remove lint holder on ge front loader dryer
I have the exact same problem. I am amazed at had been the engineering is for such a simple process. The user guide just says to clean the lint filter. Even when doing so, there is still an excessive build up of lint beyond reach. There are no instructions that mention how to clean this part. It is obvious that GE did not test this part of the machine.
Jan 30, 2009 | Zanussi ZWF1440 Front Load Washer
Ge Adora Front Loader
If you have not already done so, clean the filter behind the panel in the front bottom of the washer. Remove the three philips head screws to get the panel off. Unscrew the plastic filter on the right hand side (use a shallow cake pan to catch any water). Remove the filter and clean out the pens, pencils, change, lint, etc... and put back in. All should work well after this. Thanks, Greg
Dec 15, 2007 | GE Energy Star WCVH6260F Front Load Washer
GE WBVH6240F Front Load Washer Logo
90 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
