Question about Microsoft Windows Vista Ultimate Edition
Regestry editor i want a sound knowledge about regestry editor
  • 67 Answers
A central hierarchical database used in Microsoft Windows 98, Windows CE, Windows NT, and Windows 2000 used to store information that is necessary to configure the system for one or more users, applications and hardware devices.
The Registry contains information that Windows continually references during operation, such as profiles for each user, the applications installed on the computer and the types of documents that each can create, property sheet settings for folders and application icons, what hardware exists on the system, and the ports that are being used.
The Registry replaces most of the text-based .ini files that are used in Windows 3.x and MS-DOS configuration files, such as the Autoexec.bat and Config.sys. Although the Registry is common to several Windows operating systems, there are some differences among them.A registry hive is a group of keys, subkeys, and values in the registry that has a set of supporting files that contain backups of its data. The supporting files for all hives except HKEY_CURRENT_USER are in the %SystemRoot%\System32\Config folder on Windows NT 4.0, Windows 2000, Windows XP, Windows Server 2003, and Windows Vista. The supporting files for HKEY_CURRENT_USER are in the %SystemRoot%\Profiles\Username folder. The file name extensions of the files in these folders indicate the type of data that they contain. Also, the lack of an extension may sometimes indicate the type of data that they contain.
Posted on Jun 24, 2008
How can i make my pc run faster and can i change the hard drive where i can start over it was giving to me by my friend and what ever he has on there i don't need
first of all download ccleaner
run and scan for unwanted files
download a regestry cleaner like regestry mechanic
do regestry scan and fix the errors.( ccleaner also has a regestry cleaning option but it is limited)
change your startup programs and uninstall programs you dont need.
let me know if you need more info
Mar 07, 2010 | Dell Inspiron 2200 Notebook
Tip
How to speed up your windows computer(xp,vista,win7)
This has been a question of a million people that "How can i speed up my computer" so today I will share some small infos that will help you to speed up your windows based pc/notebook/laptop with a very small knowledge about your computer.
#Your computer has some beautiful tools built in to help you speed up your pc. The main reason that makes computers slow are basically less memory, running more service/programs at once and some Regestry error which occurs due to various software install and un-install. Regestry errors makes your computer works more and get less work done. so this is what you could do
#1.open run/search box from the start menu nad type in this" cleanmgr" delete/cleanup the files you want to remove/ you don't need. That will give you some extra space to work with.
#2.Download ccleaner which is free software reomended by various computer experts. install and run the software. It will also help you to cleanup some extra space. you can use the regestry option to check for some simple regestry error and fix those.
#3.Open ccleaner and go to "tools">>startup and change the programs you don't want to start when you start your computer for exmaple. skype,yahoo,fax/printer service etc. This will decrease your computers bootup time.
#4.from the start menu open the run/search box and type in "dfrgui". this will defragment your computer and fix some regestry error.
#5. Download any good regestry cleaner. I will recomend Regestry Mechanics a software made by pctool the same sompany makes the best anti spyware " Spyware doctor".It will help you to fix almost all the registry error.
Now restart your computer and you can feel the difference by your self. thank you!
on Mar 07, 2010 | Computers & Internet
My Num Lock keeps turning off whenever I log off my computer. It never used to do that. how do I fix it so it stays on?
dear sir
good day
to fix this problem you can enable this option from the bios setup sw by clicking on del button and navigate to this option and make it enable or you can fix it up with regestry editor by do the folowing
1.Click Start, click Run, and type regedit to open
the Windows registry editor.
2.In the registry, open the below folders.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
3.Within the keyboard folder, you should have
a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2.
Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon.
Dec 24, 2009 | Computers & Internet
My windows updates are failing continuously kb973593 kb953297 kb973636 kb973704
You can go to this site and read the error code fixes,http://support.microsoft.com/kb/310123 and you can also check each code and here is one more for xp. http://support.microsoft.com/kb/290158 your problem is in your device manager and you may have to use a regsstry editer to fix the problem but is better that you go to the web page and download a free web regestry editor to help fix some of your issues.
Nov 12, 2009 | Microsoft Windows Vista Ultimate Edition
Dvd driver of toshiba
THere is no need to get DVD drivers as they are included in standard windows package and are integrated.
In case you have windows Vista installed and dVD is with exclamation mark in Device manager you jut need to delete upper and lower filters in regestry.
Step 1: Start Registry Editor
Click Start, click Run, type regedit, and then click OK. Registry Editor starts. (In Vista, right-click Registry Editor, and select Run as Administrator)
Step 2: Delete the UpperFilters registry entry
In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE.
Expand SYSTEM, and then expand CurrentControlSet.
Expand Control, and then expand Class.
Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
In the right pane (topic area), click UpperFilters.
Note An UpperFilters.bak registry entry may also appear. To delete the UpperFilters registry entry, you must click UpperFilters and not UpperFilters.bak.
On the Edit menu, click Delete.
When you receive the following message, click Yes to confirm the deletion of the UpperFilters registry entry:
Are you sure you want to delete this value?
The UpperFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
Note Do not exit Registry Editor. You must have this program for the next step.
Step 3: Delete the LowerFilters registry entry
In the right pane (topic area), click LowerFilters.
Note An LowerFilters.bak registry entry may also appear.
To delete the LowerFilters registry entry, you must click LowerFilters and not LowerFilters.bak.
When you receive the following message, click Yes to confirm the deletion of the LowerFilters registry entry:
The LowerFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
Exit Registry Editor.
Step 4: Restart the computer
Important: If a CD recording program no longer works after you restart the computer, you must reinstall the CD recording program.
Sep 14, 2009 | Toshiba Satellite A105 Notebook
Trying to run a sound card's installation CD on my DVD drive but CD won't run (new CD from Ebuyer) Believe my DVD drive may be faulty. How do I check if drive working and if not any way of getting it to...
have you tried another DVD yet? you might jsut be good spending the $20 on a new drive.
you could also try running a regestry editor to fix corrupted registry as it is a likely cause of drives not working
also, updating drives is good
Aug 03, 2009 | Computers & Internet
Error 1311: source file not found:E\LENOVO3000 Y410 USER GUIDE\VISTA\6.LAN\FILES6~1.cab , Verify that the file exists and that you can access it.
The cause of the error is a problem with the Microsoft® Windows® Installer program used by the software. It produces the error when the registry entry AllocateCDRoms at the following subkey is set to a value of 1.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
Warning!
Problems caused by improperly editing the Windows registry could render your computer operating system unusable. Microsoft has provided a wealth of critical information you need to know about the registry in the Microsoft Knowledge Base at http://support.microsoft.com/support.
Use the Microsoft® Registry Editor only at your own risk and only after backing up the registry as well as the system.dat and user.dat files as outlined in ARTICLE-ID: Q132332 "How to Back Up the Registry" in the Microsoft Knowledge Base. Additional information about the registry is also contained in the Help topics in the Microsoft Registry Editor.
Start the Registry Editor and locate the following subkey:
goto start->run and type regedit to start registry editor
Change the value for the AllocateCDRoms entry to 0.
Exit the Registry Editor.
Dec 28, 2008 | Lenovo 3000 Y410 Laptop
Cannot fax to international number using netsatisfaction
the modem will dial any number you give it. Check with your phone company.
May 28, 2008 | FaxBack Inc NETSATISFACTION (FL1001) for...
Direct x deleted
Hello Akshay jain
try to go to system restore and restore your computer to good work point .when you complete restore your computer try to install new version of directx with uninstall the previous version because that mean it will upgrade your version or replace it automaticly.
good luck
Jan 12, 2008 | Adobe Photoshop 7.0 for PC
Microsoft Windows Vista Ultimate Edition Logo
122 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
