Question about Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Oversize Message When booting up my computer, it starts to boot up with normal picture, then the screen says "OVERSIZE recommend Mode 1280 X 1024". The screen then goes blank and the power LED turns from steady green to blinking yellow. Another moniter works fine with the computer and the Kogi moniter works fine when connected to my laptop.
  • wes0369 Aug 10, 2008
    Genius:
  • 1,011 Answers
Dear,
run the system on safte mode and then try to manage your screen resolution to minimum and then restart it normally..
regards,
dont forget to rate
Posted on Aug 08, 2008
Samsung SyncMaster 713BM
Hey!
Follow the instruction below to solve your problem:
Restart your computer and enter Safe Mode (press F8 right as the computer starts booting up. Choose Safe Mode in the menu, press Enter twice).
While in Safe Mode, open Control Panel and go to Add/Remove Programs (Programs and Features on Vista/7) and uninstall the display driver software/drivers.
Restart your computer and boot normally. Now you should be able to see everything. Things might look bigger and uglier, that because there's no display driver installed. All you have to do now is reinstall the display driver. Use it's original disc or go to the manufacturer website and download the latest driver.
Pelu.
Mar 27, 2010 | Samsung SyncMaster 713BM 17" LCD Monitor
I have this monitor and just bought a new computer. When the computer boots up and gets past the "windows" graphic monitor goes black. It worked fine with my old computer and my new computer works with an...
You may try the following steps:
Boot the computer in safe mode.
While booting press the F8 key and on the Windows Advance boot screen, select safe mode and press enter.
Once you are on the logon screen, select Administrator account.
Click on Start and rightl click on My computer, then click properties
Go to hardware tab and click on Device manager.
In the device manager look for Display adapter, Click on the + sign, right click on the listed devices and uninstall.
Now you should be able to boot the computer in normal mode.
Please let me know if you need any further assistance.
If you find this solution helpful, please do not forget to leave your feedback and ratings.
Thank you for choosing Fixya.
Nov 27, 2009 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
My ViewSonic computer monitor keeps displaying a Vga Not Support Message upon booting then the message Out Of Range comes up on a completely dark screen. Need Help
It sounds like the computer is trying to use a resolution that the monitor cannot handle. Boot into safe mode by pressing the f8 key during boot up and select safe mode. Once booted, right click on the desktop and select properties. In settings lower the resolution by moving the bar to the left and reboot.
I would move it all the way down, you can then move it up a step at a time once you are in normal mode again.
Hope this helps
May 02, 2009 | ViewSonic VA721 17" LCD Monitor
"Input Not Supported" message on monitor at boot
Sounds to me like the input has gone out of the boundaries the monitor supports. IE the refresh rate is too high frequency (normally 60 to 72 Hertz for LCD's) or the screen resolution has been set too high.
Go into safe mode and set it back to 1024 X 768 at a frequency of 60 Hz, once back into windows proper you can try higher resolutions and change your refresh, if the screen goes black or displays a message "Out of Bounds" or similar it should revert after 15 seconds if left alone.
Have fun
Apr 27, 2009 | Envision EN-9250 19" Flat Panel LCD...
Kogi monitor will not resolve screen
Startt the pc in SAFE MODE  and change thr resolution of the screen, the computer does not work on 1280 X1024, so AT THE BOOT TIME  PRES F8 chose save mode with windows, tan on the property of the display change the video resolution at 1280 X1024, and i think you don't have the video driver instaled not sure but u can chek that as well.chek run WINDOWS UPDATE if your diver is not in place. to chek driver take a look in computer management  DEVICE MANAGER.
Jan 20, 2009 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Wont work with new computer
Since this was a new out of the box computer, Safe Mode was not allowed. In order to change monitor settings (resolution), I had to use another monitor, in this case a newer CRT. With the CRT, the computer booted up, no problem. Once booted, I turned down the monitor resolution and saved. Now when the Princeton LCD was plugged in and the computer restarted, everything works fine. Now the resolution could be set to limits of the monitor.
Aug 19, 2008 | Princeton Digital VL173 Monitor
Does not work with new desktop
All you have to do is change the monitor resolution to that mode. That's probably the maximum resolution you will get with that monitor, video card, and comptuer.
Aug 13, 2008 | Kogi l5qx-ta ko 15" Flat Panel LCD Monitor
Olevia Monitor
Restart your computer and tap the F8 key until you get the Windows Advanced Options Screen. Use the arrow keys on your keyboard highlight Enable VGA Mode (Low Resolution Mode for Vista). Press Enter. Then Enter again.
Windows will boot up in a low resolution which will make things look large. Raise your resolution to a normal level in Windows' Display Properties (in the Control Panel)
The next time you restart the computer, it will boot normally.
Jul 04, 2008 | Proview PL926WBi 19" LCD Monitor
Samsung SyncMaster 931B
I tried both suggestions above and neither worked. 1) Hitting the monitor buttons as stated only got me a "digital" message and then the monitor went black as usual. Never got to any menu options. 2) Going into Safe Mode and changing the monitor settings or downloading/installing the correct driver didn't stick once you went back to the normal startup.
I didn't have another monitor handy to swap out so I had to be a little more creative. The only solution that worked for me is re-booting (F8 during startup) into the mode "Enable VGA Mode". This allowed me to go into the normal desktop with a screen resolution of 800x600. I went online, found the driver, downloaded it to the desktop. Deleted the video driver (Device Manager), installed the downloaded version, rebooted and....no problems.
I have Windows XP. Hope I've helped someone today. :)
Mar 27, 2008 | Samsung SyncMaster 913N 19" LCD Monitor
Kogi l7eh-ta ko 17" Flat Panel LCD Monitor Logo
399 people viewed this question
Top Kogi Computers & Internet Experts
Laxman Bisht
Laxman Bisht
Daniel Florin
Daniel Florin
Brian Sullivan
Brian Sullivan
Are you a Kogi Computer and Internet Expert? Answer questions, earn points and help others
