I'm trying to set up my Mom's new Gateway laptop to her new Netgear router through a ewire modem, so she can use her computer anywear in her house. We ordered the net gear pc card and it does not fit properly. After calling them back (Kanokla, the company that sold the Netgear products to us) they told us that we probably didn't need the card, it should be built in. Please help!
    Master:
  • 788 Answers
If the notebook is new (less than two years old) then it almost 100% most definitely absolutely has built-in wireless.
The card doesn't fit since it is a PC card and new notebooks use ExpressCards instead.
Posted on Jun 20, 2008
I installed a new Netgear wireless router. My old G router didn't cover the whole house, so I got a N600 N/G router. My Acer 5610 hooked up the the old router with 128 bit WEP encryption fine, as did my...
This could be a few things. all are simple settings.
If you can see other computers but can't get out, your acer needs the gateway ip number. If you are running DHCP this should be automatically set but you can also manually edit the IPV4 settings
TCP/IP and add the gateway as well as the other settings. The gateway is the ip# of your router that is connected to the cable modem or the dsl modem.
As long as you don't have the number range set you can fairly safely add any number in the allowable range. So you could edit the tcp/ip settings with something like the following:
adress: 192.168.2.25
netmask: 255.255.255.0
gateway: 192.168.2.1 ** insert actual addy of router.
DNS servers can be found on your isp's info page. You can use any dns server that will let you connect. Without the dns you won't get out on the net either unless supplied by DHCP.
Jul 30, 2010 | Acer Aspire 5610-4648 Notebook
Running install disc, says does not support operating system
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Mar 03, 2010 | NetGear WGR614 Wireless Router
Hi i have a netgear gateway router rt314 and i wanted to connect it but i dont know how can u plz help me
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
Then you need to connect the computer to the router ad the modem to the router.
Click Here for step by step by instructions
Feb 08, 2010 | NetGear RT314 Router
I have moved one of my two computers to my guest house which is about 120 feet away from my cable modem and I have no connection to the internet. I have the computer in the main house connected to a...
I would go wireless. Try to connect to the net using a laptop (wireless) at the guest house. If the signal strength is decent you should be fine with getting a wireless NIC for the PC in the guest house.
If the signal strength is bad, either buy a 802.11N router (make sure it's N and not draft N, these should be available now or within a few weeks (nov 09), or buy another access point and connect it via ethernet to the main access point. you only want one modem and one gateway generally speaking.
Nov 08, 2009 | NetGear WGR614 Wireless Router
Same old question, but I cannot get a connection between my Netgear wireless router WGR614 to my cable modem.I follow the set up via the router's wizard. But no luck. Even unplugged the modem for 15 mins...
Can you pls confirm if you have cable or PPPoE connection. Also, please connect the modem directly to the computer and let me know the results:
A. Click on Start—Programs—Accessories—Command Prompt.
B. In Command Prompt window, type in 'ipconfig' and hit 'Enter'. Note down the IP Address, Subnet mask & Default Gateway here.
Once I have this information, it will be quite easy to configure the router.
Oct 09, 2009 | NetGear WGR614 Router
New mini computer says"acquiring network address" shows contected to netgear but won't access the internet
It means your router dhcp is not running proeprly.
You can set ip addreses manually.
for that go to my network places proeprty then you see your network adapter right click on it then go t oit's property then tcp ip .
Set ip addreses , subnet mask and gateway.
set your ip addreses if your router ip is 192.168.1.1 then you can set your computer ip is 192.168.1.2
subnetmask as 255.255.255.0
and set gateway as your router ip means 192.168.1.1
you can access your router with default link
http://192.168.1.1
or http://192.168.0.1
type user name a s"admin" and password as "admin" or blank or "password"
then check its ip and settings.
Aug 08, 2009 | NetGear WGT624 Wireless Router
Have a new Hughes net HN9000 satellite service and trying to get the Netgear wireless router to allow me to connect to the internet. Have two other computer set up for the home network and they can see the...
Hey, Can you perform the task below and paste me the results from the modem:
Connect the modem to the computer. Open command prompt and type ipconfig. Paste me the results for IP address, subnet mask and default gateway.
Also, confirm, how you have connected the modem to the computer. IS it using a ethernet cable or USB?
Once I have this information, I will be able to provide you with an accurate resoultion.
Jun 30, 2009 | NetGear MR814 Wireless Router
Can't connect my Netgear WGR614v7 to Time Warner Cable Internet
I have just bought a Netgear WGR14 v9 and I was wondering if anyone knows how to set it up with Time Warner. We just swithced from Bellsouth to Time Warner and I don't know how to set it up?
Jan 11, 2009 | NetGear WGR614 Router
Does a router or combo need to be connected to computer?
As you already have the modem you only need a router. In all cases the modem connects to the WAN port on the router.
I think your best bet surely would be to go for a wireless router though? Then you wouldnt have to trail ethernet cables all round the house. I'm sure your laptop has a wireless adaptor built in unless it;s very old.
I always use Netgear networking stuff so forgive me posting a link to a nice 54G wireless router :-) :
http://www.amazon.co.uk/Netgear-WGR614UK-Wireless-Cable-Router/dp/B0000C1WO2#moreAboutThisProduct
Dec 27, 2008 | Toshiba PCX 5000 Wireless Cable Modem...
My 3 different mac laptops with airport can't connect to my wirless
Sounds like you might be accidentally connecting to a neighbour's network instead of your own. You need to go into your wireless settings on each laptop and tell them to connect to your own network.
Jan 16, 2008 | NetGear Super G WGT624SC Router...
Computers & Internet Logo
79 people viewed this question
David Payne
David Payne
